Question about Toshiba RD-XS25 DVD Recorder/HDD Recorder
Playback Problem When we record using a VHS tape, we have problems with the playback - the picture jumps, the sound is very poor. However, when we take the same VHS tape to a different VCR, the playback is perfect. The DVD player works perfectly, obviously the record feature for the tapes is fine, but the playback is a problem. Any suggestions?
    Sergeant:
    Novelist:
  • 197 Answers
Open the recorder, 4 screws at each corner, wipe the playing head and the voice reccognition head, to the right of the playing head head with a baby wipe, you will be amiazed what **** comes off it. DON'T scrub it just wipe lightly, spin the playing head so it's clean. If you have a lint free cloth ( a glasses cleaning cloth you get in the case is brilliant) Try the tape (before you put it in make sure everything is DRY!) and your problem should be solved. It worked for me! and that came from a TV engineer
Posted on Jul 15, 2009
I have the remote the date etc. programmed OK but how do I set up the actual recorder with undefined
Panasonic are very good at having free PDF copies of user manuals. However if you just want to playback old tapes then all you need do is connect the vcr to a TV and press play. You might need to adjust the tracking using the controls on the remote. But the picture should play. If you see snow on the screen, but can hear sound, then the tape heads will need to be cleaned. You can get a VCR cleaning tape for that.
Oct 29, 2014 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
TAPE MECHANISM WON'T ROLL THE TAPE, IN EITHER RECORD OR PLAYBACK
Problem with the tape transport mechanism; could be the rollers are not contacting the tape itself or it could be the springs in the transport. Sounds like an older model. Could clean the rollers with alcohol and swap and if you can open it a like observe what happens with the rollers when you place in playback. These are rather delicately adjusted machines. I would again 1) try cleaning as best you can and very light oil in moving joints/gears aferward. 2) check adjustment of springs when moving from stop to playback. Once you have that whipped the record mecanism may start working as well.
Apr 02, 2012 | RCA CC4393 VHS Analog Camcorder
I've had a DR-MV5S DVD video recorder & video cassette recorder for years to transfer DVD over to VHS tapes. Something has recently happened where I can't record VHS tapes. Can't play VHS tapes on the...
Register and download the manual for free audio.manualsonline.com
http://portablemedia.manualsonline.com/manuals/mfg/jvc/jvc_dr_drmv5s.html
If it won't PLAY VHS tapes it must have a serious mechanical problem (if it even loads) or its heads are glommed up, so it obviously won't record them either. When's the last time you ran a cleaning tape through it?
Solve the load or playback problem and it will probably record.
Time and poor storage conditions are the mortal enemies of tapes. Store the in a 'played
Feb 26, 2011 | JVC DR-MV5S DVD Recorder/VCR
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
LG RC195 dvd/vhs combo
Do you just get a snowy screen when you playback? I think the first thing to try is to clean the video heads. Either try a head cleaning tape, but these are not always the best thing, better still is to remove the lid & carefully using a head cleaning fluid (isopropal alcohol) & a thin piece of card or head cleaning stick (NOT a cloth), carefully & gently wipe the heads which are on the round silver drum. Do not use too much pressure or you will damage the heads, give it time to dry (couple of minutes) & then try playback.
Jul 20, 2009 | LG Televison & Video
After recording a program using the Toshiba W522, the picture rolls and jumps up and down, while in playback mode. I have no problem with recording, its just when its time to actually watch the program,...
If the tapes are old or cheap, they may simply be no good. However, I found that the automatic tracking is the best thing to ensure perfect quality picture and sound.
Jun 22, 2009 | Toshiba W522 VHS VCR
SLOW DOWN PLAYBACK MODE
You cannot play SVHS tapes on a standard VHS machine. Your solution is to either:
1. Buy an SVHS Home unit (not a great idea)
2. Use regular VHSC tapes in your camcorder (these will playback fine in your existing home unit).
3. Hook your camcorder directly into your TV and use the camera as a playback device.
May 02, 2009 | Televison & Video
Poor playback
Because the cable signal is OK, this eliminates the tuner as your problem and leaves the power supply which is a common problem. It is a switch mode type which often have trouble maintaining control of its output voltages and produce trouble downstream in the video circuitry. Either the power supply is failing which can be wholesale replaced for about a $150, or something somewhere else is failing and loading down the supply causing it to overwork. Usually in this case, you can hear a whine noise if you listen close.
Dec 28, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
VCR recording
As with all tape related recording equiptment, the path the tape follows in your machine will collect debris which will interfere with the synchronizing playback signals originally recorded on our tape when first recorded. The "ROLLING" is the loss of those synchronizing signals and the "skewing" of the tape where the heads are now reading between the recorded information causing noise at the top or bottom or throughout the entire screen. SOLUTION for about 85% of machines exhibiting this problem is CLEANING and inspection of tape path alignment best done with a calibrated playback tape for accuracy. HOPE this helps . . . Jaszy
May 29, 2007 | Maxell 10 Pack T60 Blank VHS Tape PI PLUS...
Toshiba RD-XS25 DVD Recorder/HDD Recorder Logo
395 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
