Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
My monitor display is side ways on the screen
    Scholar:
  • 112 Answers
Hold Ctrl & Alt then press the up arrow of the curser controls (next to the right shift key, below enter).
Posted on Jul 15, 2009
  • Randy Fitz Jul 15, 2009
Screen to dark don't now how to ajust
Two ways: buttons on the monitor (often hidden on the side of the display); or display settings on your computer (move your mouse cursor to an open area of the screen and right-click to bring up the menu).
I'd try the switches first.
May 29, 2015 | Computers & Internet
Samsung sa850t monitor right half of screen is solid blue
I think your Display monitor cable damage, or may be your motherboard display cheap damage, or your display driver problem create.
First of all you check your display driver or reinstall driver. Sec think used external VGA card or check it. If not solved then your monitor display section damage. So contact good monitor technician.
Thanks..
Feb 03, 2014 | Samsung SyncMaster Computers & Internet
Toshiba m35x starts /stops intermittently with no power to display monitor
By whom Kathleen? You?
I ask because there are two ways to answer this;
1) You performed the procedure, and less for me to post.
2) You did not perform the procedure, and I need to explain from the beginning; using a diagnostic flowchart, pictorial guidance, and guidance from me.
While I wait for your reply, suggest perform this simple test first;
Laptop OFF, monitor OFF, attach an external monitor;
1) VGA monitor to RGB (VGA) port on left side of laptop.
Can use a CRT type of monitor (Looks like a small TV), or flat LCD screen monitor if it has a VGA cable.
http://en.wikipedia.org/wiki/VGA_Connector
OR;
2) S-Video port on left side of laptop for TV, or external video display device
http://en.wikipedia.org/wiki/S-Video
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external monitor. (Display device)
If not there are 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external monitor
3) External monitor ONLY
Press, and hold the Fn key down, and at the SAME time tap once on the F5 key.
The F5 key is the Display Toggle-Over key.
Still no?
Hold the Fn key down again, and tap once more on the F5 key.
Display on external monitor means there is a problem with;
A) Video Cable
B) screen Inverter
C) LCD screen
Which means if computer display was working correctly before;
1) Whoever repaired it could have used the external display option, and it needs to be set back to internal
2) The Video Cable connections are not tight, not correct.
Loose at motherboard, screen Inverter, or LCD screen.
3) Anti-Static Procedures were NOT followed, and laptop is now an expensive paperweight.
Post back in a Comment.
Regards,
joecoolvette
Apr 05, 2013 | Toshiba Computers & Internet
Display half of screen
screen back light on the other side is busted which need replacement.
Jul 14, 2012 | Computers & Internet
Screen monitor images on the righ side is not showig.
Hi afcarrillo,
This could be a simple resolution problem. By that I mean that the resolution is set too low, therefore putting things off screen. Here's how you change the resolution:
Windows XP
Right click the Desktop and select Properties. Click the tab all the way on the right that says settings, and drag the slider to your native resolution of 1600x900
Windows Vista
Click Start, Control Panel, Appearance and Personalization, Personalization, Display Settings and drag the slider to 1600x900
Windows 7
Simply right click the desktop, select Screen resolution and pick 1600x900
If you do not have a resolution problem, then it's most likely the monitor itself. Most often times you can fix it one of two ways:
1. Some monitors have a button that says "Auto" which will auto adjust your monitor. If you have one, try it.
2. If that didn't work or you don't have one, go through the monitor's OSD (on screen display) and work through the settings so that you can manually adjust it and set it to your taste.
Hope this helps :)
Nov 29, 2009 | Acer Computers & Internet
I JUST CONNECT A SECOND MONITOR TO MY EXISTING RADEON 7500. I ALREADY SETUP THE 2ND MONITOR ON THE DISPLAY PROPERTIES ( WINDOWS XP) I CAN SEE THE MOUSE MOVING FROM ONE MONITOR TO THE OTHER, DOES ANYBODY...
you'll have to drag them windowed to your 2nd monitor. Windows automatically will use your primary monitor unless you use software to control where which programs will load.
A good program to use is called Ultramon.
Sep 02, 2009 | Dell RADEON 7500 AGP Graphic Card
Monitor will not display
Your display app controls that, try updating drivers/ software for graphics card on laptop.
Or press the monitor button (usually Fn + something) till it comes right
Aug 08, 2009 | Compaq Presario 705US Notebook
1440x900 Monitor seems to think it is a 1680x1050 screen @ >19"?
Try reinstalling the video driver (Control Panel - System - Device Drivers - Video ... ) Good luck
Jun 13, 2009 | ViewSonic VA1930WM LCD Monitor
Horizontal display size adjustment
Make sure the video resolution is set to 1024x768.
Right click on a blank area on your desktop. click properties>settings.
Oct 03, 2008 | Acer AL1511 15" LCD Monitor
ViewSonic N1700w with Black stripe on right side of display
Sounds to me that you have a bad connection/wire to the CCFL bulb on that side of the display. Should be an easy fix, do it your selfer thing.
Dec 27, 2007 | ViewSonic NextVision N1700w (Black,...
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
133 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
