Question about Pride New Mobility Legend 4 Wheel Scooter
I HAVE JUST PURCHASED A 3 WHEELER MODEL PRIDE
(1) I HAVE JUST PURCHASED A 3 WHEELER MODEL PRIDE SC3000 (USED) ITS SOUNDS TOO NOISY AT THE REAR, IS IT THE AXLE OR ANTI TIP WHEEL,? WOULD SOME OIL OR GREASE HELP, (2) HOW DO I KNOW THE BATTERIES ARE STILL GOOD ?
(3) HOW DO I GET TO ORDER A REAR VIEW MIRROR, AND HOW MUCH DOES IT COST? THANKS ...........ISSA
I need new replacement rear wheel hubs for my Pride Wrangler as they are wearing and moving and keep knocking the nuts, where can I obtain new wheel hubs! Bearing in mind I'm in the UK.
Posted on Nov 02, 2012
    Problem Solver:
  • 6 Answers
I doubt the transaxle needs grease, all these mobility scooters have bomb-proof sealed transaxles/differentials which are greased for life.
The motor is the obvious candidate, or something rubbing on the tyre? Perhaps the motor brushes are worn, damaged. Or perhaps it is noisier than you expect? An engineer whose worked with scooters before is your best bet I think.
The best way to judge the battery is see how much range you have after a full charge (but only if you know the motor is good!) Though this experiment could leave you stranded.
Push bike and motorcycle mirrors might be a low cost solution?
Posted on Sep 09, 2009
  • 130 Answers
AXLE NEEDS GREASE!!!! DO NOT RUN IT !!! WITHOUT IT,THE PLACE U BOUGHT SHOULD HAVE BUT WERE PROBABLY BEIN LAZY
Posted on Jul 15, 2009
How can I correct the steering on my pride victory 3 wheeler?
lift dust boot on the bottom section of the yoke below the fiberglas covers and the yoke tilt adjustment, the adjustments are located at this nifty hiding place
Aug 25, 2014 | Pride Mobility Victory 3 Wheel Electric...
How do I oil the freewheel mechanism located on the trans-axle
hi, is it noisy ? , i don't advise you doing that , they get noisy as they wear but in most cases they do not need to be open up , it';s tricky and i advise you to let someone who skilled in that to do so...
Regards
Rob
www.gewizrepairs.co.uk
Feb 23, 2014 | Pride Mobility Products GoGo Elite...
Gogo 4weeler clicking niose going up hills
check the duudrff keys used to hold he wheels in line with the axle. i had a clickin nosie inm y three wheeler and it took several trips to the shop and 4 different motorsbefore we discovered the keys where too thin.
Oct 28, 2012 | Pride Go-Go Elite Traveller Plus HD...
How to install rear struts on a 1999 llexus
Lexus Car ES, IS, LS 1998-06
Coil Spring Rear Suspension
Print
Hub & Bearings
Adjustment
Check the backlash in bearing shaft direction and the axle hub deviation. Maximum for backlash should be 0.0020 in. (0.05mm) and for axle hub deviation 0.020 in. (0.05mm).
Fig. Checking wheel bearings for excessive play
NOTE The rear wheel bearings are non-adjustable. If the wheel bearing is out of specifications, replace the wheel bearing.
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Raise and safely support the vehicle.
  3. Remove or disconnect the following:
    Rear tire and wheel assembly Rear stabilizer link Rear axle shaft nut Rear disc brake caliper and disc Speed sensor Parking brake assembly at the wheel hub No. 1 and 2 upper control arm assembly No. 1 and 2 rear suspension arm assembly Toe control link Rear axle from hub assembly using a plastic hammer No. 2 rear wheel bearing dust deflector using a screwdriver 4 bolts and rear axle hub and bearing assembly from the axle carrier assembly
To install:
  1. Install or connect the following:
    Hub on the carrier and tighten the bolts to 52 ft. lbs. (70 Nm) No. 2 rear wheel bearing dust deflector using a screwdriver Rear axle into hub assembly No. 1 and 2 upper control arm assembly. Torque the new nut to the No. 2 rear upper control arm to 52 ft. lbs. (70 Nm). Temporarily tighten the No. 1 arm bolt. No. 1 and 2 rear suspension arm assembly. Temporarily tighten. Toe control link. Torque new nut to 52 ft. lbs. (70 Nm). Rear stabilizer link. Torque to 20 ft. lbs. (27 Nm). Parking brake assembly at the wheel hub Rear speed sensor Rear axle shaft nut. Torque to 214 ft. Lbs. (290 Nm) and stake the nut with a chisel and hammer. Rear brake disc and disc brake caliper
  2. Adjust the parking brake.
  3. Stabilize the suspension as follows :
    1. Install the wheel(s).
    2. Lower the vehicle and bounce it up and down several times to stabilize the rear suspension.
    3. Raise the vehicle.
    4. Remove the wheel.
    5. Jack up the rear lower suspension armplacing a wood block in between. Apply a load to the suspension so that the lower suspension arm is plkaced in a horizontal position.
  4. Fully tighten the No. 1 rear upper control arm assembly to 119 ft. lbs. (161 Nm).
  5. Fully tighten the No. 1 rear suspension arm assembly to 70 ft. lbs. (95 Nm).
  6. Fully tighten the No. 2 rear suspension arm assembly to 119 ft. lbs. (161 Nm).
    NOTE If it is necessary to replace the hub or bearing, replace the components as an assembly.
    Rear tire and wheel assembly If equipped with rear disc brakes, the caliper mounting bolts. Leave the brake line connected and suspend the assembly out of the way. Brake rotor or drum 4 bolts and pull off the rear axle hub O-ring
To install:
    Hub on the carrier and tighten the bolts to 59 ft. lbs. (80 Nm) Rotor or drum Caliper, f equipped with rear disc brakes and tighten the bolts to 34 ft. lbs. (64 Nm) Wheel
  2. If equipped with air suspension, move the height control switch in the trunk area to the OFF position.
    Negative battery cable Rear wheel(s) Height control sensor link from the lower control arm Anti-lock Brake System (ABS) speed sensor and wiring harness Brake caliper bracket from the rear axle carrier by removing the 2 bolts. Support the caliper with a piece of wire. Brake rotor Parking brake shoes and cable Cotter pin, lock cap and the nut holding the halfshaft to the rear axle Suspension member brace by removing the 2 bolts Halfshaft bolts and washers Halfshaft from the vehicle Strut rod
  4. Place matchmarks on the adjusting cam and body for the No. 1 control arm.
  5. Remove or disconnect the following:
    Nut and adjusting cam Nut on the axle carrier side of the No. 1 lower control arm Separate the control arm from the axle carrier No. 1 lower control arm Stabilizer bar link from the No. 2 lower control arm.
  6. Place matchmarks on the adjusting cam and body.
  7. Remove or disconnect the following:
    Nut and adjusting cam from the No. 2 lower control arm Nut and bolt holding the No. 2 lower control arm to the axle carrier No. 2 control arm from the vehicle Nut and bolt on the lower side of the strut assembly 2 upper control arm set nuts and bolts Axle carrier with the upper control arm
  8. Secure the axle carrier in a vise.
  9. Remove or disconnect the following:
    Nut holding the upper control arm to the axle carrier and remove the control arm Dust deflector. Use a suitable prytool. Oil seal
    Fig. Removing the oil seal (inner)-LS 430
  10. Remove the 2 bolts and nuts and shift the backing the plate towards the hub side (outside).
  11. Remove or disconnect the following:
    Axle hub
    Fig. Removing the axle hub from the axle carrier-LS 430
    Backing plate. Inner race (outside) from the axle hub
    Fig. Removing the inner race (outside) from the axle hub-LS 430
    Oil seal (outer) from the axle
    Fig. Removing the oil seal (outer)-LS 430
    Snapring from inside the axle housing Bearing from the axle housing
To install:
    New bearing to the axle housing Snapring to the axle carrier, using snapring pliers New outer oil seal. Coat the oil seal lip with multipurpose grease.
    Fig. Installing the oil seal (outer)-LS 430
    Backing plate to the axle housing. Do NOT install the bolts or nuts at this time. Inner race (inside) to the axle housing Axle hub to the axle housing Backing plate in position. Tighten the bolts and nuts to 43 ft. lbs. (59 Nm). New oil seal (inner) to the axle housing. Coat the oil seal lip with multipurpose grease.
    Fig. Installing the oil seal (inner)-LS 430
    New dust deflector. Be sure to align the hose for the ABS speed sensor in the dust deflector and axle carrier. Upper control arm to the axle carrier by installing the nut. Tighten the nut to 80 ft. lbs. (108 Nm). Axle carrier and upper control arm to the vehicle as an assembly 2 upper control arm set bolts and tighten the bolts to 121 ft. lbs. (164 Nm) Bolt and nut holding the strut to the axle carrier. Tighten to 101 ft. lbs. (137 Nm). Bolt and nut connecting the No. 2 lower control arm to the axle carrier. Tighten the bolt to 60 ft. lbs. (81 Nm). Nut and adjusting cam to hold the No. 2 lower control arm to the body. Align the adjusting cam marks and tighten the nut to 57 ft. lbs. (78 Nm). Stabilizer bar link to the No. 2 lower control arm and tighten the nut to 48 ft. lbs. (65 Nm) No. 1 lower control arm to the axle carrier and body. Install the nut to hold the No. 1 lower control arm to the axle carrier. Tighten the nut to 43 ft. lbs. (59 Nm). Nut and adjusting cam to hold the No. 1 lower control arm to the body. Align the matchmarks and tighten the nut to 57 ft. lbs. (78 Nm). Strut rod to the axle carrier and body. Install the bolt and nut to hold the strut rod to the body. Tighten to 57 ft. lbs. (78 Nm). Bolt and nut to hold the strut rod to the axle carrier. Tighten to 136 ft. lbs. (184 Nm) Parking brake shoes and cable Outboard joint side of the halfshaft and align the matchmarks on the side gear shaft and the halfshaft. Coat the threads with clean oil and install the hexagon bolts. Tighten bolts to 61 ft. lbs. (83 Nm). Suspension member brace with the 2 bolts. Tighten the 2 bolts to 37 ft. lbs. (50 Nm). Nut to hold the halfshaft to the rear axle. Tighten the nut to 213 ft. lbs. (289 Nm). Lock cap and cotter pin Brake disc to the axle hub with the matchmarks aligned. Install the 2 screws and tighten the screws to 48 inch lbs. (5 Nm). Brake caliper to the vehicle and install the 2 bolts. Tighten the bolts to 77 ft. lbs. (104 Nm). ABS speed sensor and wiring harness Height control sensor link with the matchmarks aligned. Tighten the nut to 48 inch lbs. (5 Nm). Rear wheel(s) Negative battery cable
  2. Lower the vehicle and turn ON the air suspension switch.
Fig. Exploded view rear carrier assembly, hub and bearing-
  2. Remove or disconnect the following:
    WARNING Be careful not to damage the boot and ABS sensor
    Rear wheel(s) Height control sensor link from the lower control arm Anti-lock Brake System (ABS) speed sensor and wiring harness Brake caliper bracket from the rear axle carrier by removing the 2 bolts. Support the caliper with a piece of wire. Brake rotor Parking brake shoes and cable Toe control link Separate upper control arm assembly Shock absorber from axle carrier Suspension arms No 1 and 2 from axle carrier Rear axle from carrier
    Wheel bearing dust deflector 4 bolts and axle & bearing hub assembly
To install:
    4 bolts and axle & bearing assembly. Tighten to 48 ft. lbs (65 Nm) Rear wheel bearing dust deflector Rear drive axle Upper control arm. Temporarily tighten No 2 and No 1 suspension arms. Tighten to 52 ft. lbs. (70 Nm) Shock absorber. Temporarily tighten Toe control link. Tighten to 37 ft. lbs. (50 Nm) Fully tighten upper control arm. Tighten to 52 ft. lbs. (70 Nm) Height control sensor Parking brake shoes and cable Speed sensor Rear disc brake caliper Fully tighten shock with new nut to 52 ft. lbs. (70 Nm) Rear tire
  2. Inspect and adjust rear wheel alignment
  3. Check ABS speed sensor signal
    Rear wheel Wheel speed sensor Axle halfshaft Brake caliper and rotor Parking brake shoes Parking brake cable No. 1 lower suspension arm bolt No. 2 lower suspension arm bolt Toe control link Upper ball joint Axle carrier from the vehicle
  3. Press the hub out of the wheel bearing, then remove the backing plate.
  4. Remove the snapring, then press the wheel bearing out of the axle carrier.
To install:
NOTE Use a new toe control link nut for assembly.
  1. Installation is the reverse of the removal procedure, while using the following torque values:
    Backing plate bolts: 43 ft. lbs. (59 Nm) No. 1 lower suspension arm bolt: 55 ft. lbs. (75 Nm) No. 2 lower suspension arm bolt: 81 ft. lbs. (110 Nm) Toe control link nut: 36 ft. lbs. (49 Nm) Upper ball joint nut: 80 ft. lbs. (108 Nm) Brake caliper support bolts: 77 ft. lbs. (104 Nm) Rear wheel lug nuts: 76 ft. lbs. (103 Nm)
Fig. Exploded view rear Axle carrier and hub assembly-ES 330
    Rear tire and wheel assembly Brake caliper support bracket Brake rotor Skid control sensor wire 4 bolts and rear hub and bearing assembly Skid control sensor
To install:
    NOTE Inspect bearing back lash and hub deviation
    Skid control sensor Rear axle hub and bearing assembly with 4 bolts. Tighten to 59 ft. lbs. (80 Nm) Skid control sensor wire
    Rear disc Rear disc brake caliper assembly. Tighten to 46 ft. lbs (62 Nm) Flexible brake hose Rear tire and wheel
  2. inspect and adjust rear wheel alignment
Stabilizer Bar
  1. Remove the rear wheels.
  2. Remove the 2 nuts and left stabilizer bar link. If the ball joint turns together with the nut, use a hexagon wrench (5 mm) to hold the stud. Repeat for the right side.
  3. Remove the 8 bolts, 2 No. 1 brackets and 2 bushings. Two types of bolts are used, so make sure the correct bolts are installed.
  4. Remove the stabilizer bar.
To install:
  1. Install the stabilizer bar.
  2. Install the bushing and bracket with the 2 bolts and tighten to 14 ft. lbs. (19 Nm). Install the bushing to the inner side of the bushing stopper on the stabilizer bar.
  3. Connect the stabilizer bar links and tighten the nuts to 29 ft. lbs. (39 Nm). Repeat for the right side.
  4. Install the rear wheels.
  5. Inspect and adjust rear wheel alignment.
Strut & Coil Spring
    CAUTION Do NOT remove the center nut to the strut at this time. The spring on the strut is under high pressure and can cause serious injury.
    No. 2 luggage compartment trim cover Left and right deck side trim box Rear luggage compartment trim cover Front luggage compartment trim cover Left and right side luggage compartment trim covers Rear wheel Rear wheel fender liner No. 2 differential support protector Rear suspension member brace Rear No. 2 lower control arm Mounting bolts and strut assembly
  3. Secure the strut in a vise.
  4. Compress the coil spring
    Upper strut retaining nut Suspension support Upper insulator Bumper Coil spring Insulator
Dec 26, 2011 | 1999 Lexus ES 300
My dad has a pride celebrity xl scooter and keeps getting a noise similar to a rubbing noise from rear right wheel while driving, it sounds once for every rotation of the wheel, iv checked that nothing is...
The noise you are describing usually comes from the trans-axle and not from the motor/brake. Motor brake noise is usually continuous. Sounds like the trans-axle may be slightly bent on the right or rubbing internally. The easiest way to identify this is to block up the scooter and remove the rear cover. Look and listen to all the drivetrain components while the scooter is blocked up and running. If you hear rubbing at the end shaft as you describe you can try the following:
Loosen the trans-axle metal mounts that clamp the rubber sleeves over the trans-axle
Spray the rubber sleeves with silicone.
Re-torque the clamps after checking the alignment.
An overtightened or misaligned clamp can sometimes cause noise.
The brake/motor/transaxle has a prorated three year warranty so you should go through a Pride dealer for warranty repairs.
Sometimes you can get a noisy wheel on the key and key-way of the trans-axle shaft. It may be worthwhile to pull both rear wheels lubricate the shaft key-ways and keys and re-install the wheels. This can sometimes quiet a multitude of noises from the trans-axle. Depending on the age of the scooter you can do nothing, replace the brake/motor/transaxle parts individually, replace the complete assembly. I like to replace the entire assembly under warranty so there are no future problems. The rest of the repair depends on your insurance coverage or budget. Hope this helps.
Nov 30, 2010 | Pride Celebrity Xl 4 Wheel Scooter
My scooter is making loud clicking sounds as though something has come loose & hitting something in the rear wheels as it goes around. The repair tech rotated the rear tires last week & this helped...
Its quite common for Pride scooters to be assembled using little or no grease on the rear axle. If the noise is like a stone stuck in the tyre, its probably a 'Dry Axle' as mentioned above. Try just removing the rear wheel(s) and greasing the axle. This normally cures the problem. When removing the wheel, be careful not to lose the hub key which slots into the axle and wheel to stop the wheel spinning freely on the axle. Hope this helps.
Jun 29, 2010 | Pride Go Go Elite Traveller Plus HD 4...
I received my Pride Revo 3 on Friday and noticed a clicking noise to the rear of the scooter (sounds like it's around the right wheel arch). It's a sound which happens in motion and is quite...
Is it a fast clicking or does it sound like a stone in the tyre? If its the latter, it will just be a dry axle. Remove the wheel (be careful not to lose the hub key!), put grease on the axle and replace the wheel again. This should solve the problem. If its the former, it is normal for this noise to occur but its not usually very load and can sometimes be curred by removing the brake from the motor and 'Re-Seating' it. Either way, it should be nothing to be too cercerned about.
Feb 15, 2010 | Pride Value Line Revo Scooter 3 Wheel
How do you remove right rear axle on a 2004 ford crown vic to replace seal on wheel?
Section 05-02A: Axle, Integral Carrier — 8.8-Inch Ring Gear 1994 Town Car, Crown Victoria/Grand Marquis. Workshop Manual REMOVAL AND INSTALLATION Axle Shaft NOTE: Whenever replacing the rear axle lubricant, use Rear Axle Lubricant XY-90-QL (ESP-M2C154-A) or equivalent.
Removal
sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The rear brake anti-lock sensor must be removed before the axle shafts are removed. The rear brake anti-lock sensor is bolted on the rear disc brake caliper anchor plate.
  1. Raise vehicle to desired working height. Refer to Section 00-02 . Remove rear wheel (1007) and tire assembly. Remove rear disc brake calipers (2552) and rear disc brake rotors (2C026) .
  1. Clean all dirt from area of axle housing cover with a wire brush and/or cloth.
  1. Drain rear axle lubricant by removing the axle housing cover .
  1. Remove differential pinion shaft lock pin and differential pinion shaft .
  1. Push flanged end of the axle shafts toward the center of the vehicle and remove the rear axle shaft retaining u-washer from the button end of the axle shaft .
  1. Remove axle shaft from the rear axle housing , being careful not to damage the inner wheel bearing oil seal (1177) and rear brake anti-lock sensor ring.
Installation
NOTE: Check for presence of rear axle shaft o-ring (4A332) on the spline end of the shaft and install if not present.
sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Care must be taken not to let axle shaft splines damage oil seal or bearing assembly.
  1. Carefully slide axle shaft into rear axle housing without damaging rear wheel bearing (1225) or rear brake anti-lock sensor indicator (2C189) . Start splines into side gear and push firmly until the button end of axle shaft can be seen in the differential case .
  1. Install the rear axle shaft retaining u-washer on the button end of the axle shaft splines, then pull the shaft outboard until the shaft splines engage and the rear axle shaft retaining u-washer seats in the counterbore of the differential side gear .
  1. Position the differential pinion shaft through the differential case and differential pinion gears , aligning the hole in the differential pinion shaft with the lock bolt hole. Apply Rear Axle Lubricant to differential pinion shaft lock pin . Install differential pinion shaft lock pin and tighten to 20-41 Nm (15-30 lb-ft). sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Differential pinion shaft lock pin must be tightened to specification using Stud and Bearing Mount E0AZ-19554-BA (WSK-M2G349-A1) or equivalent.
    NOTE: Axle housing cover must be installed within 15 minutes of application of the silicone rubber or new silicone rubber must be applied.
    sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Make sure machined surfaces on both axle housing cover and rear axle housing are clean before installing the new silicone sealant. Inside of axle must be covered when cleaning the machined surface to prevent axle contamination. Tighten the cover bolts in a crosswise pattern to ensure uniform draw on axle housing cover .
  1. Apply Silicone Rubber D6AZ-19562-AA or BA (ESB-M4G92-A or ESE-M4G195-A) or equivalent. Install axle housing cover and tighten retaining bolts to 28-38 Nm (38-52 lb-ft).
  1. Add Motorcraft Rear Axle Lubricant XY-90-QL or KL (ESP-M2C154-A) or equivalent until it is 6-14mm (1/4-9/16 inch) below bottom of fill hole. Add 118.3 mL (4 oz) of Ford Additive Friction Modifier C8AZ-19B546-A (EST-M2C118-A) or equivalent to Traction-Lok axles. Install fill plug and tighten to 20-41 Nm (15-30 lb-ft).
  1. Install rear brake anti-lock sensor indicator . Tighten retaining bolt to 4.5-6.8 Nm (40-60 lb-in).
  1. Install rear disc brake caliper and rear disc brake rotor .
  1. Install wheels and tires.
  1. Insert Rear Bearing Remover T85L-1225-AH in bore and position it behind bearing so tangs on tool engage bearing outer race. Remove rear wheel bearing and inner wheel bearing oil seal as a unit, using Impact Slide Hammer T50T-100-A.
    Rear Disc Brake Caliper Anchor Plate
  1. Lubricate the rear wheel bearing with Rear Axle Lubricant.
  1. Install rear wheel bearing into the housing bore using Axle Tube Bearing Replacer T78P-1225-A.
    sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Installation of rear wheel bearing or inner wheel bearing oil seal assembly without proper tool may result in an early bearing or seal failure. If inner wheel bearing oil seal becomes cocked in bore during installation, remove it and install a new one.
  1. Install the inner wheel bearing oil seal using Axle Tube Seal Replacer T78P-1177-A. Use Premium Long-Life Grease XG-1-C or K (ESA-M1C75-B) or equivalent between the lips of the inner wheel bearing oil seal .
  1. Install axle shafts as outlined.
May 13, 2009 | 2004 Ford Crown Victoria
Rear wheel bearing
SECTION 205-02B: Rear Drive Axle/Differential — Ford 8.8-Inch Ring Gear 2003 Mustang Workshop Manual IN-VEHICLE REPAIR Axle Shaft Removal
  1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
  1. Remove the rear brake disc (2C026). For additional information, refer to Section 206-04 .
  1. Remove the differential housing cover (4033) and drain the lubricant. For additional information, refer to Differential Housing Cover in this section.
  1. Remove the differential pinion shaft (4211).
    1. Remove the differential pinion shaft lock bolt (4241).
    1. Remove the differential pinion shaft.
  1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-ring in the axle shaft groove.
    Remove the U-washer (4N237).
    1. Push the axle shafts (4234) inboard.
    1. Remove the U-washer.
  1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Damage to the rear brake anti-lock sensor (2C190) may occur if it is not removed before the axle shaft.
    Carefully remove the rear brake anti-lock sensor. For additional information, refer to Section 206-09A .
  1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the wheel bearing oil seal.
    Remove the axle shaft.
Rear Wheel Bearing and Axle Shaft Oil Seal Removal
  1. Remove the axle shaft (4234). For additional information, refer to Axle Shaft in this section.
  1. NOTE: If the wheel bearing oil seal is leaking, the axle housing vent may be plugged.
    Using the special tools, remove the rear wheel bearing and wheel bearing oil seal.
Installation
  1. Lubricate the new rear wheel bearing with the specified lubricant.
  1. Using the special tools, install the new rear wheel bearing.
  1. Lubricate the lip of the new wheel bearing oil seal.
    • Use Premium Long-Life Grease XG-1-C or equivalent meeting Ford specification ESA-M1C75-B.
  1. Using the special tools, install the new wheel bearing oil seal.
  1. Install the axle shaft. For additional information, refer to Axle Shaft in this section.
Installation
  1. Lubricate the lip of the wheel bearing oil seal
    Install the two axle shafts.
    Install the U-washer.
    1. Position the two U-washers on the button end of the axle shaft.
    1. Pull the axle shaft outward.
  1. NOTE: If a new pinion shaft lock bolt is unavailable, coat the threads with Threadlock and Sealer EOAZ-19554-AA or equivalent meeting Ford specification WSK-M2G351-A5 prior to installation.
    Install the differential pinion shaft.
    1. Align the hole in the differential pinion shaft with the case lock bolt hole.
    1. Install a new differential pinion shaft lock bolt.
  1. Install the differential housing cover and fill the rear axle with the specified lubrication. For additional information, refer to Differential Housing Cover in this section.
  1. Install the rear brake anti-lock sensor. For additional information, refer to Section 206-09A .
  1. Install the rear brakes. For additional information, refer to Section 206-04 .
  1. Install the tire and wheel assembly. For additional information, refer to Section 204-04 .
  1. Lower the vehicle.
Apr 10, 2009 | 2004 Ford GT
Pride New Mobility Legend 4 Wheel Scooter Logo
401 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
