Question about Dryers
Ignitor glows for about 6-8 seconds, then goes out without igniting anything. However, if it "rests" for a long enough time, it will ignite and the flame appears briefly in the heat box. Could it be a bad coil?
  • 8 more comments
  • lem_adm Jul 15, 2009
    Hi Vic, and thank you for your help. It is a 2000 year Whirlpool Gas Dryer, Model Number LGR4634JQO, Serial Number MK2813979.
    I had replaced a gas coil valve back in September 2006. Is it normal for them to go bad this soon?
    Symptoms appear to be the same as back then: Ignitor glows for 6-8 seconds without igniting anything, although if it sits long enough, sometimes it will ignite and you can see the glow in the heat box, which only lasts for about a minute. But it sounds like it wants to kick on (a cycling type sound).
    Thank you again,
    Larry
    Vic, yes, any assistance with replacing these is appreciated. For the life of me, can't remember how I did it back in 06'.
    Thanks again,
    Larry
    Thank you Vic for the assistance. It is much appreciated. Have a great evening,
    Larry
    Hi Vic, I did have one last question. How will I know which coil to replace (the 3 or 2 terminal).
    When I looked at the parts on line, it indicated that the 3 terminal was for "3 Terminal, 60 hz. Pilot Position", which the 2 terminal was for "2 Terminal, 60 hz., Main".
    Sorry to ask another question...just wasn't sure if they both need replaced or just one.
    Thank you again,
    Larry
    Thank you again,
    Larry
    Thanks Vic. That makes good sense so I don't have to repeat this exercise again. Murphy's Law!
    Take care,
    Larry
    Will do Vic. Thanks for the heads up!
    Larry
    Larry
    Hi Vic:
    Thanks again for all the great info. I saw the sleeve on the 3 wire coil, and made sure that went back on. The 2 wire coil did not have a sleeve. Is that correct?
    Thank you,
    Larry
    Thanks again Vic. My wife is happily drying clothes again!
    Larry
    President:
  • 1,136 Answers
It does sound like you will need to change the coils on yop of the gas valve. If you need insturction on how to get to the coils, please get me a make/model # so I can look this up and assist you.
Thanks
Vic
Posted on Jul 15, 2009
Testimonial: "Extremely helpful in guiding me to the correct answer!"
  • 2 more comments
  • Victor
    Victor Jul 15, 2009
    Larry, here are the instructions.
    UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
    If I can assist you further, please let me know.
    Thanks
    Vic
  • Victor
    Victor Jul 15, 2009
    Larry, Change them both. They come together anyways.
    Don't worry about to many questions, you need to be sure so ask away...........
    Vic
  • Victor
    Victor Jul 15, 2009
    Larry, Make sure the little sleeve inside the 3 wire coil gets put back on the gas valve post before you put the coil on. Sometimes it will slide off with the old coil. Very important.
    Vic
  • Victor
    Victor Jul 15, 2009
    Hi Larry,
    Yes, All is good......... Glad I could help.
    Vic
Oven slow to heat , oven burner goes on and off a lot, oven igniter glows....broiler works fine
Hello. I need the make/model number to help you accurately. It sounds like the bake ignitor is worn out and not consistently igniting the gas. How old is the unit? If it has more than a few years on it, the ignitor can wear--it might glow, but not enough to ignite gas. Remove the racks.Remove the bottom cover of the oven(usually there are 2 screws, right and left side at the rear, inside the oven. There usually will be a heavy steel flame shield held on by a single nut underneath the cover. Remove this shield. This will expose the ignitor(called a glow bar). One of the classic symptoms of a worn bar is that the center of the glow material will turn bright orange but not the rest of the resistive material. Also, you can test the viability of the bar using a meter. Normal amp draw on either of the 2 wires connected to it should have approximately 4 amps. Use a clamp-on voltage/ohm meter set to amps. Under normal conditions, the electric gas valve senses the current draw and will open, letting in gas to ignite. From activating "bake" to ignition *usually* takes 20 to 30 seconds. If you find yours is worn, HANDLE THE REPLACEMENT GENTLY. Don't knock it, drop it, or touch the resistive material. It is FRAGILE AND BREAKS EASILY(ask me how I know this!)The mount screws(usually 2) can become seized due to heat. Take your time removing them. Another symptom of a worn ignitor can be the "WHOOF" sound of too much gas building up in the oven prior to ignition. I've seen oven doors knocked open by too much gas saturation suddenly igniting from a slow glow bar. I hope I helped you!
Sep 07, 2015 | Kitchen Ranges
10 year old DCS Oven does ignite. Oven ignitor glows but maybe not enough to trigger LP from being introduced?
just because the ignitor glows it doesn't mean it's good,it takes 3.2 amps for the ignitor to open the gas valve and ignite the flame,usually if the flame doesn't ignite in around 40 seconds the ignitor is bad.also check the burner tube,your model number doesn't come up so i don't know if you have one or two ignitors in this oven but i've found that when the ignitor starts to fail and the customer waits to long to have it looked at the ignitor burns a hole in the tube and then both the ignitor and tube has to be changed,hope this helps and good luck with your oven.
Jul 19, 2013 | DCS RGU-486GD-L Range 48", 6 Burner,...
My Amana GUI090B30B furnace will not ignite. The ignitor glows then the valve releases gas but the gas does not ignite. The ignitor goes out and the valve shuts after a second or two of trying to ignite...
Hello, it is possible that even tnough the ignitor is glowing it might be too weak to ignite the burners. I would cneck the resistance of the ignitor with a multmeter, should be between 40-90 ohms typically
Nov 28, 2011 | Heating & Cooling
I HAVE PROBLEM WITH HEATER IS SWOING 1F IN THE SCREEN
YOur 1f code is actually a IF code which stands for "ignition failure".
This can be caused by many things, but the most likely is either the ignitor has failed, or the flame sensor has failed.
Make sure the gas manual gas valve is open. Remove from panel so that you can see the ignitor.
Turn off power, then turn back on. After 90 seconds, the ignitor should start to glow red hot. If this is not occuring, then it is likely the ignitor or ignitor wiring.
If the ignitor does glow, then the heater ignites, but still goes off showing the IF code, then it is the flame sensor.
If the ignitor glows, and the heater does not ignite, it is likely the gas valve or ignition control.
As stated above, the ignitor is most likely.
Dec 30, 2010 | Hayward H Series Pool & Spa Heater 400k...
I have problem with the heater is swow in the screen f1
Dec 30, 2010 | Hayward H400fdp Low Nox Propane Swimming...
Ignitor will lid for a few seconds
This is commonly caused by a weak igniter. Over time, the igniter wears out and does not draw enough current to open the gas safety valve on the burner assembly. This is a designed safety feature that prevents free-flowing gas from entering the dryer cabinet without ignition. The following link explains how these igniters work:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
I know the link is for a gas range, but the types of igniters and theory of operation is still the same. In effect, your igniter may have the appearance of working correctly by glowing, but it may be too weak for ignition to occur. I would recommend you try replacing the igniter.
If you have quesitons, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 28, 2009 | LG DLG5988 Stainless Steel Gas Dryer
Gas ignites but goes out after 15 or 20 seconds
Hello gdurawa
Welcome to Fixya
My name is Huum,
You said, upon starting my Kenmore gas dryer the igniter glows and the gas ignites, but the gas goes out after 15 or 20 seconds - clothes don't dry.
This means either the igniter is bad and not getting hot enough to make the gas continue to release completely and stay open, so it shut off.
or you have a bad gas module.
Or a bad gas valve without enough pressure.
Needs to be diagnosed hands on at your location .
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Jan 22, 2009 | Kenmore 63942 Dryer
Rheem Furnace sometimes takes a couple of ignition cycles before
Try cleaning the flame sensor. It is located right besides the last burner. Looks like a thick piece of wire. Take steel wool and gently remove the carbon that has built up. Should only take 4 or 5 strokes. Let me know how it goes after that. ken
Dec 23, 2008 | Heating & Cooling
Maytag gas dryer model#NDG2330AWW heating problem
your gas coils are bad. they open up for the first cycle but fail to after. Replace your coils and this will solve your problem
Dec 13, 2008 | Maytag Dryers
Dryers Logo
80 people viewed this question
Top Dryers Experts
