Question about Nikon COOLPIX S200 Digital Camera
The night setting results in blurry pictures
1. The night setting results in blurry pictures. The auto setting results in grainy pictures.
The grain is from underxexposure and the blur is from hand shake caused by low shutter speed. Try using a tripod. Also, change from auto settings and shoot in manual mode with a high ISO and low aperture setting. Good luck!
Posted on Jul 15, 2009
  • 285 Answers
Night setting produces quite long shutter times which means it is very difficult to get a sharp photo without using a tripod or keeping the camera dead still.
The auto setting will be setting the ISO up high, which does result in more grainier images, however, it also makes the sensor more sensitive to light, and hence result in a faster shutter speed, which does reduce blur, but the down side is grainier images.
It all sounds quite normal to me.
Night Pictures
make this test .God bless you
When troubleshooting problems with your photographs, you need to be able to distinguish between problems created by the camera and problems created by the, ahem, photographer. Some things, like a finger over half of the shot or a totally out of focus picture of your own feet are not camera malfunctions. Fortunately, most of what appear to be "malfunctions" are things you can correct through settings. Blurry pictures usually result in pressing the shutter button down before the autofocus kicks in; half-tap the shutter to bring the camera into focus then press it all the way down to take a clear shot. Grainy photos are the result of a high ISO value and low light; use a tripod or, if necessary, the flash when taking pictures in low light. Different makes and models have different ways to warn you that the light is low: some display a shaking hand icon, others a red light. Look for this and adjust photo settings.
Nov 08, 2013 | Moultrie Game Spy M-80xt Infrared Camera
I have a Canon Power Shot A720. Outdoor photos are beautiful. Indoor photos are always grainy/blurry...a lot of noise. I have tried the ISP feature but there are only two choices... 1. Auto or 2....
Hi Usually outdoor picture are good within small compact camera. They designed like that. But now your unit just have flash pcb defective. When flash function work, your picture will be good indoor. Regarding your flash unit would be brown fuse or replacement of flash unit. It is 50 and 50 chance. Your local repair shop would charge around $35 to 95 depend on what they really want to charge. Thanks and best regard!
May 24, 2011 | Canon PowerShot A720 IS Digital Camera
Hello! I actually have a TZ3 and have been having problems with the quality of the pictures without using the zoom (grainy) as well as problems with the quality of the picture when using the zoom...
Hello, yes a few suggestions "grainy" could be from an auto ISO setting the sensor speed high as in possibly ISO 400 even 800 or higher you get the pictures but it's grainy. On pocket point and shooters this is most often the case in full automatic modes and on your camera it's called "Intelligent ISO Mode" You should consult your manual and select a more user selectable ISO speed manually. Another feature with your camera is image stabilization this you can turn on or off preferably off when the camera is mounted to a tripod. Okay for the blurry part on the zoom the quickest way to explain this is every tiny movement you make holding the camera is magnified 10 times, this is where the image stabilizing feature would be handy. Jennifer in my younger days I could hold a 35mm camera with a 300mm lens steady at 1/60 of a second now I use only a 200mm lens with image stabilization "on" to get the same results. What you have is a full time auto everything camera if it's working for you it doesn't matter if it's 3.5 years old. You are still working with a 7.2meg camera with a print capability of 11x14. hope this answered some of your questions.
Dec 28, 2010 | Panasonic Lumix DMC-TZ2 Digital Camera
Really Grainy low quality pictures with my new camera.
Try shooting with ISO value of 200 or less; or set to "Auto".
If you're missing the manual, you can get it in English, here. Page 76 briefly discusses ISO settings. This camera can select an ISO as high as 1600. ISO has to do with graininess of film - the higher the number - the more grainy the images. Higher ISOs are selected when light levels are low and no flash is used or is usable (such as when the subject is too distant). Some photographers use higher ISO settings with high shutter speeds to stop fast moving objects (like wheels on a race car). The grainier the film, the quicker it captures light. Fime grained film takes longer to capture light.
Generally, pictures taken outdoors in sunshine look best when ISO is 100 or less. 100 is a good choice for well lit indoor pictures, too; but may be better with an ISO of 200. ISO works like this:
If a picture can be properly exposed with an ISO of 100 in 1/15 sec, it would require only 1/30 sec at ISO 200, or 1/60 sec at ISO 400. When you double the ISO value, the exposure times are halved. What's the big deal about 1/15sec, 1/30 or 1/60 sec you might ask? Easy! the picture will probably be blurry at 1/15 and even 1/30 sec exposure time, due to the camera recording even the slightest movement of your hands. You'll need to supply a tripod or do something else (such as increase the size of the opening of the aperture or f-stop) to get a properly exposed image.
I hope this helped - if it isn't an ISO problem - let me know. Good luck!
Dec 10, 2010 | Canon PowerShot SX30 IS Digital Camera
Blurry pics
Go into the setup menu and scroll to "reset" and follow the on-screen instructions. Sometimes that will restore your camera to original specs.
Oct 07, 2009 | Olympus Stylus 790SW Digital Camera
Grainy pictures...iso problem for olympus stylus 820
Without ISO you will not be able to take pictures.
ISO is the old ASA which is related to film speed
ISO 50 is very slow film speed and may result in blur and some grainy appearance , same as if you PUSHED ISO up to 800 in low light.
Try setting it to ISO 100 and see if that helps.
You can still select auto, but its related to either shutter or aperture priority in relation to the set film speed ( now ISO 100)
Sep 09, 2009 | Olympus Stylus 820 Digital Camera
Grainy pictures at night
Hi
Low light without a flash will always cause grainy pictures unless you have a very high end camera that can shoot at very high ISO speeds like 6400 and up.
Try changing the camera from the green camera 'auto' setting to "P" and then press the Menu button (I think it's Menu) and look for the different mode settings. There should be one for Night or Night Portrait or similar, I can't recall Sony terms and I don't have one here to check sorry.
Your other option is to use the flash, try it with Red Eye turned on if possible.
Hope this helps.
Thomas D.
Owner, Darntoothysam com
Nov 03, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Very grainy pictures indoors at night
If you can adjust the ISO sensitivity to a lower number then the graininess will be reduced.
However, by reducing the ISO, you will need a slower shutter speed and a larger aperture. A tripod, table or other support may be necessary.
The "noise reduction" setting on the camera can also be adjusted a step up.
Taking pictures at full resolution and fine compression will also help.
Overall, at least try lowering the ISO, and using the flash brighter.
Jul 01, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Blurry still pictures
I had the same problem and found this forum.  In Camera mode, I went to the night/program light button and somehow entered a circular menu shown on the screen ... chose sports shots - and boom!  back on to focused pictures.  Hallelujah.
Jul 04, 2007 | JVC Everio GZ-MG130 Camcorder
Blurry pics indoors
1. you could try it with flash, but the lighting in the picture would look artificial, won?t reflect the interior of the building as it really is, and the flash will cover only near objects leaving the rest dark, and we?ll be missing the point. 2. recommended ? place the camera on a stable platform(table, chair, shelf etc in lack of a tripod), adjust its vertical angle by placing some flat object under the front side of the camera, set it to auto or a preference to slow shutter speed(usually 1/60 to 0.5 of a sec according to the lighting), set timer(most cameras only give you about 2 seconds) in order to avoid vibrations during the picture taking. 3. you should avoid using more then 50 to 100 ISO, more will give you a grainy effect. You are promised a sharp picture with life like colors that looks real.
Feb 21, 2006 | MitekMedia CD30P3 Digital Camera
Nikon COOLPIX S200 Digital Camera Logo
366 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
