Question about RCA D52W19 52" Rear Projection Television
Convergence issue while in HD
My television had always had an issue with auto convergence on some channels while trying to process graphics and such. This hasn't really bothered me until now. While on certain HD channels like Fox or ESPN I get a triple image. Three vertical images. Is this a progressive problem? Can I replace a board, look for blown caps or resistors. Any suggestions would be appreciated.
  • RCA Master
  • 8,617 Answers
I would try doing the alignment via the service menu for the HD formatt. You can get the CD at the following link which explains exactly how to do the alignment.
http://servicemanuals.vstore.ca/product_info.php/pName/itc222-convergence-and-geometry-adjustment-cd/cName/rca
Posted on Jul 15, 2009
Screen splits into 3 separate images not convergence
Make sure you re-adjust convergence in HD and non HD modes if your TV has HD
Mar 30, 2013 | RCA HD52W59 HDTV Projection Television
Green auto convergence
The master convergence settings have to be close for the Autoconvergence to work. If they are not you need a technician to go into the service menu and adjust them.This is a long job and you can't do it yourself.
Mar 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Pink and greenish lines creating a double picture
with your remote go to your menu and find convergence. Follow the instructions to auto set convergence. if that don't fix it the problem convergence panel if bad.
Mar 15, 2009 | Philips 55PW9363 55" Rear Projection...
Convergence problem
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
You can download the manual here. Insrtuctions for auomatic convergence are described. I copied the instructions below.
Automatic Convergence
Your HD Monitor’s picture tubes might have been disturbed during delivery or
after you moved the HD Monitor, causing the color in your HD Monitor to be
out of alignment. The colors adjust by starting auto convergence.
IMPORTANT: Auto convergence works best once the HD Monitor has
warmed up for at least an hour. If you've just unpacked your HD Monitor,
it's a good idea to repeat the Auto convergence function when the
HD Monitor's been running for at least an hour. See page 38 for more
information about Auto convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu
appears. The cross in the middle of the screen should be yellow. If it is not,
use the arrow buttons to move the red cross to overlap the green cross.
Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle
of the screen. If it is not, use the arrow
Sep 23, 2008 | RCA R52WM24 52" HDTV Projection Television
Top left side of picture blur
You may have to clean the crt's and lenses and the mirror. Unit may need total convergence from the service menu. If image is blurred in only one area like the corner I would suggest NOT to adjust the electrical or mechanical focus.
Aug 31, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence off on Digital Cable
convergence for the rca itc222 is set individually for digital and analog tuner. Most of time the set will have to be converge in service mode. as a tech i would not recommend getting intoservice mode. but the key is the the convergence has to be set indiviadually for each tuner. You could try autoconverging in digital or even manualy converging
Jul 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Right side convergence
A convergence IC has burned out. If I remember correctly, those Pioneer sets have one huge convergence IC, but that IC only has 5 channels in it so they use another smaller dual STK IC and one half of it is used for the 6th channel and the other half is the vertical output. Look on the convergence board, find the blue convergence jack, identify the blue horizontal channel, follow the traces and replace the IC handling the blue horizontal channel.
Aug 28, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Samsung HC-P4752W Blurry ONLY on HD Channels
Similar problem, then about 2 weeks later the SD convergence went out. Changes convergence Amps,,, Now I'm trying to learn what 2 red flashes mean now when I try to power it up,,, it flashes twice then shut down into standby mode,,, I got no picture after installing STK392-040 chips, thinking about trying another set as atleast I had blury picture before. No solder shorts of opens that I can find. TV has always been a pain,,, locking up once in a while such that you can't change modes,,,
Jul 22, 2007 | Samsung HC-P4752W 47" Rear Projection...
Convergence for HD channels only
Hello, please check the IC7102 (24LC64). This is eeprom that contains the convergence data. Please ask the Panasonic dealer if they can supply a replacement IC with the data for your HD. If you need more info please advice. Arpi
Jun 08, 2007 | Panasonic PT-51HX41 51" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
107 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
