Question about Amana SCRATCH&DENT 25 Cu. Ft. French Doors Refrigerator (BLACK COLOR) AFD2535DEB
JUST BOUGHT AMANA BOTTOM FREEZER, MODEL#AFD2535DEB USED. THEY SAID IT WORKED GREAT, BUT REFRIGERATOR DID NOT GET AS COLD AS IT USED TO. THEY SAID THEY BOUGHT IT AT END OF 2005. APPLIANCE STORE SAID THE PUMP WAS GOING OUT. PLUGGED IT IN LAST NIGHT AND PUT ON COLDEST SETTINGS FOR REFRIG AND FREEZER. FREEZER FROZE WATER BOTTLE OVERNIGHT. THIS AFTERNOON, PUT ICE CREAM AND FROZEN VEGETABLES IN FREEZER. AN HOUR LATER, ICE CREAM WAS SOFT AND VEGETABLES STARTED TO THAW. FAN IS WORKING IN FREEZER, BUT DOESN'T FEEL REAL COLD AND REFRIGERATOR IS KIND OF COLD, BUT IT ALSO SEEMED TO LOSE COLDNESS WHEN FREEZER STARTING DEFROSTING STUFF. WHAT DO YOU THINK THIS IS?
  • 52 Answers
Sounds as if you have a bad timer or a cold control They can be replaced. Most likely it is the cold control
Posted on Jul 15, 2009
I have an amanda 25cubic Model #afd2535deb. The bottom freezer works just fine but the top half of the refrigerator gets warm. What I notice is in back of the bottom freezer is the coils have frosted up...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
-0--0
Mar 13, 2011 | LG LRFC22750ST French Door 22.4 Cu. Ft....
Bottom freezer working great, top not cold
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Oct 16, 2010 | Amana ABB1927DE Bottom Freezer...
Refrigerator is not getting cold
the evap fan motor sounds like its not working . replace the fan motor and the defrost terminator .. ..mm
Jul 01, 2010 | Amana ABB1927DE Bottom Freezer...
I have an amana afd2535deb the freezer stays cold but the fridge is warm and i feel no flow from the fridge bottom vents
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Sep 24, 2009 | Refrigerators
Fridge not getting cold enough
The cold from the freezer is piped up to the refrigerator and if that tube gets clogged with frost or ice it will not be able to blow to the cold air into the refrigerator area. I took everything out, unpluged the unit for about 6 hours, till all the frost from the freezer was gone, wiped up all moisture and turn it back on. It worked!
Aug 03, 2009 | Amana ABB1927DE Bottom Freezer...
Amana ARB2214CB refrigerator fan not working?
the fan is locted in the freezer and it blows up to the ref and it sounds like the fan quit working and needs replace to check it the be for sure take the back panel off and with the ref running test the leads to the motor and make sure you have 110 volts if you do it is a bad motor
Jul 07, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
May 25, 2009 | Amana ABB1927DE Bottom Freezer...
Amana side-by-side refrigerator/freezer
raise the front legs/rollers so unit is tipped back slightly.its ok if it opens as long as it closes.
Aug 07, 2008 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
Refrigerator not cooling
-check your thermostat setting at refrigerator it should be at cold. Same digital control they have separate settings.
- Check also the vents of your unit for obstruction.
Jan 13, 2008 | Refrigerators
Amana SCRATCH&DENT 25 Cu. Ft. French Doors Refrigerator (BLACK COLOR) AFD2535DEB Logo
422 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
