Question about Maytag PAV2300 Top Load Washer
My washer will not keep water in the tub. The
My washer will not keep water in the tub. The water runs down the drain.
    President:
  • 1,136 Answers
Hi, You need to make sure the drain hose is as high as the top of the washer. If the drain hose is to low, the water wil drain out before it reaaches the proper water level.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Posted on Jul 15, 2009
  • Victor
    Victor Jul 15, 2009
    Thanks
    Vic
When the water is entering the tub it immediately goes out the outflow. The tub will not even fill up a little bit. What could be the problem? thanks
The drain hose outlet must be located higher that any expected water level in the tub. If too low, gravity drains the tub as it is filled. Extend the (a) drain pipe up to the proper level, even if you are using a floor drain to carry away the water. Hope this helps!
Jan 27, 2011 | GE WDSR2080D Top Load Washer
Tip
Winterizing a Washing Machine
If you keep your washer in area where you need to winterize for the winter (unheated garage or unoccupied vacation home), the following steps may provide you with some helpful guidance in preparing before extreme temperatures occur and possibly leave you with damaged plumbing and/or a ruined appliance.<br /> <br /> <b><u>TOP LOADERS</u></b>:<br /> <br /> 1. Turn off the main water supply to both water taps.<br /> <br /> 2. Remove the fill hoses, drain them of all water and reinstall them - leave water supply turned OFF.<br /> <br /> 3. Add 1 gallon of Recreational Vehicle (RV) antifreeze (non-toxic) to an empty wash tub.<br /> <br /> 4. Select the DRAIN/SPIN function on the timer and allow the washer to run for one minute to drain the antifreeze from the wash tub, and any water remaining in the drain pump or drain lines. <br /> <br /> NOTE: Not all the antifreeze will drain. A small amount will remain in the drain pump and line (this is normal).<br /> <br /> 5. STOP or CANCEL the timer on the washer and UNPLUG.<br /> <br /> 6. Wipe down and dry the wash tub.<br /> <br /> 7. Clean the detergent dispenser and fabric softener dispenser and ensure they are dry.<br /> <br /> 8. Store washer, unplugged in an upright position.<br /> <br /> <br /> <b><u>FRONT LOADER</u></b>:<br /> <br /> 1. Turn off the main water supply to both water taps.<br /> <br /> 2. Remove the fill hoses, drain them of all water and reinstall them - leave water supply turned OFF.<br /> <br /> 3. Add 1 gallon of Recreational Vehicle (RV) antifreeze (non-toxic) to an empty wash tub.<br /> <br /> 4. Select the DRAIN/SPIN function on the timer and allow the washer to run for one minute to drain the antifreeze from the wash tub and any water remaining in the drain pump or drain lines. <br /> <br /> NOTE: Not all the antifreeze will drain. A small amount will remain in the drain pump and line (this is normal).<br /> <br /> 5. Press PAUSE/CANCEL twice to halt the cycle and UNPLUG the appliance.<br /> <br /> 6. Wipe down and dry the wash tub.<br /> <br /> 7. IMPORTANT: Check the perimeter of the door bellow (gray rubber seal) and make sure no small articles of clothing are left in the rubber folds. Clean this area thoroughly and dry. NOTE: Anything left behind will mildew over a period of time causing foul odors.<br /> <br /> 8. Clean the detergent dispenser drawer of any remaining water or fabric softener residue.<br /> <br /> 9. Store washer, unplugged in an upright position.<br /> <br /> <b><i><u>Secondary Method</u></i></b>: <br /> <br /> If you cannot find RV antifreeze (or prefer not to use it), another method of draining the washer is to remove the drain hose from the standpipe at the wall and pull a vacuum on the line with a wet/dry shop vac. This will pull any remaining water from the drain pump and lines. <br /> <br /> If a shop vac is not available, lowering the drain hose from the standpipe to the floor will allow it to drain using simple gravity. <u>IMPORTANT</u>: On a front loader, you may have to remove the drain line from the drain pump to drain the pump. Or, use the access cover (if equipped). Most front loader pumps are accessed by removing the lower panel directly below the door.<br /> <br /> <b><i><u>Taking the Washer out of Winter Storage</u></i></b>:<br /> <br /> To remove antifreeze from the washer following storage, run the appliance on a complete cycle with detergent and NO garments added.<br /> <br /> I hope you find this information helpful. If you have any questions, please let me know.<br /> <br /> <br />
on Aug 09, 2011 | Washing Machines
Sometimes when I turn the washer on; it continues to run the water without filling the bowl. Seems like the washer thinks its in rinse mode.
Check your drain the drain hose must be higher that the tub or it will run down the drain.
It must be going down the drain or you would have water all over the floor If the water is coming in it has to go somwhere. In rinse cycle it should stay in the tub until the timer kicks it into drain and spin.
Sep 14, 2010 | Kenmore 98702 Stacked Washer/Dryer
Wash tub does not fill - water continues to run but does not fill
Be sure that the drain hose is routed HIGHER than the console of the washer. There is no drain valve, but rather physics that keeps water in the machine..
Doc
Sep 18, 2009 | Kenmore 22422 Top Load Washer
My washer will not spin and can only fill tub on small loads cause water will run out
does the water keep running and it keeps draining the water? if so your drain hose needs to be higher than the highest water level in the tub or it will drain as it fills.
Aug 31, 2009 | Washing Machines
Water continuously runs and cycle won't start. The washer tub doesn't seem to be filling with any water.
Probably a syphon problem . Check your drain hose to make sure hose is not stuffed too far down drain and air can get between the hose and the drain pipe . If you have tapped the hose to the drain to keep water from comming out the drain pipe , go to home depot or an appliance parts house , and get a syphon break . When a washer fills , but water level doesn't rise in the machine , it's being sucked out by syphoning thru your sewer pipe .
Aug 08, 2009 | GE WVSR1060A Top Load Washer
Keeps filling with water, but draining at the same time!
be sure your drain is nearly to the top of the washer if it is you may need to try a siphon break
Apr 24, 2009 | Washing Machines
Water will not stay filled in tub on rinse cycle
It sounds like a siphon issue.
Check that the drain hose does a high loop before it goes into the drain pipe. (ie. drain hose loops above the water level inside the tub). Make sure the drain hose is not pushed too far down into the drain pipe. Also if the drain hose is sealed to the drain pipe this will create an airlock and a siphon will occur, allow air to enter between drain hose and drain pipe connection.
This should help you but if there is still a problem let me know and I'll try to assist you further.
Mar 21, 2009 | Maytag Washing Machines
Tub fills only 1/2 full but water keeps running as if the tub is not full. If the water level is set to 1/2 or less, tub fills 1/2 full and begins to cycle. The water is running into the tub but not...
Check the drain hose to make sure you have a high loop, ie. make sure the drain hose loops above the height of the washer lid before going to the drain pipe.
Also make sure the drain hose is not going too far down into the drain pipe.
You may be getting a siphon effect.
Feb 20, 2009 | Admiral AAV7000A
Repair man says washer hose must be off ground for proper draining
yes drain should be at least 36 inches from floorif hose outlet falls below water height in tub water will siphon out faster than it runs in try installing 1 and quarter diameter pipe into floor drain and dropping end of hose into it
Apr 30, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Maytag PAV2300 Top Load Washer Logo
267 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
