Question about Solis SCDIG-5000 Coffee Maker, Espresso Machine
I have a solis 5000 coffee maker and would like to descale. the users manual says never use vinegar as it will harn the machine. It recomends a product called SOLIPOL, is there another product that you could recomend that I could use. Thanks, Rob
  • 1,089 Answers
Hi
Starbucks used to carry a descaling product for their machines. Yes don't use vinegar because it is only 5% before you dilute it. It also leaves a taste for about 2 weeks that will affect the taste of your coffee. You can use Citric acid. 1 tablespoon per 32 oz of water. Use at least 2 table spoons. Dissolve the descaling solution so there are no crystals left. Now.
Turn the machine off and then push and hold the 2 buttons at the same time. While holding them down, turn the machine on.
Release the buttons and turn the dial counter clockwise till it stops.
This will keep the machine from heating.
If you push the steam button the pump will activate.
Open the steam knob. Run 8 oz through the wand and rekease the button. Let it set for 10 minutes, then open the knob again. Repeat until the tank is empty. Rinse with a whole tank of fresh water and your done.
If you have the Digital there is a program in the menu for descaling. There is also a program for resetting the descal mode so it will tell you the next time it need to be done. Chose yes and push the enter button. Also change your water hardness to 4. Descale more often than not enough.
Posted on Jul 15, 2009
My Solis Master 5000 will not make a cup of coffee anymore. I already descaled, the water comes through the steam arm, but not through the coffee drip. How to fix?
If the problem is that water come from steam arm only,and if you try to make coffe is nothing happen- try to make several coffees with descaler liquid in the water tank.
Aug 31, 2017 | Solis Coffee Makers & Espresso Machines
How can I determine what parts I need to repair my espresso machine and where do I get parts and service?
Solis Master 5000 Espresso Machine - YouTube
? 9:49
www.youtube.com/watch?v=MjBmlQXElag Sep 2, 2010 - Uploaded by Day Tooley
I have been enjoying the Solis Master 5000 for a year. It's time to ... I haven't been able to find an actual user manual online...for some reason.
Nov 03, 2015 | Solis Master 5000 Espresso Machine
I have a solis 5000 and the temperature of my coffe is to low . How can i get o hot coffe ?
Descale it!! any water (even RO) will build up scale. Once a month is good and I use 4x filtered water
Oct 17, 2011 | Solis Master 5000 Espresso Machine
If we plug in the Solis Coffeemaker, the electrical circuit trips. What happened? It is a 5000 Espressep Machine. We always treated it with care.
Hi
I would suspect the boiler is leaking and shorting. Common problem when you don't descale on a regular basis or descale incorrectly. Any high temperatures during descaling will turn the gasket hard and brittle causing the leak. If not done enough the scale builds up and expands the boiler causing the leak.
Oct 26, 2010 | Solis Master 5000 Espresso Machine
Display says 'DECALCIFY'...I don't hvae the solution they recommend...what can I use to descale?
You should really use the solution that is recommended for the machine as damage could be caused to seals etc if you don't. The only other thing I have seen used is normal white vinegar but it takes a lot longer to work.
Jan 13, 2010 | Solis Master 5000 Espresso Machine
No water supply on Solis Master 5000 Manual
open steam valve and run water couple minuts,after try again if light show up again thats mean machine is somewhere clugged
Aug 23, 2009 | Solis Master 5000 Espresso Machine
SOLIS MASTER 5000
Try descaling your machine, because it may be clogged. Boilers heat up the water to produce steam. If descaling doesnt work you may have a boiler related problem.
Find descaler on www.CeriniCoffee.com
Nov 26, 2007 | Solis Master 5000 Espresso Machine
Manual
Here's the link; http://www.solis.com/pdfs/manuals/kaffee/MASTER5000_DIGI/MASTER5000_DIGI_ENG.PDF Hope this helps :)
Jul 02, 2007 | Solis SCDIG-5000 Coffee Maker, Espresso...
Solis SCDIG-5000 Coffee Maker, Espresso Machine Logo
247 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
