Question about Nintendo Guitar Hero Wireless Guitar - Wii for Wii
Wire broken on drum
I have taken apart the drum set. The wires going to each drum and symbol have two wires. One wire is always black the other is the color of the corresponding symbol or drum. Ex: (one black wire one yellow wire). Which wire is the ground?
  • 130 Answers
BLACK
Posted on Jul 15, 2009
Replace motor
green is always ground. white or gray is always neutral. and black, red always hot. without know what make,model machine your working on this is best info i can give.
Jan 14, 2013 | Vacuums
My Brother HL 4040cn printer is leaking toner, black and yellow. It leaves spatter spots of these colors on printed pages. The machine does not have any messages. Do you know what this may be from or how...
If you've taken the printer apart and cleaned the belt unit and everywhere else in the paper's path, then it is probably either a bad toner cartridge or the drum. Since it's multiple colors producing splatter, its most likely the drum unit. Try taking the drum out and removing all of the toner cartridges and then clean the drums and corona wires. If its still producing splatter afterward, you've got yourself a bad drum.
Jul 20, 2011 | Office Equipment & Supplies
Black & Decker 4.5 Angle Grinder Model KG915 Type 1 Grinder refused to go and when pulled apart found broken wire. After repair and putting back together the Grinder emitted large sparks from brushes...
How many wires did you put back together? If that was only two, just reverse the wires. Also in most cases wires are color coded. Green is always ground. White should be your neutral wire, and red or black (possibly blue or yellow) would be the hot wire. Swapping the blue and yellow (if that's what you have will reverse the direction)
Sep 03, 2017 | Makita 9069 9" Angle Grinder
Wire fell out of my sons drum set. it's the symbol wire
I just fixed this problem on our WII drums, the entire connector was ripped off the wire. You can get a repalcement jack at Radio Shack (pair is $4). You will have to carefully strip the shield and center conductor, tin with soldering iron and install new jack. Make sure you put the connector shell on the wire before you install the metal jack. Works like new.
Jul 04, 2009 | Nintendo Rock Band for Wii
How to solder guitar hero drum set wire
any tin/lead solder you get from maplins will do , I think they do a little tube with a coil of the stuff for about £2,,,
May 22, 2009 | Nintendo Activision Guitar Hero World Tour...
My guitar hero world tour drum kit is broken
If you know how to solder, you can resolder the wire back onto the connector. I just did that tonight actually. the orange cymbal has a white wire and a black/bare copper wire. You can cut open the male connector [I use an exact-o knife along the underside mold line] (one side only) so you can just slide the wires/connector back into it. The white would solder onto the base of the male connector. The bare copper thats wrapped around the white one is the black/bare copper wire mentioned above. This one is soldered to the tip [the solder point inside that small black plastic piece] of the connector. Once you have it soldered, just slip the male connector rubber piece back into place and use some super glue to glue back together.I wrap it in electrical tape just so its definitely secured. If wire length is an issue, simply solder some wire extensions before soldering to the male connector/plug.
Mar 22, 2009 | Nintendo Activsion Guitar Hero® World Tour...
Wii drum symbol in world tour just quit
WIRES ARE VERY THIN.YOU WILL HAVE TO TAKE SET APART AND LOOK FOR THE WIRE THAT HAS COME APART . YOU CAN FIX THIS BY SOLDERING WIRE ,OR TAKE SET BACK TO PLACE OF PURCHACE. REMEMBER YOU WILL EVENTUALLY RUN INTO THIS SAME PROBLEM, WHICH YOU CAN FIX ON YOUR OWN.
Mar 08, 2009 | Nintendo Rock Band for Wii
Hi,can you help??the wire that connects the yellow symbol is broken completely off the black little thing that goes into the slot. the actual wire is coming out and i stuck it together with sellotape and...
im sorry to tell you this but you will have to get a whole new drumset because nobody sells just a yellow symbol. (this has happened to my friends before and they had to buy new sets.)
Feb 01, 2009 | Buck Guitar Hero World Tour for for Xbox...
I had guitar hero since xmas and yellow symbol not working
How did you break the wire?
The best I can suggest is that since the drum kit is still under warranty, take it back to the store you bought it from and get it replaced. Be sure to take of the selotape beforehand since it will look like the drum kit has been tampered with.
Nintendo Guitar Hero Wireless Guitar - Wii for Wii Logo
285 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
