Question about FUJIFILM Cameras
Fujifilm finepix s9500 won't turn on with new batteries works in picture viewer with power adaptor but as soon as I turn switch fully on to take picture the camera just turns off
    Top Expert:
  • FUJIFILM Master
  • 9,098 Answers
Hello my FinePix S9500 will not power up, i have - Fixya
www.fixya.com/support/t4079670-finepix_s9500_will_not_power_up
Feb 8, 2010 - Question about Fuji FinePix S9500 Zoom Digital Camera ... Mine willswitch to 'picture view' but when I turn the switch to 'camera' it all just ...
Fugi 9000s camara fix( won't turn on) - YouTube
? 1:17
https://www.youtube.com/watch?v=Hb8jiWFfXQs
Jul 1, 2013 - Uploaded by wakohelliott
Fugi 9000s camara fix( won't turn on) .... FUJIFILM FINEPIXXP50 - Head's UP - My New Camera - Full HD - Water, Shock, Freeze, Dust Proof ...
fujifilm finepix s9500 wont turn on ' Fuji X Forum
www.fujix-forum.com/.../fujifilm-finepix-s9500-wont-turn-on.49929/
1 day ago - Hi I am new on this forum and new to bridge/DSLR cameras I have been given a fujifilm finepix s9500 and it will not power on I have tried ...
Posted on Jan 02, 2016
SOURCE:
  • 188 Answers
SOURCE: Power/lens Problems
it seems that the lense movement is jammed. Have you dropped the camera? just have a close look from the front side of the camera, does the lense assembly seems to be pressed or moved aside by some extra preassure? if no physical disalingment is visible may be some sand or dust partical is obstructing the movement of the lense assambly. needs a help from camera repair shop.
Posted on Sep 14, 2006
SOURCE: fUJIFILM FinePix A360
my A360 digital wont turn on it flashes green then goes off i put new batteries in it
Posted on Sep 30, 2008
SOURCE: My Camera Won't Turn ON
I'm one who had the same problem but I just noticed that if I hold my finger down firmly on the "ON" button for a few seconds the camera finally turns on. Please let me know if this also works for you. Maybe it's the answer for all of us!
Posted on Mar 19, 2009
zohail
  • 1223 Answers
SOURCE: i have a fujifilm finepix S5000 when camera is
if u see white screen and lcd show info and signs and pictures also turn out to be blank when u see them on pc
CCD Failure has occured !
dont worry i have the same problem with my S5000 i contacted fuji and they repaired it free of charge bcoz it is a known problem in thousands of cameras of different brands just call them in ur area and they will do it free of charge
see this
http://www.imaging-resource.com/badccds.html
for support in usa or select different region www.fujifilm.com
http://www.fujifilmusa.com/support/ServiceSupportContact.do
Posted on Apr 09, 2009
  • 244 Answers
SOURCE: fujifilm finepix v10 does not turn on. when
Fuse F351 has possibly blown on the board. It is a 2.5A 32v UL type surfacemount fuse which is soldered to the board. The fuse has a coded letter on it for identification. Recomend you find someone who knows electronics to repair
Posted on Jan 03, 2010
Fujifilm xp30 that won't turn on.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Dec 16, 2011 | FUJIFILM FinePix XP30 Digital Camera
My fujifilm J10 will not turn on with a fully charged battery and my battery will not turn on any other fujifilm j10.
Hi, It sounds like your battery can't hold a charge anymore. My suggestion would be to get a new battery for the camera and then it should work fine.
May 12, 2011 | Fuji FinePix J10 Digital Camera
Fujifilm FinPix S9500 Spares Where to buy a
This is a non essential part and does not have to be in place for the camera to operate properly. I would suspect that the part can be ordered through a Fujifinpix sales dealer. This little plastic cover on all my cameras is the first thing to be removed and lost.
Sep 09, 2010 | Fuji FinePix S9500 Zoom Digital Camera
I want user manual for the model finepix s9500
You can download/print your camera manual here:
http://www.fuji.fi/documents/12/S9500.pdf
Bill B
May 05, 2010 | Fuji FinePix S9500 Zoom Digital Camera
Hello my FinePix S9500 will not power up, i have tried new batterys, but still no power
Had the same problem. Was quiet desperate. But then I remembered that the last thing I did just before the apparent death of my dear camera was to remove and put back the CompactFlash card to transfer pics. That caused a pin on the card connector to be bent, making contact with the next pin. It wasn't easy to put straight, because the contacts are rather deep inside the shaft. But that was the cure. My FinePix came back to life.
Let's hope the same thing happened to you...
Feb 08, 2010 | Fuji FinePix S9500 Zoom Digital Camera
Low battery
As you have noticed, the battey is not charging completely which indicates a faulty battery. Too bad you didn't get it replaced when under warranty as they would have replaced it for you for free. ANyways you can get a replacement from here for about $14
http://www.wholesalebatteries.us/battery.cfm/hurl/Digital-Camera/FUJIFILM/FinePix-E550/PRO415-25.htm
Apr 21, 2009 | Fuji FinePix E550 Digital Camera
FujiFilm FinePix A500 screen turns off when trying to take a picture
I had the same problem with a fujifilm finepix... It didn't take pictures with 2 sony batteries, just turned off after pressing the shutter. Then I tried 2 panasonic batteries and it worked fine....
My solution: try panasonic rechargeable.
Oct 24, 2007 | Nikon COOLPIX P4 Digital Camera
Cameras Logo
415 people viewed this question
Top FUJIFILM Cameras Experts
Falling star
Marvin
Marvin
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
