Question about Canon NP 6551 Black and White Copier
Canon 6025 My copir show me this message E001 Press the power swithch to off and then back to on
"E001" Abnormal fuser temp. (thermistor, dc controller, ac driver)
Posted on Nov 18, 2007
I REALLY NEED SOMEBODY TO TELL ME WHATS AN E000 IS
You need to formulate your post into a sentence that makes some sort of sense instead of a cryptic error code. You know something like
"I have a Canon MG7120 al in one printer. I was printing, it stopped printing and the display shows E000. Can you tell me what the error is and how to fix it please"?
WHAT DOES SYSTEM ERROR E000 MEAN? - JustAnswer
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting
  1. Cached
The error is a system fault error that can sometimes be reset: Follow these steps to reset the error: Press Additional Functions key. Press # Press > to #7 Printer Function Press Set Press > to #4 Printer Reset Press Set Press < Unplug printer and repower it. Ask Your Own Printers Question ...
I have an MF4350d. It is showing SYSTEM ERROR E000. What does ...
  1. Cached
I have an MF4350d. It is showing SYSTEM ERROR E000. What does that mean and what do I need to do? Thanks! - Answered by a verified Technician.
Technology Time: Canon Error E000, E001,E002, E003, E007
www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
  1. Cached
  2. Similar
I described in a previous post that E000, E001, E002, E003 and E007 are fixing unit temperature error codes. Lets go into more detail now. .... I have A problem canon 2002 when i power on the machine then show error E002-0000 pls advice me what i do ? ReplyDelete ยท Lizpeth G. ... What's prize of cannon copier E354?
Mar 08, 2018 | Office Equipment & Supplies
How to solve the error of canon iR2016 photocopy system error E003?
How to reset E000, E001, E003, and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" then Press "Stop" or "Additional Function key" to end service mode or restart the machine.
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
Canon IC-MF6530/6550/6560/6580
No reset procedure is required, replacing the fuser is the only repair.
Canon D860 series
Press Additional Function key and the "#" key in that order. Go to Printer (number 7), select "Set", Select "Printer reset" and press "set".
Canon Printer Support Phone Number
Dec 06, 2017 | Canon Office Equipment & Supplies
How to fix the Canon Image Class Printer 4750 error code e001-0000
for more details : www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
Jan 04, 2015 | Canon Office Equipment & Supplies
My canon C3170i shows error E000001-0010
Product : imageRUNNER 5070 / 5570 / 6570 Title : Fuser noise and intermittent E001 code Error
The upper fuser roller section makes a noise and intermittently error code E001 occurs Workaround : In this case, the UFR Shutter inside the upper fuser roller was installed reversed (180 degrees out of postion). Installing the UFR Shutter in the proper orientation corrected the problem. Note: the UFR shutter installed in the reversed position will cause a noise and block the Main Thermistor when the shutter should block the Sub Thermistor. In turn, the shutter will block the Sub Thermistor when the shutter should block the Main thermistor. This will cause improper temperature for the Upper Fuser roller and cause the error code. suggested to go in service mode and reset the error, and see if it will solve the problem. If the problem presist, a code will appear and that will be the one we should work on. So we did clear the error, and the machine is functioning.
Entering service mode: press Additional Function > press 2 & 8 at the same time > press Additional Function again Clearing the Error: press Copier > press Functions > press clear > press Err > press Ok. Restarting the Machine:Power off then On.
Oct 12, 2011 | Canon Office Equipment & Supplies
ERROAR E001 AND E808
u can clear E001 in the service mode Press * 28 * go to clear press OK then err press OK . and the E808 is the cooling fan malfunction .it can be because of the erratic power fluctuations or damaged fan.
and the if E001 happens during copying then u have to check the fusing unit as sometimes the pressure roller bush gets misplaced from original position causing jam and code
Aug 03, 2011 | Canon iR 2016i Black and White Copier
E00001-002 Error cod?
Thanks for using Fixya.
E001 is an Overheating detection error.
E001-002 - The sub thermistor detects about 295 degrees celsius or higher. You would have got E001-000 for a temperature above 250 degrees.
Go into service mode, go to COPIER > FUNCTION > CLEAR > ERR.
Select ERR to highlight, and press OK key.
Turn off the copier using the main power switch (on the right side of copier).
Wait at least 10 seconds and then turn the copier back on using the main power switch.
If the error is still there then you will need to take your printer to a canon service center.
Good luck and have a nice day.
Nov 08, 2010 | Canon (6981A002AA) for imagerunner 2200,...
I have canon ir6570.its shows e001-001,e001-0010 repeatly
try to clesr the err. from service mode ( * 2,8 * ) function - clear- err- press ok
if not ok
you have a problem in the fixing unit
Apr 01, 2010 | Canon IMAGERUNNER 6570 Copier
Aaa
Here ya go:
What you will see
The printer display is not in the required language.
What to do
To change the language on the display back to the required language, do the following:
Steps Action 1 Power the printer off and back on. 2 Press the down arrow button () four times. 3 Press the button once. 4 Press once. 5 Press once. 6 Press once. 7 Press the left arrow button () or right arrow button () until you see the desired language. 8 Press the return button (). 9 Press once to save the new setting
Jun 19, 2009 | Canon NP 6035 Copier
Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
May 17, 2008 | Canon imageRUNNER 1600 Laser Printer
6551 E01
try unplugging it for a few minutes first and see if that helps at all, and let me know and I will further assist you with this problem
Apr 29, 2008 | Canon NP 6650II Copier
Canon NP 6551 Black and White Copier Logo
111 people viewed this question
old marine
old marine
