Question about HP Computers & Internet
How do i get better wireless connection? - HP Computers & Internet
  • HP Master
  • 32,281 Answers
1. Have a look at the signal strength, you can improve it by relocation the wireless router higher and away from solid walls.
2. Move your laptop closer to your wireless router.
3. If there are other wireless routers in your area, have a look at which channel they are broadcasting on and change yours to a different channel so that it doesn't clash with yours.
Posted on Jul 15, 2009
How to speed up bsnl 2g internet in dlink dwm 156?
Try with the following steps to get better internet connection from your wireless router
1.) Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.
Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from www.ScanMySpeed.com before and after following these steps.
Apr 04, 2013 | Computers & Internet
I cannot connect wireless to my HP 3520 printer
Please check your wireless connection? are you sure you are typing the correct username and password for your wireless on your printer. if it is still not working fine then you need to call hp tech support at toll free number- 1-800-585-2494 or visit: HP Customer service . hope this will help you better.
Dec 02, 2012 | HP DeskJet F380 All-In-One Printer
What is access points
An Access point is like a wireless router that allows you to connect to your network with a wireless connection.
This WEB site gives a better definition.
http://compnetworking.about.com/cs/wireless/g/bldef_ap.htm
Jan 28, 2011 | Linksys WRT54G2 Wireless Router
How to add apple McBook to secure network. Changed configuration to secure network and apple laptops cannot connect via wi-fi.
The MAC network card needs configuring with the router's security settings ie. SSID and encryption code etc, otherwise it cannot connect to the router wirelessly.
Sep 19, 2010 | Linksys Wireless-G WRT54G Router
The wireless laptops wont connect at low signal
set the wireless router in better coverage performance instead of better power management in the root menu of the wireless router.(seen in the properties tab)
Oct 18, 2009 | Computers & Internet
I have a wbr-2310 and my connection seems fine, but with a laptop it's completly different. I get disconnected about 10 times per hour. Is it commun from this router?
Its not common for that model but if your connection frop below 10mb to the router over wireless you may want to consider checking if AUTO chanel is enabled or available on that model
If so then enable it.
Also consider moving the router is there are any other wireless devices nearby eg. cordless phone.
It may also be the the windows "zero wireless configuration" service is finding too many other wireless signals nearby.
If that is the case you may want to disable the service and set it to manual. Better still if you have a utility on the laptop (most have) then try set that to control the wireless setting instead of windows.
One of those last two items should help you maintain a better connection but only holds true if you have a reasonable connection to the router to start with.
Aug 21, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
My Linksys Wireless A P only allows one computer to connect
You need to get a router in order to share the Internet connection. The existing Internet connection (from the DSL/cable modem for instance) goes into the WAN port of the router/firewall, then you connect the AP to one of the LAN ports.
Today it is often a better idea to buy a wireless router instead, i.e a router with built-in wireless AP. They are very inexpensive.
May 28, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Airport connection - G5 Powerbook
Yes better get a new wireless card if there's a airport that can be connected via USB that will be better..
Good luck....
Jul 21, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
NETGEAR WG111T 108 MBPS WIRELESS USB 2.0 ADAPTER stopped working
What are you trying to connect your USB wireless device to?
Is it to a wireless hot spot?
or to a Wireless Access Point/Router?
When you find a connection, what is the signal strength?
I assume you have configured your Access Point correctly as well as making it secure. You should connect a computer to the Access Point using a network 10BaseT cable to check the Access Point configuration, especially the wireless configuration.
If you are trying to connect to a wireless Access Point and you have a weak signal, move your computer closer to the Access Point or move the Access Point to a better and higher location to give you a better wireless coverage. Note, walls can affect the wireless signals between the Access Point and the wireless network card and wireless USB device, especially reinforced concrete walls.
Jun 01, 2008 | Computers & Internet
Staying connected
Well, I would try to switch your settings for the enternet. Then i would go to madden into the game and if it does not work. you might need a better connetion.
Oct 26, 2007 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
