Question about Refrigerators
Freezer thawed, fridge leaking. Our refrigerator
Freezer thawed, fridge leaking. Our refrigerator is only 5 years old. Any suggestions?
  • 30 Answers
Without a type of Freezer, I take it it's a froze free type ? Check the drain for food clogging it or the drain pan and hose to it ( may have a hole in pan or hose. Wrap everything but be sure to clean the unit from food that lays at the bottom .
Posted on Jul 15, 2009
Model GX5FHTXVB03 - Bottom Freezer - ice buildup in the bottom that leaks on to the floor - Ice maker is NOT connected (no water supply to the refrigerator)
Our Amana/Whirpool fridge is 5 years old and this just happened for the 2nd time. As previous posters explained, the defrost drain tube is likely frozen. Remove all food from the fridge and freezer and unplug it for a day. This will thaw it out. Take the opportunity to clean it inside and out (wipe the interior, vacuum the condenser coils underneath). It may leak on the floor if the drip pan overflows after it thaws, so keep a towel or rag handy. I got this advice from a nice lady at the Whirlpool service number, so this is a common problem. She saved me a service call :-)
After a day, plug it back in and reload it. It should work OK. Not necessary to check circuit boards, pump air into the tube, etc unless it still doesn't work It helps to have a 2nd refrigerator handy, in my case a Maytag/JennAir that doesn't have this problem. Note that newer Maytags are Whirlpools also. I will not buy another one of these.
Oct 27, 2013 | Whirlpool GB2SHKXL Bottom Freezer...
My fridgedaire fridge FRT856embg wont get cold on the bottom
Im not familure with this item but on the older style fridge ice would build up in the freezer blocking the air ways to the bottom half of the fridge in this case you would need to remove the food from the freezer and fridge and unplug it open the doors and let it thaw out for a day or so I wish you luck and I hope this was helpful
Dec 07, 2012 | Frigidaire FRT21H8 Top Freezer...
My frezzer is thawing out the fridge is 5 or 6 years old
is it an auto defrost ifso remove the prear pannel inside the freezer compartment if it is full of ice then the auto defrost has stopped working you can thaw it out and it will work again for so long but will need to be defrosted manually again or it will do the same
May 30, 2011 | Refrigerators
Whirlpool, water puddles on top shelf of fridge
If it is not from a plugged or misaligned defrost drain tube, then it is always from air leaking into your refer section. Check you door gasket to see if it is sealing correctly all around your door. Make sure your door is shutting tightly every time. Good Luck, Appliance Specialists.
Jan 17, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer not freezing
you may have defrost problem or check fan by compressor
Apr 04, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Slow dripping water from top freezer into the main fridge
We just got rid of our 26 year old Kenmore for this reason. In 26 years I used a hair dryer to thaw out a tube toward the back of the refrigerator. At least in ours when the tube gets frozen shut the water had nowhere to go but in our egg tray.
Oct 23, 2008 | Whirlpool Refrigerators
Freezer only cool, fridge not cold as well
it sounds like the relay on the back of the unit may have gone bad.or the compressor has a leak in the line...call a tech out and have it checked...it may be cheaper to get a new fridge
Aug 22, 2008 | Kenmore 53642 / 53644 Side by Side...
Water leaking from freezer down back wall inside fridge
Defrost water from a top freezer models exits the cabinet in the rear. This drain line may be plugged.
May 07, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
