Question about Dometic Rooftop RV Air Conditioner
The heat strip comes on when unit is running causing heat/electric smell, and temperature raises, when i disconnect the heat strip, unit is normal. Is the on off switch bad? I have analog switches not digital.
  • rhl0801 Jul 15, 2009
    Thanks for the help, according to the instruction manual, the temperature controller does not affect the heat strip at all, the heat strip is independent of the thermostat right in the intructions , "the ac thermostat does not operate the heat strip, when desired temperature is reached turn the control switch to off"
    I would think the on off switch is the culprit.
  • 614 Answers
Heat strips have sequencer or time delay reay. One of them sounds like it is sticking.Rus
Posted on Jul 15, 2009
    Champion:
  • 233 Answers
If the on off switch is the only switch in series with the strip then I would say it is bad, there should also be a temeprature controller in series, if it is a three pole switch it could also be bad, verify the switch(s) operation with an ohmmeter
The fridge is hot the center deviding fridge and freezer hot enough burn hand and center of fridgeon side with water/ice despenser is hot also i just pluged in fridge is that normal for the fridge
Hi, welcome to FixYa.
I`ll start by letting you know first the heat between the doors is normal, yes...to a degree, and done by design to help prevent moisture along the "breaker strip"/divider.(where the doors come together when shut)
If all else appears fine (temp. Ok, fans running, no significant frost build up on freezer back wall) it's likely nothing to be concerned about.
**Just be sure the condensor fan isn't jammed and still turning.** The fan at the back next to the compressor...In fact that is what I`d look for based on your post.
But just so you know, the amount of heat can be determined by several factor's such as,
1) temperature setting - lower ( colder ) the temperature is set the more the run time the hotter the strip.
2) The ambient temperature - hotter the environment the more the unit runs to compensate, hence the hotter the strip.
3) The amount of "fresh" content added to the unit ( especially freezer section if unfrozen items added ) - new items add a lot of warmth thus demanding the unit to run more to remove this heat (btu`s or british thermal unit`s )causing the strip to be hotter.
4) Build up of dust & dirt on the condensor coils - this also causes the unit to run excessively which in turn makes for more heat on this strip.
These are all things which can and do determine the amount of heat between the doors.
Another factor to always consider is of course If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned.
Hope this answer's your question and let me know if I can assist you further.
Thank's for coming to "fixya" and good luck moving forward.
Please take a second to write a brief testimony and rate the info provided here.
Regards,
Macmarkus :)
Jun 30, 2011 | Samsung RS2630SH Side by Side Refrigerator
The door frame surface between the freezer and refer is very warm almost hot to the touch. is this normal?
Welcome to FixYa.
I`ll start by letting you know first the heat between the doors is normal...to a degree, and done by design to help prevent moisture along the "breaker strip"/divider.(where the doors come together when shut)
Regards,
Macmarkus :)
Mar 30, 2011 | Kenmore Side by Side Refrigerator
I smell an odor possibly electrical but I was unsure and had the gas company come and check. The gas company serviceman states the gas connections are good, nos gas smell in any areas of the house. The...
You should have an Amp draw on the system and it's motors. Your nose will be your guide in figuring out what component is getting hot. Smell circuit board and electric motors.
Jan 16, 2011 | Ruud UBHC Air Conditioner
What does it mean if the doors to the refrigerator are hot where they come together when shut? It's a Kenmore Coldspot Model number 106.55642500
Welcome to FixYa.
I`ll start by letting you know first the heat between the doors is normal...to a degree, and done by design to help prevent moisture along the "breaker strip"/divider.( "where the doors come together when shut" )
If all else appears fine, temp. Ok, fans running, no significant frost build up on freezer back wall, it's likely nothing to be concerned about.
The amount of heat can be determined by several factor's such as,
Regards,
Macmarkus :)
Sep 05, 2010 | Kenmore Refrigerators
The post between where the freezer and
Hi, Welcome to FixYa.
Hope this answer's your question and let me know if I can assist you further. Thank's for coming to "fixya" and good luck moving forward.
Please take a second to rate the info provided here.
macmarkus :)
Jul 30, 2010 | Kenmore 53642 / 53644 Side by Side...
Very hot
Hi, welcome to Fixya.
The heat between the doors is normal and done by design to help prevent moisture along the "breaker strip"/divider. If all else appears fine, temp. Ok, fans running, no significant frost build up on freezer back wall, it's likely nothing to be concerned about. The amount of heat can be determined by several factor's such as, a) temperature setting - lower the temperature is set the more the run time the hotter the strip. b) The ambient temperature - hotter the environment the more the unit runs the hotter the strip. c) The amount of "fresh" content added to the unit - new items add a lot of warmth thus demanding the unit to run more to remove this heat causing the strip to be hotter, especially during hot summer days. d) Build up of dust & dirt on the condensor coils - this also causes the unit to run excessively which in turn makes for more heat on this strip. These are all things which can and do determine the amount of heat between the doors. If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned. Hope this answer's your question and let me know if I can assist you further. Thank's for coming to "fixya" and good luck moving forward. Please take a second to rate the info provided here. macmarkus :)
Jul 08, 2010 | Samsung RS2630SH Side by Side Refrigerator
Center support of Side By Side is Hot to the touch
Hi, welcome to Fixya. The heat between the doors is normal and done by design to help prevent moisture along the "breaker strip"/divider. If all else appears fine, temp. Ok, fans running, no significant frost build up on freezer back wall, it's likely nothing to be concerned about. Just be sure the condensor fan isn't jammed and still turning. If not turning it can cause the unit to become extremely hot. The amount of heat can and is determined by several factor's such as, temperature setting - lower/colder the temperature is set the more the run time the hotter the strip. The ambient temperature - hotter the environment the more the unit runs the hotter the strip. The amount of "fresh" content added to the unit - new items add a lot of warmth thus demanding the unit to run more to remove this heat causing the strip to be hotter. Build up of dust & dirt on the condensor coils ( they should be vacuumed annually ) - this also causes the unit to run excessively which in turn makes for more heat on this strip. These are all things which can and do determine the amount of heat between the doors. If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned. Hope this answer's your question and let me know if I can assist you further. Thank's for coming to "fixya" and good luck moving forward. Please take a second to rate the info provided here. Macmarkus :)
Jun 07, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Hot between the doors.
Hi, The heat between the doors is normal and done by design to help prevent moisture along the "breaker strip"/divider. If all else appears fine, temp. Ok, fans running, no significant frost build up on freezer back wall, it's likely nothing to be concerned about. Just be sure the condensor fan isn't jammed and still turning. The amount of heat can be determined by several factor's such as, temperature setting - lower the temperature is set the more the run time the hotter the strip. The ambient temperature - hotter the environment the more the unit runs the hotter the strip. The amount of "fresh" content added to the unit - new items add a lot of warmth thus demanding the unit to run more to remove this heat causing the strip to be hotter. Build up of dust & dirt on the condensor coils - this also causes the unit to run excessively which in turn makes for more heat on this strip. These are all things which can and do determine the amount of heat between the doors. If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned. Hope this answer's your question and let me know if I can assist you further. Thank's for coming to "fixya" and good luck moving forward. Please take a second to rate the info provided here. Macmarkus :)
May 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Goodman package- no heat below 30 degrees outside
I believe the unit you are describing is a heat pump. Heat pump are great when the temperature isn't below 30 With low ambient temps. outside it is much more efficient and comfortable to run aux. electric heat from the heat pump.
Jan 03, 2010 | Goodman PHKJ048-1 Air Conditioner
I have a Trane XE1200 AC unit which emits a slight electrical burning smell when it turns on / cycles throughout the day. the smell is very similar to that of the furnace when it initially turns on during...
I would have a tech come out and check the voltage going into the fan relay and fan itself. The smell being as how it is coming through the vents in the house tells me that the problem has got to be at the blower or in the area at the blower fan which leads me to the possibilty that the smell could be the windings on the motor. This could be because the voltage may be to high. Good luck on repairs
Dave
Sep 01, 2009 | Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
222 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
