Question about GE Profile 30" Self-Cleaning Freestanding Double Oven Gas Range - Stainless-Steel
Dial has 350 line, line, line, 450 Which line is 400
    President:
  • GE Master
  • 1,922 Answers
If it says 350 line line line 450 it would seem appropriate that the center line id 400,the one to the left 375 and the one to the right 425...right???
Posted on Jul 28, 2009
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
Sep 22, 2008 | Canon FAXPHONE L80 Laser
I have a farberware convention turbo-oven model 460 serial number 2336445 I can only read the first two temperatures on the dial [150*- 250*] I am guessing that 350*- 450* is that correct ? , is that...
The top temperature is actually 475 (which is 550 in a regular oven). That's with the dial turned as far as it goes to the left. Don't know how you'll figure out the settings for the temperatures above 350, unless you measure the intervals below 350 and mark them off on the other side some way.
Here's a picture of the dial on my oven:
Oct 08, 2010 | Farberware T490C 1500 Watts Toaster Oven...
How is change shutter speed for canon 350 D camera.thankyou i am from india.
In either Tv or M mode, simply turn the command dial. In Program AE mode, press the shutter release button halfway and then turn the command dial to shift to different equivalent exposures.
Mar 21, 2010 | Canon Digital Rebel XT / EOS 350D Digital...
Our ARG7302WW range is missing the temperature sticker for the dial...where should 350 degrees be and does it go up in temp clockwise?
Hello- The background panel is screened with gradients, but is expensive and hard to find. The easiest solution is to purchase an oven thermometer and allow to set for about 20 min at an indicated 350deg. Make sure that dial knob is tight and mark with a line at that point. Use a fine point sharpy, and clean surface before marking. Turn off, let cool, and turn to the new 350 mark and see if temp comes up and matches 350deg on thermometer. If it works ok, try marking 325, 375, 400, etc. ---Yes,  Clockwise is up in temp. Let me know if this info helps.   Have more if needed-  Thanks - Ed
Mar 16, 2010 | Ovens
Can not hear the telephone ring on one of the main phones upstair
You will need to know which line(s), and on which station(s) (extensions) you want each line to ring.
Programming is accomplished as follows:
Default Installer Password = INTERCOM *746
You can enable different ringing assignments for individual lines and stations.
You must program ringing assignments on a per station/per line basis. You can control ringing for every line that has appearance at a station assigning immediate, or direct, ringing to some lines and delayed ringing to others. NOTE: Do not program direct ringing for lines that you assign to the direct department calling feature.
To Program: 1. Dial 54. “STA/LINE CONFIG.”
2. Dial 1 “DIRECT RING”
—OR—
Dial 2. “DELAY RING”
NOTE: For no station ringing, skip step 3 and make no line selection.
3. Select line ports for ringing (LED On = Selected Ports).
—Line port 1–14 = Dial 01–14 or press A1–A14
—Line port 15, 16 = Dial 15, 16 or press B1, B2
—Line port 17–24 = Dial 17–24 or press HOLD then press A1–A8.
4. Dial # when all line ports are selected.
5. Select station ports (LED On = Feature Assigned)
—Station 10–57: Dial 10–57 or press C10–C57.
6. Dial * when all station ports are selected
—OR—
dial ** for next station/line ringing assignment
—OR—
dial ***for configuration mode.
To clear current setting, repeat procedure.
Use an LCD speakerphone and a DSS/BLF console at station port 11 or 13 to see which features are assigned to individual stations. While you can install any non-LCD digital telephone and use it for programming, visual feedback of the programming operations will not be available. You must always keep the handset of the LCD speakerphone on-hook while you use this telephone to program the system.
Mar 26, 2009 | Comdial Impact 8024S Corded Phone
NorStar T7316E Corded Phone Manual
1 you can but it must be done via log on to switch with lap top (you may use handset but very tricky)
2 use feature *4
Speed dial -
using
FEATURE 0
Dial an external telephone number using a two- or three-digit code. There
are two types of speed dial codes: system (01-70 or 001 to 255) and
personal (71 to 94). System speed dial codes can be used from any
display telephone in the system. System speed dial codes are assigned by
your System Administrator.
Personal speed dial codes are used exclusively at your telephone.
To make a call using a speed dial code:
1. Press FEATURE 0.
2. Enter the two- or three-digit code for the number.
Speed dial -
programming
To program personal speed dial numbers:
1. Press FEATURE *4.
2. Enter a two-digit code from 71 to 94.
3. Specify the external line by pressing a line button, a line pool button, or
the intercom button. If you do not specify the external line, the system
automatically chooses a line for the call.
4. Dial the telephone number you want to program (up to 24 digits).
5. Press HOLD.
6. Record the code and number you have just programmed.
Note: You cannot program personal speed dial numbers while another
user is programming your system.
May 15, 2008 | NorStar T7316E Corded Phone
Toshiba strata dk 280
it may be setup to block outbound calling, remember also, you have to dial a 9 to get dial tone on a centrex line, so in this case if your phone system is setup to dial 9 as a line access code you will actually have to dial 99. hope that helps
May 13, 2008 | Toshiba Strata PT-390 Corded Phone
Toshiba estudio 350
on the side of the panel just move the black finger dial either up or down depending on lighter or darker, whichever you choose
Mar 21, 2008 | Toshiba e-Studio 350 Copier
NO Dial Tone on Verifone tranz 380
It could be the number programmed to dial is invalid, or it needs a PABX (8 or 9, etc)
If you have digital lines, these terminals will function in an inconsistant way. Make sure you are using a dedicated analog line. If you have a fax machine, try that line.
You can try slowing down the speed by checking fields 542 and 543 and changing them from 2 to 1.
You're best bet is to call you terminal software provider.
Feb 07, 2008 | VeriFone TRANZ 380 Transaction System (X2,...
GE Profile 30" Self-Cleaning Freestanding Double Oven Gas Range - Stainless-Steel Logo
77 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
