Question about Dell Latitude C400 Notebook
Unable to see what screen resolution I have
I don't know how to see what it actually is; a program tells me that I do not have enough resolution for that program (a digital camera utility). I have Vista on my machine. sob.
  • Dell Master
  • 2,404 Answers
Go into the control panel and then click on personalization. From there click on Display Settings and it will tell you what you have your screen resolution set at.
Posted on Jul 15, 2009
Suddenly my screen resolution got huge. how do i go back?
Go: Start -- Control Panel -- Display -- Settings -- To the upper left it says Screen Resolution. Adjust this upward and click "Apply". You may have to toy with it a few times to figure out which one it is actually supposed to be on. But don't worry, there is nothing there where you could mess anything up - after all...its already messed up. :-)
Anyway, if memory serves, going up gives you finer resolution, which makes things smaller. If you get there and its already all the way up, over toward your right, then my memory is backwards.....so just take it the other way.
And look at this as a blessing. You'll know more about your computer than you did. And - its a useful thing to know because if you ever plug your computer into a larger screen (like your TV), you will need to make adjustments here at this screen.
If this is helpful to you, please take a sec to rate me. Thanks!
Don
Mar 24, 2012 | Acer Computers & Internet
Hdmi from laptop to tv small picture no sound
First the picture size is probably related to the screen resolution or aspect ratio. In Windows 7, you can adjust the resolution by right clicking on the desktop and choosing Screen Resolution. Make sure you do not exceed the limits of the video graphics output of the laptop or the refresh and resolution of the TV. (Without knowing your hardware, I can't tell you the actual settings you should use.) Usually HD TVs are either 720p or 1080i. Alternatively, check if you can change the zoom or aspect ratio (4:3, 16:9) on the TV. Those settings may fill your screen. (It could expand the image past the viewable edges of the TV or distort your image though.)
For the audio, you should check the Sound outputs. Again in Windows 7, click Start > Control Panel > Hardware and Sound > Manage Audio Devices. Under Playback, see if you have an option for HDMI sound. If you don't have this option, you will need to connect an audio cable between your computer and TV. (If the TV has a VGA input with a PC audio jack, use a 3.5 mm audio patch cable. Otherwise, you'll need a 3.5 mm to RCA audio adapter or cable.) Make sure that the audio isn't muted.
If you have a different OS, the specific commands will be slightly different but similar in Windows.
I hope this helps.
Oct 18, 2011 | Televison & Video
Can I install windows 8 on samsung n150 netbook?
I install windows 8 in my samsung n150 netbook , but there are some small problems , one of these problems you can't use the metro ! because all program in metro requires a big screen resolution . But this types don't support that . If you find any solve for this problem please tell me .
Sep 24, 2011 | Samsung N150 Notebook
Every time i try to go on my webcam it tells me that the hp media smart webcam does not support a screen resolution smaller then 1024 by 768?
I've had problems using a widescreen monitor with certain programs/devices when my horizontal resolution is set high enough (for example: 1024), but my vertical resolution is too low (for example: 700). This may be your problem check the display settings and increase if necessary.
Hope this helps you.
Thanks,
Steve G.
Nov 02, 2010 | HP w2558hc 25.5" Widescreen LCD Monitor
How to enlarge a picture that is scanned or copied? When i scan or copy a picture it is too small and I want to enlarge it in order to view it better.
hi
Open an image. Go to the Image Menu and select Image Size. This is where you can change an image’s resolution and print size (width and height). The following Image Size dialog box will appear:
Notethat the width and the height of the image as you view it on yourmonitor is not necessarily representative of the image’s actual widthand height—i.e., the size it would print out at (print size).Average monitor resolution is 72 dpi. If you view a 72 dpi image at100% in Photoshop, chances are that it will appear on your screen inits actual print size. However, this is not true when viewing a 300 dpiimage. A 300 dpi image viewed on-screen at 100% will be enormous. Don’tget tricked into believing that what you see on your monitor is whatyou’ll get when you print or place the image into another application.The best way to determine what your image’s actual print size will beis through the Image Size dialog box.
When the Resample Imagebox is checked, any changes you make to an image’s width or height willnot change the image’s resolution, and as such, any changes you make toan image’s resolution will not affect the image’s width and height.Keep in mind, however, when you increase width and height, orresolution, with the Resample Image box checked, you are adding pixelsto your image. These pixels don’t actually exist so Photoshop mustcreate them. As such, you will succeed only in degrading the quality ofyour image.
If you want to increase an image’swidth and height, or resolution, then uncheck the Resample Image box.Now any changes you make to the image’s width and height will changethe image’s resolution, and vice versa:
  • If you decrease resolution, the width and height will increase.
  • If you increase resolution, the width and height will decrease.
  • If you increase the width or height, the resolution will decrease.
  • If you decrease the width or height, the resolution will increase.
Thebest way to increase the width and height of a scanned image is to scanthe image in at a high resolution (about twice what your finalresolution should be), and with the Resample Image box unchecked, decrease the resolution. Once the image width and height is where you want it, you can then check the Resample Imagebox and type in the resolution you want if the resolution is too high.At this point, as long as you don’t increase resolution, or width andheight, your image quality will not suffer.
Aug 07, 2010 | HP Officejet 5610 All-In-One InkJet...
Unable to transmit my image
You really aren't telling us a lot of information. If you can get a picture onto the notebook then it's got to be stored somewhere. Try taking the picture, then saving it. Now you can use e-mail to send the picture as an attachment.
Feb 10, 2010 | Acer Aspire 3610 Notebook
Wallpaper only, no icons or programs available for use or viewing
Have you already done a vista repair on this unit.Do you get the same result in safemode
May 06, 2009 | Computers & Internet
Fullscreening problem
try up dating you video driver. you may not have enough video memory avalible try going to system properties under the advanced tab click dettings in the performance box then click the radio button fro best performance. your desktop colors and display will be very basic but then try to loading the same program. if that doesent work try reinsatlling that program again make sure that your computer meets the requirements. also make sure that you have enough ram also.
Mar 26, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Dell Latitude C400 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
