Question about Dishwashers
Whirlpool 350xt-4 model dishwasher runs, but does not clean. What can I do?
  • 297 Answers
Maybe you are overloading the unit,try less you may get better results.
Posted on Jul 15, 2009
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
Error code 4 philips whirlpool dishwasher
Hi Kevin , it seems like you have debris clogging your sump motor . Remove the lower spray arm and remove the five T15 screws then remove the motor cover . Next with a wet vac clean all debris in motor . Make sure theres nothing under the float switch .
GOOD LUCK
APPLIANCES R'EN
Dec 06, 2013 | Whirlpool 24 in. ADG6340 Built-in...
Won't start/run. CLEAN light blinks continuously. manual drain (CANCEL)button works model number DU1100XTPQ9
When the clean light is blinking, the self-test on the dishwasher has reported a problem with the heating circuit. It needs to be fixed. If the dishwasher is still under warranty, call for service.
The manual for the DU1100XTPQ9 is here: http://www.managemylife.com/mmh/owner_manuals/4164/WHIRLPOOL-Dishwasher-L0704454?brand_name_search=DU1100XTPQ9+WHIRLPOOL . Various parts diagrams and links to purchase the parts are here http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dishwasher-Parts/Model-DU1100XTPQ9/1198/0130000 .
I hope this helps.
Jun 20, 2011 | Whirlpool Dishwashers
The clean light is flashing on a whirlpool dishwasher-model du1048. The manuel says the dishwasher has malfunctioned and to check the heater circuit. How do I do that?
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Feb 17, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
I have a Whirlpool Quiet Partner II model DU1100XTPQ7. The top rack is not clean after the dishwasher runs. We cleaned both sprayers with pipe cleaner & ran water through the lower sprayer with a...
Hello Tx_smiths! We are terribly sorry to hear of your concern with your Whirlpool Dishwasher. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer name (Tx_smiths), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 19, 2017 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes not getting clean,model#gu1500
Had the same problem. Here's what I did to resolve it: 1. Removed the lower spray arm and the mesh filter. I washed the filter and pulled out a few non-degradable particles, including husks and shells. 2. Switched from a liquid detergent to a powder. 3. Turned my hot water heater to the highest setting. 4. Let the water flow in the kitchen sink to ensure it warms up before I run the dishwasher.
Jun 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Our less than 1 year old Whirlpool dishwasher model DU1145XTPQA is taking as much as 2 and 3/4 hrs. to complete the entire dishwashing (normal)cycle. This is much longer than it used to take.
Contact Whirlpool service immediately to get a service call scheduled before the warranty expires.
Most dishwashers that begin taking longer to complete the cycle have a failed heating element but that also normally means that the dishes do not get fully clean and the glassware has a film on it after the cycle ends.
Good Luck!
Apr 07, 2009 | Whirlpool 24 in. DU1148XTP Built-in...
Whirlpool dishwasher reset code
Yup, found it on another site..I had the same issue today.
Reset code: Push 1. Heat Dry 2. Normal 3. Heat Dry 4. Normal
wait about 2 minutes as the controller resets itself. You should see all the leds flash on and then wash and rinse leds stay on for about 30 seconds. A minute or so later ..presto, my machine worked again.
My machine is not the GU3200XTP, but in the same Whirlpool tall tub series (same manual) so leds may not have the same name.
Mark
Oct 19, 2008 | Whirlpool 24 in. GU3200XTP Built-in...
I have a Whirlpool dishwasher model ADP951. the green light is continually flashing and will not run, help with this would be most appreciated.
Have a look underneath dishwasher by removing front bottom access panel, the one touching the floor. Look for a round plastic disc about size of 4 jam lids together, centre front of dishwasher. Inside of it is a foam disc that will float up off the base of the dishwasher if water causes it to do so. This floating up will trip a switch. Clean base of dishwasher of water and maybe test the switch with multimeter. Reset fault by holding down start button.
Apr 26, 2008 | Whirlpool Dishwashers
Bosch sgi45e12gb/22 dishwasher won't stop
hey you..I have a whirlpool dishwasher too that would not
stop the wash cycle...it would run for 2-3 hours,
and then run thru the whole wash cycle again!
so..I had a whirlpool factory trained repair man come to
the home. He ran a diagnostic and it was 100% good,
so he called Whirlpool headquarters spoke to them;
said...........every 250 hours the dishwasher will
RE-CALIBRATE itself! running for 4-4 1/2 hours
straight, in order to re-calibrate itself. I was
interupting this by opening the door before it had
run the full 4 -41/2 hours of it's self-maintenance program.
Perhaps that your dishwasher is doing too?
p.s. always make sure you get a repairman that
is factory trained in your specific brand, otherwise
you'll waste $$$ money with a repairman who doesn't
have access to the corporate tech's and direct access
to their parts/inventory.
good luck with your dishwasher!
mine is the whisper quiet with computer control on front
of the door.
Apr 11, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
