After my a/c has been running for awhile, ice will build up where the filter is
    Champion:
  • 233 Answers
The only things that will cause a coil to ice are airflow problems or an undercharge of refrigerant if the filter and the blower assembly are clean and the blower is operating correctly, the leak must be found repaired and the system recharged to correct capacity
Posted on Jul 15, 2009
Ice maker leaks on floor when I turn on after awhile
Hello:
is the water coming from the ice maker for sure?
It could be that you may have clogged defrost drain line and the water has no where else to go but the bottom of freezer..Defrost happens roughly every 8 hr or so...
Jul 11, 2017 | GE Refrigerators
When set in smart mode it runs continuously and the core ices up this results in the filter not being able to be removed. water then runs all over the floor. This also happens in normal mode Very li
Ice builds up for two basic reasons:
  1. Impeded air flow. This causes the dehumidifier to run constantly as the humistat never reaches it setpoint as there is limited or no airflow over the coils. Even with a filter, the cooling coils can become clogged and render airflow restricted or non-existent. Check and correct as necessary.
  2. A low refrigerant charge. Systems can leak over time and become low on charge. This causes extended period of running and the resultant freeze-up. If the coils and filter are clean, have the system checked for proper charge of refrigerant.
Jan 02, 2015 | Dehumidifiers
The washing machine smells like rotten eggs on the rinse cycle. The clothes also smell afterwards as well. What can I do to resolve this?
Rotten egg stench is caused by sulphur content in the water or building up over time in your water heater. It can also build in a water system that is rarely run. Have you noticed this smell from other taps in your house? There are inline charcoal filters that can remove it from the water, or you can also try removing the water lines from the washer and running them awhile.
Is this new, or has it been happening for awhile?
Dec 04, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Unit iceing uo
Dehumidifiers freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
May 04, 2010 | Kenmore 54501 Dehumidifier
Hello--toy will start and run fine for awhile and
I would do a visual inspection around the top of the engine for vacuum lines that look deteriorated of broken. Also check the hose from the air cleaner box where it conects to the motor. Had one recently where the underside of it was cracked and air coming in there is after sensors and makes the car too lean robbing power and making idle rough. If this helps please reply and good luck
Apr 27, 2010 | 1995 Toyota Camry
Ice maker wont fill.water dispenser on door is working
Could be the filter. Can you bypass the filter? How about the incoming water line. Is there presure there?
Aug 26, 2009 | Frigidaire FRS26R4A Side by Side...
Ice forming on inside of unit air not cold
clean the filters and check the drain, to clear the drain run a jug of warm water down the pipe
Aug 19, 2009 | Dometic Rooftop RV Air Conditioner
Why does the filter in the back ice over after awhile of running
ice is a result of low refrigerant charge or lack of airflow across the coil
Jul 30, 2009 | Dehumidifiers
Area around freezer door is very hot to the touch. ice maker works, but after awhile the ice will melt. freezer is freezing.
HI, That area being hot is a sign the refigerator is not cooling properly. We need to pin point the cooling problem.
First, are you noticing any frost build up inside the rear freezer panel?
Are the fans and the compressor running?
Please let me know so I can assist you through this.
Vic
May 27, 2009 | Refrigerators
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
