Question about Quasar SP-2725 27" TV
I need the code to do an auto channel search for my lg tv so i can go up and down from channel to channel instead of typing the number to the channel in
  • 56 Answers
Your auto channel search should be in your menu on the TV. Find your menu button on the front of your TV or on the remote.Make sure before you do a auto search you set your TV to cable, that can also be be done through your menu screen. If you can change the channels on the remote and control the volume your remote is already programmed.
Posted on Jul 15, 2009
Just bought an ANTSIG 4 in 1 universal remote control and cant find the code to operate an LG vcr.. can you help ?
Not sure if you've decided to throw your remote control away already or not. But try using the manual search code. I have only tried this with an LG TV. Hopefully it helps you out. Basically press "TV" (light blinks once), then press the "Up" channel button and the "up" volume button at the same time (light comes on permanently), then hold down "Power" whilst putting the remote RIGHT IN FRONT of the place where your tv receives signal (usually where you can see a light), and I mean right in front! Hold it down until your tv powers off. Then it should be configured and working. It took me about 1 minute or more for the TV to react and turn off. Then you can check if it turns on again and if the channels are working. Maybe you'd need to press something else instead of TV for a VCR? But the trick is to be about 1mm away from the signal receiver. I literally put it in front of the red light of the tv.
Feb 03, 2011 | Televison & Video
Channel buttons change input
Auto channel search is your friend. Once the tv has been through it and finds active channels, your channel button should work the way you envision.
Jul 06, 2017 | Toshiba 15LV505 LCD TV
Auto Channel Search places all channels in skip mode causing channel changes to made by number input instead of up/down button. Having to manually turn "Skip" off on each channel individually.
check the agc line from the tuner is functioning properly, if the agc signal , is not reaching the processor it will register that channel as being inactive and lock it out, there is not much circuit to contend with so a multimeter should do the trick to trace down the fault, you should find AGC marked on the board where the tuner modual is mounted.. i suggest obtaining a service manual to do the job good luck
Jan 28, 2010 | Polaroid FLM-1911 19 in. LCD Television
I have a 32 inch Haier TV and my comcast cable remote wont work with it. I need to know how to get my tv to sync with my cable remote.
there is an auto search method....some remotes you can hold the tv button down and then the select button simultanteously for a few seconds to make the light turn red and then proceed with codes, when you get the right code you press the select button again, the light blinks and you are done..... well with out a code its the luck of the draw..... the auto search method is similar to programming the code in....hold the tv button and the select button for a couple seconds until the tv button lights up, but instead of a code.....press the channel up button(that represents the first autosearch code), continue until the tv turns itself off and then press the select button to lock it into the remote...........if you go past the trigger point you can channel down to backtrack.... otherwise drop it in the toilet until it wont work, call the cable company and have them send out a tech with anew remote. they cant charge you for their equipment not working correctly.
trust me, i am a supervisor at a major cable company.
Jan 17, 2010 | Haier HTF20R21 20" TV
Free list of codes for a magnavox mru3300
I'm not positive but these codes should work, if not try the CODE SEARCH function. I'll post the Code Search instructions first, then I'll post the Brand Codes (list is a bit long so it might take a couple of posts). Let me know if any of this helps you and I'll continue to search for a pdf type of code list for the mru3300 for you.
*CODE SEARCH
If your product does not respond after you have tried all
the codes for your brand, or if your brand is not listed,
try searching for your code by following these steps.
1. Manually turn on the device (TV, VCR, etc.) to be
controlled.
2. Press and hold the CODE SEARCH button until the
red indicator stays on, then release the CODE
SEARCH button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to
300 times) until the device to be controlled changes
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing CHANNEL UP changes
direction to forward again.
5. Press and release MUTE to install the code.
Most users will store VCR codes under the VCR button,
Cable codes under CABLE, etc. If (for example) you
want to store a VCR code under CABLE, first follow the
procedure for Direct Code Entry (previous page) and
press CABLE in step 2 of Direct Code Entry, then enter
ANY VCR code in step 3 of Direct Code Entry. Then
follow the steps above for Code Search (or Brand
Search, below). Note: If the device does not have a
CHANNEL UP button, use PLAY (VCR only) or
POWER instead. Code Search starts from the currently
stored 4 digit number under that mode.
Dec 13, 2009 | Philips Televison & Video
I lost my code sheet and I need the code for a Symphonic TV
controlled.
SEARCH
button.
stored three digit number under that mode. Good Luck.
Nov 20, 2009 | Philips PM3S Remote Control
Describe how to program channels on lg tv
Very simple -
You will need to find a feature that says 'Auto Tune'
This first will ask you to select between:
1) Regular TV - off air antenna - connection
2) Cable TV - connection
3) DSS TV - Connection
If you aren't ready for digital TV with your antenna or cable you may get very few channels.
Nov 17, 2009 | LG 42LC2D 42 in. LCD HDTV
CHANGE CHANNELS WITH THE CONTROL
Run a channel scan on the DTV and/or TV input depending on what one your not getting channels on. This will solve your issue.
Change the input on the unit to the DTV or TV input. Press the menu button on the remote. Navigate to the tuner DTV or TV tuner setup menu. Go down to auto search using the down arrow. go right when with auto search selected. This may take a few minutes but you should have all the channels back after the scan.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Auto Channel Search
sounds like the tuner section of the main pcb isn't working properly.
Jul 28, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Quasar SP-2725 27" TV Logo
233 people viewed this question
Top Quasar Televison & Video Experts
Radames Pagan
Radames Pagan
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
