Question about Haier HDN655E Dehumidifier
Fuse location Where is the fuse located? We have the front and back off of the unit, but don't see a fuse. Thanks
  • dkdiaz Jul 15, 2009
    Inside front cover on right side near bottom of circuts.
Bottom left of board. has a blue plastic covering. if you find out why it blows fuses please post. baby need diapers not a new dehumidifier!!!!
Posted on Jul 24, 2009
EVERYTIME I PLUG IN THE UNIT AND TURN IT ON IT BLOWS THE 12 AMP 125 V FUSE INSIDE. REPLACED THE FUSE MULTIPLE TIMES WITH THE EXACT FUSE RECOMMENDED AND IT STILL BLOWS. THE UNIT IS ONLY 1-2 YEARS OLD. ...
The compressor has locked up and will not start...this is terminal and will cost more to replace it then the unit is worth...
unfortunately you will have to replace the unit with a new one...
heatman101
Jun 30, 2011 | Amana D545M Dehumidifier
Hello Our LG HDL 65EL is not working properly. It turns on, the compressor sounds like it want to go, but the fan doesn't turn on. Is the fuse we can replace or a reset button we can switch? Or...
No, there is no fuse or circuit breaker to reset on your unit. However, there are several things r=than can cause the problem, you're experiencing:
The unit's humidity level may be set to high. Lower it to 35%
The air intake filter may be dirty or clogged. Remove the filter and clean it
The compressor coils may need cleaning.
The air ambient air temperature may be to low. Dehumidifiers don't function well between 40 & 60 degrees F.
The unit may need to reset itself. Turn the Master ON/OFF Switch to OFF and unplug the unit for 12-15 minutes. Plug it back in and turn the Master ON/OFF Switch to ON. Set the humidity level to 35%. Allow the unit to operate in Automatic Timed Mode, rather than continuous mode.
Make sure there is at least a minimum of 12" of clear air space around the entire unit, when in operation.
If none of the above solves the problem, the humidity sensor may have failed. In which case it should be replaced. Or the compressor needs to be recharged with refrigerant.
I hope this helps you troubleshoot and solve the problem.
May 27, 2011 | LG LHD45EL Dehumidifier
The unit has power, all controls work. The machine "turns on" when the humidity level exceeds the level set. However, the fan or wheel or whatever it's called does not turn. I took apart the unit and...
I have the exact same problem. I've isolated it to the thermal fuse for the fan motor. This can be confirmed by jumping the black wire to the blue wire coming from the fan motor while the unit is running. Only problem I have is I haven't been able to locate the fuse yet.
Oct 21, 2010 | Maytag M7DH45B2A Dehumidifier
Location of Maytag M7DH45B2A motor fuse
I'm fixing one of these too. Take the top off (follow the AC cord) and the fuse is on the PCB.
I am also looking for a better wiring diagram - the control panel on mine does not light up.
Aug 21, 2008 | Maytag M7DH45B2A Dehumidifier
Bad fan motor on DH504ELY5?
problem fixed with the fan motor not running.
heres how i did it for anyone who experiences the same problem
1.) open back of unit(6 screws and pop tabs)
2.) with back cover open youll have access to compressor and fan-locate the blower assembly and remove the nut on it i used a 3/8 wrench from dollartree and rotated the blower fan while turning-its plastic be careful and remember righty tighty lefty loosey)
3.) with fan assembly off youll see the motor with 2 phillips head screws-taking these screws out with a power screwdriver allows the bearing assembly closest to the fan assembly,shaft,armeture and motor assembly to come out leaving rear bearing assembly attached to chassis
4.) once the motor assembly is completely out gently rest it against the fan hole and cut the silver tape being careful to ONLY cut the silver tape and the first white tape strip.
5.) youll see 3 wires and some insulator sleeves covering them leave everything alone except the ORANGE wire this wire attaches to the thermal fuse than to the windings
CAREFULLY heat up your soldering iron and remove the orange to thermal fuse connection than carefully thermal fuse to windings its a bit of a pain but can be done with patience
6.) remove original thermal fuse noting EXACTLY where original is placed on windings-it will have a small tape strip on it. replace it with one of EXACT OR NEAR THERMAL RATINGS a good choice is radioshack 270-1322. this thermal fuse is ratyed 10 amps max. but remember thermal fuses go by degree of heat and not by amp rating unless the amperage is in excess to melt the thermal material inside-my original fuse was 2 amps and 130 degrees celcius new fuse was 129degrees but plus minus 2 degrees so its a good choice and costs under 2 dollars
7.) place a heatsink clip or needlenose pliers between thermal fuse and solder connections BEFORE YOU SOLDER IT IN PLACE this prevents your 700 degree f iron from melting the fuse(remember its thermal not amperage were talking about here)
solder orange to thermal fuse with plastic extension than flat end to winding wire exactly opposite of how removed
8.) tape fuse in ORIGINAL LOCATION AS OLD FUSE i used scotch tape,place the thermal white protector piece on orange to fuse wire and push everything back down in original places-there should be no contact with any other wires etc. it will cause a fire
9.) once fuse is in place push tape you cut earlier back on and put 2 or 3 small scotch tape pieces of good length to secure the innards, lube the rear bearing of motor using vasoline- a few dollups will do it do the same for front slide motor winding assembly holding it in place than replace armeture with front bearing attaches as they came out secure the 2 screws back in place, put fan blade assembly back on(its keyed) secure nut and reassemble back
if you did everything correctly it will work like new just remember this time CLEAN YOUR FILTER SCREEN REGULARILY lol its critical for proper fan cooling
that should do it:)
Aug 20, 2008 | Goldstar DH504EL Dehumidifier
No Power
Found the fuse at this website www.tiewraps.com ORder the AG-12
Jun 27, 2008 | Haier HDN655E Dehumidifier
Haier HDN305 humidifier
It's on the right side under blue plastic cover.
Jun 13, 2008 | Haier HDN655E Dehumidifier
Haier HDN655E Dead
There is an internal fuse. Take off the outer plastic casing. The fuse is on the bottom of the board on the upper right of the unit. It's a 12 amp fuse. I had the same problem and found the fuse blown.
Aug 10, 2007 | Haier HDN655E Dehumidifier
Haier HDN655E Dehumidifier Logo
550 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
