How to install a 2008 chevrolet uplander van a/c compressor kit
Michael, this job requires special tools. You need to recover the refrigerant. But your big issue will be removing all of the moisture from the system, after the compressor surgery.
System oil is another major concern. As per directions, measure that you remove from the compressor. Adjust accordingly. Meaning for example, (Random values, check specs for your system) if you were to have 4 oz of oil in the compressor, but you find only 3 oz (measured!), you are not down 1 oz. The entire system is 25% low on oil. Adjust accordingly. No biggie, but if you are not aware of these things, you will introduce moisture into your system, which will react negatively with the metal parts of the system, causing costly damage.
Always replace the receiver/dryer when you open an A/C system.
(it has oil in it, too...)
Really, dollars and cents, this job might want to be done by a trained professional.
Discharge of refrigerant is ******* most everywhere.
Doc
