Question about Logitech Wireless Xbox GamePad Cordless Game Controller - 963279-0403
Logitech Cordless Controller for Xbox not working.
Logitech Cordless Controller for Xbox is not working the batteries work fine and when I press connect it doesn't work the light is on but it doesn't work do I have to hold the buttons down if so which one's
Please help..
  • nobead746 May 24, 2008
    IT JUST KEEPS FLASHING WHEN I TURN IT ON
    Problem Solver:
  • 10 Answers
It looks like you may have to change your controller for a new one
Posted on Nov 18, 2007
X box controller keeps turning itself off - I have put new batteries in
Connection problems might be caused by one or more of the following factors:
  • Weak batteries or a weak Xbox 360 Rechargeable Battery Pack
  • Interference from another wireless device, such as a microwave oven, a cordless phone, or a wireless router
  • Metallic objects positioned between the console and the wireless controller, such as a chrome faceplate or metal dividers, shelves, or doors on an entertainment center cabinet
    Note All licensed Xbox 360 console faceplates are tested for interference, and do not interfere with licensed wireless devices.
  • There are already four controllers connected to the console.
uparrow.gifBack to the top THINGS TO TRY Solution 1: Restart your console Turn your console off, wait a minute, and then... Solution 1: Restart your consoleTurn your console off, wait a minute, and then turn it on again.
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 2: Replace the batteries or the Rechargeable Battery PackInsert fresh AA batteries, or attach a fully charged Xbox 360 Rechargeable Battery Pack to your controller. If you have an Xbox 360 Rechargeable Battery Pack
  • Remove the battery pack and reattach it to your controller, making sure that it is attached correctly.
  • Press and hold the Xbox Guide button. In the upper-left area of the Xbox Guide button, the battery meter indicates your current level of battery strength. You might need to recharge the battery pack, if the level is low.
If you have an Xbox 360 Play & Charge kit
  • Make sure that the Xbox 360 Rechargeable Battery Pack is correctly connected to your controller and plugged into one of your console's USB ports. If you check both of those things but are still having the problem, try the suggestion below.
  • Plug the charge cable into each USB port on your console, one by one. There are two USB ports on the front of the console and one on the back. If the controller works in one USB port but not another, try another accessory in the USB port that did not work with the controller. If the USB port does not work with any accessory, your Xbox 360 console might need to be repaired.
  • Turn off vibration feedback (rumbling) on the controller. If you play games with feedback while charging, it takes longer for the controller to charge and might drain the battery pack faster than it can recharge. Here's how to turn vibration off.
    1. Press the Xbox Guide button on the controller.
    2. Go to the Settings area, and then select Preferences.
    3. Select Vibration.
    4. Select Enable Vibration to clear the checkbox.
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 3: Remove objects between the controller and the consoleThe controller works within 33 feet (10 meters) of your console. However, objects placed between the controller and the console might reduce this range. In addition, objects that use wireless technology (for example, a cordless phone) can interfere with your wireless controller. Remove or relocate objects or wireless devices that might interfere with the wireless controller or console. Here are some things that can cause problems:
  • Microwave ovens
  • Cordless phones
  • Wireless routers
  • Chrome faceplates
  • Metal dividers
  • Shelves
  • Doors on an entertainment center cabinet
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 4: Disconnect all controllers and headsetsIf all four rings surrounding the power button on the console are green but the controller has four flashing green lights, four controllers might already be connected to the console. Disconnect all of the controllers, and then try to connect the controller with the problem.
  • To disconnect a wireless controller, press and hold the Xbox Guide button for three seconds, and then turn the controller off.
  • To disconnect a wireless headset, turn the headset off.
  • To disconnect a wired controller or headset, unplug its cable from the console.
To learn more about connecting your wireless controller, please read the following Knowledge Base article: 906947 (http://support.microsoft.com/kb/906947/ ) How to connect an Xbox 360 Wireless Controller to an Xbox 360 console or computer If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 5: Replace your controllerIf your controller still does not work correctly, it might need to be replaced. Please contact Xbox support at the following address: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) uparrow.gifBack to the top Additional supportPlease visit the following Web site for information about how to contact Xbox support: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact)
Dec 05, 2010 | Microsoft Xbox 360 Controller
Logitech Cordless Action Controller for PS2 will not work, and receiver is blinking fast/steady green.
take batteries out control and put back in...turn off ps2 and while holding the button on the ir piece connected to ur ps2..turn it on and dont let go till game has fully come on...should work..if the red controller light still keeps blinking after doin it a few times then change your batteries
Mar 08, 2009 | Logitech Cordless Action Controller for...
Receiver blinks green, wireless controller blinks red and does nothing
hold in the button on the top of the receiver until it is a solid green then press any button on the controller
Oct 30, 2008 | Logitech Wireless Xbox GamePad Cordless...
Juiced 2-dual action controller not working
Download the xpadder from the website http://xpadder.com/ and you are set, works fine with my Logitech rumblepad 2 on Juiced 2 no problems. I don't see that it wont work on Logitech Dual Action controller, it is on the list of controllers that xpadder support
Feb 06, 2008 | Logitech Dual Action for Pc (963292-0403:)...
Vibration on Logitech Wireless Xbox (not 360) Controller
when you play a game go in option menu you will see vibration on off press on the button and you should feel vibration cheers
Jan 17, 2008 | Logitech - Cordless Game Controller...
Logitech wireless controller for PS2
make sure you put batteries in the controller
also if you bought a new controller cuz you lost your old card or something take the batteries out of the old one itll interfere
and you have to press an action button on the controller
(the x,circle,square,and triangle buttons)
if all else fails use your old dual shock and trade the cordless into gamestop for a used controller
(if it wont work theyll replace it for free)
Jan 03, 2008 | Logitech - Cordless Game Controller...
Logitech Cordless Rumblepad 2 connection problems
 The 5 + 7 buttons work for teh OLD versions that take FOUR batteries and have the RED Logitech logo.
The New versions, which use TWO battreies has an ORANGE logo use buttons 6 + 8 to reset sticks.
Whatever postition the sticks are in when that battery is put back in will be condiered new calibrated center.
From Logitech:
To re-calibrate, please do the following:
Remove one battery.
Hold the six (6) and eight (8) buttons simultaneously while re-inserting the battery. (NOTE: Do not touch or move the mini-joysticks at all during this time. It is very important that the mini joysticks are allowed to center themselves during this step or the calibration procedure will not be successful.)
The mini-joysticks should now be re-calibrated.
Jan 01, 2008 | Logitech Cordless Rumblepad 2 Vibration...
Logitech Cordless action controller 2.4 ghz is not working
Try Blowing into the peice that plugs into the playstation or whatever you have, after that, blow into the port that you would plug it into, sometimes dust gets in there. Good Luck. -JD
Apr 01, 2007 | Logitech Cordless Action (9633200403) Game...
Logitech Wireless Xbox GamePad Cordless Game Controller - 963279-0403 Logo
365 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
