Sewing Machines Logo
Lynn Lawrence Posted on Jan 02, 2016
How to thread rex rx 1804 sewing machine - Rex Sewing Machines
1 Related Answer
MissFixIt828
  • 70 Answers
  • Posted on Jan 08, 2015
SOURCE: WHERE CAN I BUY A WALKING FOOT FOR MY RX-1804.
The Janome even feed foot will work with your machine
http://janome.com/en/accessories/sewing-machine-feet/even-feed-foot/
Testimonial: "helpful but which model number should I use"
tip
I am looking for a manual for The Rex 1804 need to know where to oil it
The rule of thumb about oiling your sewing machine is to put one drop of oil (sewing machine oil only, please!) wherever one metal part moves against another. Do that, and you won't go wrong. You can also look for the oil ports -- small holes in metal gears and housings--I've posted a good photo at www.robbiesews.blogspot.com--where you put one drop of sewing machine oil. Don't use oil on the gears themselves--use sewing machine grease instead.
Oil ports and places where metal moves against metal can be found in three locations: on the top of the machine, under the cover; on the bottom of the machine; and behind the access door (or panel) on the left side of the machine head.
Here's a generic sketch:
Note: Please refer to your sewing machine manual to see if your machine is self-oiling. If it is, disregard this note--you do not oil those machines.
on Jun 18, 2011 • Rex RX-1804
1helpful
How to adjust the bobbin timing on a Rex Sewing Machine, model 26-188
Why dont you tell me how to get a manual for a REX USA Rx 1804 manual? This seems like a unfortunate site.
2helpful
Jan 08, 2015 • Rex RX-1804
Top thread keeps breaking
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Aug 02, 2012 • Rex RX-1804
Rx-1804 manual
try these sites--you may have to email these sites about a manual
ebay
sewingpartsonline.com
sew4less.com
sewusa.com
sewvacdoctor.com
a1sewingmachines.com
May 10, 2012 • Rex RX-1804
Instructions for rx-1804
go to the website of sewvacdoctor.com & email the about a manual
Mar 02, 2012 • Rex RX-1804
Rex rx- 1804 bobbin case
check with the sewvacdoctor.com
Feb 21, 2012 • Rex RX-1804
Top Rex Sewing Machines Experts
vince
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Rex Sewing Machine Expert? Answer questions, earn points and help others
