Question about Creative Labs ZEN V Plus MP3 Player
Zen v problem
Playback error appear in the screen,and i can't play any song,shut down the zen or do any thing
  • 4,402 Answers
Re: zen v problem
Have you tried installing the latest firmware? Version is 1.32.01.
Posted on Dec 07, 2007
0 characters
3 Points
Playback error
ok some mp3 players also read wma wich is an audio cd format wat u need to do is either convert the wma,s in to mp3s or just put nothing but mp3 formatted songs
Mar 07, 2010 | Creative Labs ZEN V Plus MP3 Player
Creative Zen V Plus Bookmarks
A little known feature on this player is the ability to use bookmarks, up to 10 of them. Many of you listen to podcasts or audio books which may be fairly lengthy and if you have to stop in the middle of what ever you're listening to, normally when you go back to your player you would have to start all over again.<br /><br />A note about <span style="font-style: italic;">"resuming playback":</span> If you shutdown during playback of a podcast or audio book (not pausing or stopping playback first) your Zen will automatically resume playback when you start it back up.<br /><br /><span style="font-weight: bold;">Zen V Plus Bookmarking</span><br /><br />You can insert bookmarks during playback. A bookmark helps you mark a point within a track, so you can return to it at a later time.<br /><br />You can use up to 10 bookmarks at any one time.<br /><br /><span style="font-weight: bold;">To insert a bookmark:</span><br /> <ol> <li>In the Now Playing screen, press the Options button and select Set Bookmark .</li> <li>For ZEN V Plus, you will need to press and <span style="text-decoration: underline;">hold</span> the Options button. Playback pauses and the Set Bookmark screen appears.</li> <li>Select a bookmark number.</li> <li>Your bookmark is assigned to the selected bookmark number. If all 10 bookmark numbers have been assigned, you can replace an existing bookmark with the new one or you can delete a previous bookmark.</li></ol><span style="font-weight: bold;">To delete a bookmark:</span><br /><br /> <ol> <li>Press and hold the Menu/Back button. The main menu appears.</li> <li>Select Music Library and then Bookmarks .</li> <li>Go to the bookmark that you want to delete.</li> <li>Press the Options button. For ZEN V Plus, you will need to press and hold the Options button.</li> <li>Select Clear Bookmark.<br /></li></ol><span style="font-weight: bold;">To go to a bookmark:</span><br /> <ol> <li>1. Press and hold the Menu/Back button. The main menu appears.</li> <li>2. Select Music Library and then Bookmarks .</li> <li>3. Select the bookmark that you want.</li></ol>Note: The Bookmark feature is not applicable for contents played from the memory card for players such as ZEN 2GB,4GB,8GB,16GB, 32GB and the ZEN X-Fi Series. ZEN Xtra also supports bookmarks though you cannot place two or more bookmarks for one song or audio book<br /><br />
on Jan 25, 2011 | Creative Labs ZEN V Plus MP3 Player
your player has the firmware of share type which uses it for your pc so load only 150 songs
Mar 02, 2009 | Creative Labs Zen V MP3 Player
Creative Zen screen is frozen on ZEN
If you have tried the reset hole on the bottom, try the mp3 player recovery tool here.
Feb 12, 2009 | Creative Labs Zen Digital Media Player
My zen wont play an y music
try sliding down the power button while holding down play and resetting the zen while the player is off, this should bring you to the zen format screen thing, select "clean up" if this doesn't work try selecting the other options from the zen format screen thing.
Jan 18, 2009 | Creative Labs Zen Digital Media Player
Creative zen says Playback error
I had the same problem: "Playback error", and nothing i did, helped. But when i pushed the reset buttom, below the on/of button, it turned of, and when i switched it on again, it worked. Maybe you could try again?
Otherwise I say this on YouTube, but thought it was a little drastic ;-)" />
Jul 25, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative zen vision M playback error
edit the play list again in the program provided, take only playable songs
Jun 26, 2008 | MP3 & Digital Media Players
Playback error
does it give you and error code? what does it say? can you go into recovery mode and do a clean?
Nov 19, 2007 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
75 people viewed this question
Top Creative Labs MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a Creative Labs MP3 and Digital Media Player Expert? Answer questions, earn points and help others
