Question about Nintendo Wii Console
Arrow will not move, changed batteries in control .
  • 130 Answers
THE INFARED NEEDS TO BE CLEANED
Posted on Jul 15, 2009
How do I open the casing to the battery compartment? I push the arrow in the indicated direction but I don't know which part moves or what direction
The arrow points in the opening direction. some battery compartments are difficult to open even with the help of the arrow pointing in the correct direction of movement.
Oct 07, 2016 | Televison & Video
Sometimes when I am on my laptop the arrow for my cursor disappears and I can not do anything unless I can get the arrow keys to take me to something.
Go to the Control Panel, using the menu (keys control+ESC).
Using the arrow keys.
Using the tab keys go to mouse icon and then pointers and make the changes to reveal the cursors.
Feb 19, 2015 | Toshiba Satellite Computers & Internet
Can't use the arrow keys to move from equation to equation on the home screen. why? I just changed the batteries.
Remove the battery and after 5 minutes put it again. Be sure to install the correct battery polarity
Mar 25, 2013 | Texas Instruments TI-84 Plus Silver...
How can i turn down contrast on my laptop
Acer Aspire one
Brightness is controlled by the Fn and arrow keys.
Contrast can be controlled from the software.
FN key, + left/right arrow key's
other Acers
Log on to your Acer laptop and click on the "Start" button. Choose "Control Panel" from the menu.
Double-click on the "Display" icon in "Control Panel" and select the "Settings" tab.
Check the "Color Quality" settings and make sure they are set to either medium or high.
The high setting will give you better color quality and contrast, but it will also use more system resources and shorten battery life.
If you are operating on battery power you may want to move the setting to medium.
Hold down the "Fn" key and press the right arrow at the same time.
This key combination will increase the brightness of your screen.
To decrease the brightness and contrast, hold the "Fn" key down and press the left arrow. Continue using these key combinations until you have found the optimal setting for your laptop display.
hope this helps
Oct 08, 2012 | Acer Aspire One D255E13438 Netbook
My acer compuer screen has moved clockwise. Please tell me how to return it upright. I have tried Control and comma/ period keys but it hasn't helped. Thanks
An upside down image - this is caused by unintentionalpressing Ctrl-Alt plus the down arrow key. Restore by pressing Ctrl-Alt plus the up arrow key. ALSO To change the display from portrait to landscape Press Ctrl-Alt plus a left or right arrow key.
Mar 25, 2011 | Computers & Internet
How could i change the ip addres my hp 4015n ?
Configure the network product View or change network settings
1. Type the IP address into the address line of a Web browser to open the embedded Web server. 2. Click the Networking tab to obtain network information. You can change settings as needed.
Manually configure IPv4 TCP/IP parameters from the control panel In addition to using the embedded Web server, you can also use the control-panel menus to set an IPv4 address, subnet mask, and default gateway. 1. Press Menu . 2. Press the down arrow to highlight CONFIGURE DEVICE, and then press OK. 3. Press the down arrow to highlight I/O, and then press OK. 4. Press the down arrow to highlight EMBEDDED JETDIRECT MENU, and then press OK. 5. Press the down arrow to highlight TCP/IP, and then press OK. 6. Press the down arrow to highlight IPV4 SETTINGS, and then press OK. 7. Press the down arrow to highlight MANUAL SETTINGS, and then press OK. 8. Press the down arrow to highlight IP ADDRESS, and then press OK. -or- Press the down arrow to highlight SUBNET MASK, and then press OK. -or- Press the down arrow to highlight DEFAULT GATEWAY, and then press OK. 9. Use the numeric keypad, or press the up arrow or the down arrow to increase or decrease the number for the first byte of the IP address, subnet mask, or default gateway. 10. Press OK to move to the next set of numbers. To move to the previous set of numbers, press the back arrow . 11. Repeat steps 9 and 10 until the IP address, subnet mask, or default gateway is complete, and then press OK to save the setting. 12. Press Menu to return to the Ready state.
Jan 14, 2011 | HP LaserJet P4015N Printer
Subtitles always on
Hi - welcome to FixYa,
There are 2 methods for changing the subtitle settings on your DVD player.
Method 1.
To turn off the subtitles on your DVD player during playback:
1. Press the "SUBTITLE" button on your remote control
The subtitle button is just below the "0" (zero) numerical key on the remote control. It is marked "SUBTITLE" above the button and the button has "ABC" written inside a white rectangle on it.
2. Use the left "<" and right ">" arrow keys to change the subtitle setting
Each time you press an arrow key the subtitle language will change and eventually the language will read "OFF". The subtitles are now switched off during playback.
Method 2.
To turn disc subtitles off from the main menu:
1. Press the "MENU/LIST" button on your remote control (directly below "STOP")
The main menu will now appear
2. Press the down arrow key on your remote once to highlight "A" in the left hand column of the main menu
3. Press the right arrow key on your remote once to move to the right-hand column of the menu
4. Press the down arrow twice to highlight "Disc Subtitle"
5. Use the left and right arrow keys to change the subtitle options until your required choice is displayed
6. Once set, press the "MENU/LIST" button again to exit the menu.
This should solve your problem, but if you need any further assistance, please post back.
Regards,
BElectric
Nov 21, 2010 | LG RH-4820 DVD Recorder
How Do You Finalize the DVD after Recording it?
On remote control press 'Setup' button;
'DVD Video Setup' tab will be highlighted;
Using arrow keys around the 'Enter' key, press right arrow once to move to adjacent tab called 'HDD/DVD Setup';
Press down arrow once to move to 'HDD Setup' tab;
Press right arrow to move to 'Disc setup' tab;
Press down arrow to highlight 'Finalise' button;
Press 'Enter' and follow on screen prompts.
Dec 21, 2009 | JVC DR-MX1 DVD Recorder/VCR
How do you reset forgotten parental control password?
Disconnect power to the TV. The power interruption will allow you to reset the parental control password to the default password of 0000.
To change the password after disconnecting the power, do the following:
1. Press the Menu button on the remote.
2. Arrow up / down to SET LOCK CODE
The lock icom will appear
3. Arrow left / right to operate
4. Press 0 to access the lock code
5. The first digit will be highlighted.
Arrow left / right to select the number
Arrow up / down to move to the next digit
4. Continue to follow these directions for all 4 code numbers.
5. Arrow up / down to FINISH
6. Arrow left / right to save settings and exit.
The password has now been reset.
Nov 29, 2007 | JVC AV-36260 TV
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
