Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Frig has stopped making ice.
Although the frig dispenses the drinking water, the frig has stopped making ice. Yes, the door is complete closed. Any Clues?
    Champion:
  • 363 Answers
Open the left door open the ice maker door, up in the left hand corner you should see a green light, check to make sure that you have a selection chosen(either small of large cubes.
Posted on Jul 21, 2009
HI I hope I have reached Sea Breeze because I see someone had the same or similar problem as we are having from our GE GSS25... side by side refrigerator. this person wrote: "Water now comes out but only...
You have a bad main control board . Located behind the refrig , behind an 8 X 10 " panel . Easily replaceable . Sorry , not Seabreeze . You can reach him at seabreeze appliance parts . com , I think .
Sep 08, 2010 | Refrigerators
Water dispenser stopped working. Ice maker works.
Some of these ge frig have a problem with water freezing inside the door and so the water dispenser wont work. only way to be sure it to turn off your frig for about a week and leave the doors open. plug in then try the water dispenser. if this is the problem call g.e. you will need a special kit to solve this problem. it dispenser still doesn't work replace water valve!!!
Mar 22, 2010 | GE Refrigerators
Very slow drip from water dispenser. How do I fix
Good day,
A slow continues drip, but still dispenses O.K. is caused by the dual water valve on the bottom rear of the machine not closing completely.
Only fix is replacing the water valve assembly.
Mar 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Why is water pooling under the crisper drawers? someone mentioned a humidity problem but there aren't any controls so what do I do? whirlpool ET18GMXHW0
Check the water reservoir behind the crispers for a leak. It could be a clogged defrost drain also. If you keep a jug of drinking water in the frig check closely for a pinhole. These are my first places to look.
Eric
Feb 01, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker and water dispenser not working
well there is two things it could be low water pressure or ur ice maker is defective try replaceing the ice maker this should work if not u need to get a frig repair man out to help u because if the problem is in the frezzer door it is not easy to fix on ur own
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Water dispenser will not work when lever is pressed. we had an intermittent problem with it before it stopped working altogather.I was going to look at it but was afraid to pop off the trim on the outside...
This could be a bad water valve in the frig. This frig has a double water valves. One for the ice maker and one for the water dispenser. It should be in the lower back. Where the water line goes in. You can check this valve easily. Find the double water valve on the frig. Turn off water supply to frig first. Swap the plastic water lines going from the water valve into the frig. Turn water supply on. Then see if the water dispenser works. Sometimes you will have to operate the water dispenser for a little while to get the air out of the line. If it works now then the problem is in the water valve solenoid and needs to be replaced.
Nov 08, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker freezing up
The problem is in the water valve.
The water supply line going to the Ref is connected to a water valve. This valve is not shutting off completely which causes water to drip into the ice maker. This dripping will freeze and eventually completely block the fill tube in the freezer.
Aug 23, 2008 | Whirlpool ED2FHSS Side by Side...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
258 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
