Question about Compaq Evo N610C Notebook
Laptop not charging
Hi, My evo Compaq laptop fell and the little pin in the power source got bent. Its not charging. What can I do?
  • Anonymous Nov 30, 2007
    I think in my situation the pin is completely broken. Is there any way I can replace that?
    Problem Solver:
  • 15 Answers
Newbi,
It sounds like the AC adapter connector on the system board is damaged. You need to determine the condition of the connector and its solder connections. The best way to determine this is by completely disassembling the laptop. Disassembling the Compaq Evo N610c is not as bad as some other laptops. You need to visually inspect the AC adapter connector. You may be lucky and just need to bend the pin an resolder the connections. If the connector is cracked it will need replacing and thats a problem. Finding spare parts is a real issue here. Find yourself another defective Evo N610c with a good AC adapter connector and swap the parts.
Posted on Dec 07, 2007
    Problem Solver:
  • 9 Answers
Unfortunately on most Compaq/HP mobile devices the AC pin is soldered directly onto the motherboard. If the pin is severely bent of broken off then a service is required, usually to replace the motherboard. Having the broken off like then can actually create a minor crack in the PCB. Sorry for the bad news.
Posted on Nov 30, 2007
    Scholar:
  • 127 Answers
If the pin is not completely remove...try to slowly straighten it if you can...please do this with caution if the pin is remove then you'll be having a big problem.
Posted on Nov 17, 2007
I have compaq evo N610c laptop, it works when plug power cable. battery also charging. but when i remove power cable computer shut down
Hi this may be due to your laptop battery problem. It may the time now to replace the battery of your laptop as it may go week now with time.
So very simple just go to any compaq service center and ask them for a new battery.
Nov 24, 2010 | Compaq Computers & Internet
How to get my laptop to charge.
If you battery is totally dead you need a replacement unit - remove the battery power the unit up using external power pack then refitt the battery - if it won't charge the battery is dead. get a new battery
May 19, 2010 | HP Compaq Evo n610c Notebook
Dropped Averatec 3200 laptop and it fell on the cord and bent the power source connection. Can I fix this or do I need to send for repair?
I've had this happen to me a few times. If the pin inside the laptop is bent, then there is no question that you'll need a warranty or shop repair on the laptop to fix or replace the power port.
If the power input coming from the power supply is bent, then you can try fixing it by pushing the plug back into place with a pair of pliers. If this doesn't work, then you'll need a replacement power supply or repair.
Apr 03, 2010 | Averatec 3200 Notebook
Works great on battery but will not charge or work on the Power Supply. The power supply is good. Problem seems to be the transistor in the charging circuit.
I had the same problem
eventualy the end fell off
i had a look at it and it turns out that the connector, after general use, snaps inside because the connection between the main wire and the connector got bent when i charged my laptop
i am now on my third charger and even that is dodgy
Oct 13, 2009 | HP Compaq Presario C700T Notebook
HP dv5400 laptop and external power source won't power up
Either your AC CORD or POWER JACK is BAD... Check if that's the case, if not, the worse senario is that the charging port can be shocked, which you will have to replace the motherboard...
Sep 26, 2009 | HP Computers & Internet
Battery installer
My compaq evo n610c have the following problem: "103 circuit charge failure" and use power AC only.
best regards
Sep 19, 2008 | Compaq Evo N610C Notebook
Evo n400c
Did you charge it for up to 8 hours?
Caring for your Compaq Evo N400c Laptop Battery You can improve the life of your Compaq Evo N400c Laptop Battery by doing the following:
When you first receive your laptop battery charge it fully for at least 6-8 hours and then discharge the battery fully by using your laptop unplugged from the mains until it runs down completely.
Repeat this 3 times to ensure your Compaq Evo N400c Laptop Battery will give you the maximum performance.
If you regularly use your Compaq Evo N400c Laptop on mains power for extended periods, removing the battery from your Laptop during these periods will extend the usable life of your laptop battery.
Apr 05, 2008 | Compaq Evo N400C Notebook
Battery not charging
Dont worry you can go through your problem by visiting the link below-
http://ftp1.us.dell.com/diags/R66243.htm#s1
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Jan 28, 2008 | HP Compaq Evo n610c Notebook
Compaq Evo N610C Notebook Logo
235 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
