Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
43" sony - model no. kf42we(g or 6 ) ? 10
Problem - powers on - no sound pic is all green. change channels and it goes all blue - sometimes lines show up - when a dvd player is attached - same thing - my email is - I am in Cleve. Ohio
  • 1,694 Answers
KF-42WE610.....Probable bad Optical block assy..Contact
Auth.Sony for warranty as part is expensive = Optical block assy. at cost about 750.00 + 600.00 core charge....................................T.
Posted on Dec 26, 2007
Showing colors out of line. Like a 3d look.
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D, wavy, or has a shadow or shadows
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
You can get the correct parts, step by step photo instruction guides, and support from or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Jan 02, 2011 | Sony KP-43HT20 43" Rear Projection...
A 16/4 channel Mackie VLZ bought new 1997 hardly used. Some times a channel goes quiet, sometimes the fault moves to another channel, or while setting a channel input signal the knob seems to work till...
I suspect you MAY have a severe ground loop. The green light indicates channel crossover if nothing plugged in.
MAKE SURE ALL connected equipment is powered from the SAME receptacle. If you service amps from receptacles at one end of the room and this board from the other end, you are ASKING for trouble.
Read up on "common mode" as it pertains to balanced lines. Equipment can be at risk if grounds "bounce" as they often do.
When green light with no inout shows up, slide all faders down first. Then unplug input lines one at a time... turn off the amps and then unplug the output lines one at a time. See if one of these inout or output lines was causing the green light.
You should be using BALANCED lines to your amps... either XLR or TRS types at both ends.
May 17, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
There is just three lines that show red, green and blue.
It has been my experience with Sonys that those three colored lines indicate that the set is having trouble with the data communication lines. The hitch is that a model as complex as that one has as many as five seperate clock/data lines and if any one of them goes down the set will exhibit your symptom. It will take a professional to track down which line is causing the problem. I've seen audio output IC's as well as tuners cause the problem.
Jun 03, 2009 | Sony KP-61XBR48 61" Rear Projection...
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
TV: vertical colored lines on TOSHIBA TV Model 36ZP46P
Jul 05, 2008 | Televison & Video
Tv has a brownish green tint to it
Sony Convergence
Dec 03, 2007 | JVC AV-56WP30 56" Rear Projection...
Channnel keeps flicking like your changing channels with remote
when you say flickering??? are you saying the screen goes black and comes back on?? does the sound go out at the same time and comes bag on with the pic ? Is the sound there when this happens but is distorted. Is the pic blacked out or is it greying out with lines and twisting?? Need more info please as if its blacking out and the sound goes with it it may be going into shutdown. If the pic is getting kinda greyish with it twisting and the sound is there and ditorted then the tuner could be bad
Mar 25, 2006 | Sony KV-32S26 32" TV
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
67 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
