Question about Microsoft Xbox 360 Console
My xbox 360 keeps telling me the disc tray is open even when i have a game in it. ive had this problem before but i moved my console up 3 inches before and it worked and i tried it again but it's not working this time. ive even put a different game in it and it still keeps saying open tray??
  • 130 Answers
IT IS OFF TRACK.JUST BUMB TRAY A LITTLE
Posted on Jul 15, 2009
Hi my xbox 360 keeps telling me to open tray after a disc is inserted. it says reading then it says open tray.
1: Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Hold the disc by the edges without touching the top or bottom surfaces. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward. 2: Try other discs to determine whether the problem happens with any disc or only with this particular disc. If multiple game discs, DVDs, or CDs will not play: Make sure the media type and the disc region code are compatible with the console. 3: If your Xbox 360 console can't play multiple game discs, try clearing your system cache. Here's how: On the console, go to My Xbox, and then select System Settings. Select Memory. Highlight any storage device, and then press Y on your controller.Select Clear System Cache. If you still can't play a game disc, try the next solution. 4: If the solutions above did not resolve your problem, please send Microsoft your Xbox 360 console for repair..
Mar 01, 2011 | Microsoft Xbox 360 Console
I put in a disc into my xbox 360 and i just keeps reading th disc and saying open tray, I open tray, put in disc and close tray, it reads the disk and just repeats message open tray?? Please help
You can do it yourself by opening the xbox 360 case and the dvd rom with a proper tools.. tighten with a screw (counter clock) right there!! (see the picture)
Feb 16, 2011 | Microsoft Xbox 360 Console
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
When i put a game in my xbox 360 it says reading then open tray
I found a solution that works for me after a long period of time with this problem.
Get an air spray canister (just compressed air), open your Xbox's game tray, take the disc out, then spray the air along the tray, moving side to side inside the Xbox. You may want to spray into the vents, too, just to be sure.
This worked for me, and it was the only thing that worked for me. I had already tried hitting the console with the controller (gently), and doing the stuff Microsoft recommends etc.
If that doesn't work, you could try gently knocking the top of the Xbox with your conroller, when you put the disc in, as I've heard that works for some people.
Another thing that works for some people is taking the disc out, closing the tray, then when it goes to Open Tray, open the tray, put the disc back in and then closing the tray again.
Jun 19, 2010 | Microsoft Xbox 360 Console
Everytime i put a disc in my xbox it keeps saying open tray then when i open and close the tray it just says "open tray" again.
Hey, Ive had this problem before, Basicly your disc tray has had it, And it basicly wants to do nothing... Which is very anoying indeed.
Your best bet is to take it to you nearest game store
May 10, 2010 | Microsoft Xbox 360 Console
The xbox 360 elites keeps on saying open tray when trying to play
1, the disc may be dirty
2. the mian reason for this your xbox drive cannot read the disc , because the power of the lens is gone(not completely) ,
solution:
1. keep your disc inside the drive and switch off the console, again swith on try this 2 to 3 time
2. keep the console in vertical position or little slanding position(180 dg) make sure it does not fall
3. its better to buy hatddisc and load the game inside it , so that u lens life increased
4. change the entire drive
Feb 09, 2010 | Microsoft Xbox 360 Console
My xbox 360 doesn't play my games
it could be that u got **** like food in your x box360 open it up and clean it out put it back to gether and try it if this dose not work tell me at alexswierenga@yahoo.com ty
May 29, 2009 | Microsoft Xbox 360 Console
DISC TRAY WONT CLOSE... PLEASE HELP !!!!1
the drive switch is broken try to buy a new one and then it should work coz my dad works in the computer part
Dec 07, 2008 | Microsoft Xbox 360 Console
My xbox 360 will not read game discs. it tells me to open tray when there is a game already inside
have you tried a cleaner for it? i bought one at gamestop for like 10 dollars but ive never used it on the 360. its basically just a cd with brushes on the buttom of it.
Nov 16, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
319 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
