Question about Maytag Neptune MDG5500AW Gas Dryer
MGD3000AWW wont start. Makes the start up sound but then nothing. Took it apart ignition and flame seems ok (Cycles on and off) motor spins fine without the drum in. Any ideas?
  • 6,784 Answers
You have a malfunctioning control sector. i recommend replacing this damaged control board asap, if possible. it has failed.
Posted on Jul 26, 2009
Whirlpool washer does not spin
Try taking some of the wet clothes out maybe to heavy
Jan 15, 2016 | Whirlpool Washing Machines
Washing machine will not engage drum in wash or spin mode
it sounded like the brushes have gone but you said you replaced them right? usually when the drum stops spinning its because the brushes have completely worn down and there is nothing left are you sure you snapped them into place properly or brought the correct model numbered ones? then are very difficult to get into the correct place I had a very similar problem and it took four attemps to get them in thr right place they are not the most easiest of things to do. if you have then it might be the motherboard electrical component if this is the case you will need a new machine im afraid if you dont have that much disposable funds try the freecycle website the offer free stuff look for you nearest area and take a look
Apr 15, 2014 | Bosch Washing Machines
Chugging like noise during certain cycles
your clutch need to be replaced as does the tub shaft bearings i;m sorry this is not a do-it-yourself job, try to make a deal to trade in your washer
Apr 22, 2009 | GE Washing Machines
Drum wont turn
yes the start whinding shot,,,replace motor..
Jan 25, 2009 | Whirlpool LER5636P Electric Dryer
Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Jan 06, 2009 | Heating & Cooling
No Heat-Inducer motor doesn't start ?..humming noise only..warm..
Bad inducer motor most likely. Check the leads and plug. If it just homms, it is stuck. Check to see if the drain hoses are free of moisture. Can you get to the shaft to spin it to see if it is free?
Dec 07, 2008 | Goodman GMS90703BXA Heater
Whirlpool duet washer wont run
sounds as if perhaps the hummm is coming form the drain pump not the motor, remove the front cover and you ll be able to acess the drain pump resivior, unscrew it and you find all sorts if things jammed into the pump preventing free spinning, 7 years servicing this unt never saw a bad motor, 1000's of pumps
Oct 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer does not wash or spin
the electronic module who drives the motor its the problem . you can order and replace find part at partstore.com go by brand and model let me know if you need more help thanks
Jun 20, 2007 | GE WSXH208A Front Load Washer
Maytag Neptune MDG5500AW Gas Dryer Logo
218 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
