Question about Brother MFC-3240C All-In-One InkJet Printer
Brother mfc 3240c paper jam error
When I turn on the printer I get these noise (grinding) the it goes through some process, then I get beeps the the error message come up paper jam, I checked the printer thouroghly and there is no peices of paper in the track or anywhere. can any one help!!!
  • 1 more comment
  • Spotty Dog Feb 15, 2008
    I have exactly the same problem. I have checked the machine thoroughly and can't see any paper whatsoever. The machine makes a noise like plastic cogs slipping when the printhead goes across, but the cogs look ok..Is there a fix for this?
  • Anonymous Apr 14, 2008
    display showeing the set paper and press start after prays the butan after showing display printing but paper move the in side and midal and showing paper jam.
  • Mzthomas6 Nov 30, 2008
    I cannot print due to paper jam message. I have looked and there is no paper. I have turned my machine on and off to reset, and I have even uninstalled and reinstalled the printer and it still does not work.
    Brother MFC-3240C
You may not have the paper tray inserted all the way. I had the same problem until I pushed the tray in all the way.
Posted on Feb 20, 2008
You may have missed a VERY SMALL piece of paper some where. Check it again -use a flash light,magnifying glass BUT make sure there is no paper piece any where in the transportation route of the paper.Reset the machine-power off then on from the wall power outlet.
I did have this with a friend's machine and found a small piece in the side of the paper route.
Best luck and hope this helps
Posted on Nov 17, 2007
Sir, i have brother mfc-295cn their is NO PAPER INSIDE but still error that paper jam, open back cover then remove paper
You have to know the paper path of your printer (for any printer both laser and ink jet). Basically that's the path the paper takes from start to finish inside the machine. You'll have to check for any paper debris through the front and back. I would need some more information required to help further diagnosis this if you had paper jams in the past and last things done etc.
Dec 22, 2010 | Brother MFC-3240C All-In-One InkJet...
well have you cleaned the head manually or by using the software thru the pc. if you have done so by hand it may cause aproblem try cleaning using the software and see id that helps.
Oct 03, 2010 | Brother MFC-3240C All-In-One InkJet...
Paper jam
im assuming you are using regular copy paper, is so fan the paper out before you put it in the printer and also check to see if the roller inside the printer are clean. they pull the paper threw the machine.
Jun 28, 2009 | Brother MFC-3240C All-In-One InkJet...
Clicking noise with MFC-8640D
Make sure that the paper guides in your paper tray are not holding the paper too tight against the front of the tray, there should be about 1/16 inch play so that the paper can be lifted to the roller easily. Also take out your toner and drum and turn it on, if the grinding noise is gone you may need a new toner, some refilled toners are too tight to turn properly.
Jun 24, 2009 | Brother MFC-8460N All-In-One Printer
Brothers error message 50
Check for remaining ( small peace) jammed paper inside.
Jan 23, 2009 | Brother MFC-3240C All-In-One InkJet...
Brother MFC 3240C Paper Jam Error Message
If it is not resetting then either there is still something on a sensor or you did something to a sensor by accident.
here is the manual
Nov 21, 2007 | Brother IntelliFax-2820 Laser Fax
Brother MFC-3240C All-In-One InkJet Printer Logo
188 people viewed this question
James Cagle
James Cagle
Jim Keysor
