Question about Homelite Consumer Products 4.0 Amp, 13 In. Trimmer
I have a sx-135 bandit. it was working fine then it stopped? i try to pull on rope to start but it froze. i used two cycle generic oil mixed with regular-un. gas does it need oil? or is the engine broken. just remember that i pull and pull and the little teeth inside the casing lock up.
  • 41 Answers
SOURCE: Picked up a Homelite SX-135 Bandit week wacker.
When you say, you pick up, you bought it or found it. Most likely it is a 2 cycle.
Posted on May 19, 2009
SOURCE: what is the gas oil ratio for a sx 135 homelite
is it so important to have the right oil ratio i have used a good grade oil and used a 50:1 ratio on all my trimmer, plows & ect. and had no problems cuz too
Posted on Jul 06, 2009
  • 279 Answers
SOURCE: Broken Primer Bulb
Get the model number and go to:http://www.psep.biz/store/homelite_trimmer_parts.htm
Posted on Sep 03, 2009
rycgl
  • 1545 Answers
SOURCE: what are the carberator settings for a homelite
If it's a Zama 2-stroke carb...the reference settings for the high and low speed needle jets are... turn them all the way in till they are snug and them bring them back out about 1 1/2 turns. (one and a half ) That is a good starting point for their carbs and should get it to start so fine tuning can be done.
Posted on Jul 10, 2010
rycgl
  • 1545 Answers
SOURCE: Where to find a replacement primer bulb for
Here is the part you need for your Walbro carburetor.
http://www.ereplacementparts.com/search_result.php?type=search-part&q=01201&manufacturer=Homelite
Posted on Oct 15, 2010
Homlite string trimmer sx-135 ut-20609 a ratio gas & oil mixture
You should mix 8 Oz. of two cycle oil to one gallon of gas. I put the oil in first and then the gas and it will be mixed and ready to go.
Jun 08, 2016 | Homelite Garden
Will not stay running
Very small 2 strokes need lots of compression,so keep the oil mix high,even as low as 22 to 1,should be 25 to 1,but take care mixing.scrape out all the oil and mix thoroughly.Each pull of the rope should be quite hard,and you should really feel each compression.if motor keeps on turning by itself after you've stopped pulling,it means compression poor,replace barrel,piston
Jul 24, 2014 | Poulan Pro 1129478 Weed Eater 952711557 0...
Restringing a homelite bandit trimmer
What is the correct size of the nylon cutting material - on my homelite bandit SX-135 trimmer ?
Thanks, Bill.
Apr 30, 2010 | Homelite Consumer Products 4.0 Amp, 13 In....
Oil change
STOP !
Your lawn mower is has a 4 cycle engine
It does not require oil to be mixed with the gas
The oil for the crankcase should be a 10W-30 or 10W- 40
NO GAS IN THE OIL
What you have is a 2 cycle oil that is mixed with gas for most weed eaters, chain saws, ect
Putting a gas/oil mix in your mower WILL severely damage it destroying the main bearings and could lead to an explosion or fire.
Please be careful
Apr 04, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Saw wont start
Think about joining the Army and tell your dad. This will take your dad mind off the saw while he is trying to change your mind to stay in school.
Actually 32:1 mix is richer than 50:1 meaning it shouldn't overheat the saw piston.
Is the gas fresh? Is the mix actually correct? It very hard to see a spark from a two cycle engine. You also need to pull the starting rope very fast for it to operate.
My guess the plug is fouled out it needs to be clean again or replace.
Sep 15, 2009 | Garden
My poulan chain saw sat for about 2 yrs with gas in it. I emptied the tank, put new gas in it along with a carburator cleaner but it will not start. lost the manual for it and don,t know which position to...
Empty out the gas and replace with proper gasoline mixed with oil in the proper proportion. Always use a good quality 2-cycle oil that contains a fuel stabilizer.
To start the generic chainsaw, follow these steps:
1. Pull the choke all the way out
2. Press the fuel bulb serveral times to prime the carb - you can feel when the fuel flows into it.
3. Set the lock on the trigger to full speed.
4. Now, pull the starter rope until the saw sounds like it tried to start.
5. Press the choke in to the 1/2 way position.
6. Pull the rope until it starts.
7. Release the trigger lock and push the choke all the way in.
If starting it when it is warn, skip steps 1 and 4.
It is unlikely that the spark plug is the problem. If you replace it without properly setting the gap, you may make it worse. If you start trying to adjust the carb without knowing exactly what you are doing, you will make it much worse, You can try spraying some carb cleaner into the carb and pulling the rope to such the cleaner into the jets.
In the future, always add fuel stabilizer or oil with a stabilizer to you gas/oil mix. This prevents the varnishing caused by aging gasoline.
Jul 11, 2009 | Poulan Garden
Lawn mower died. Pull rope locked up
remove the spark plug and try to pull the rope. Sometimes the coil can get loose and wedge against the flywheel. if that's not the problem then pour a little oile in the spark plug hole, let it set a bit, if it still won't turn over then you have an internal engine problems. Not very common but it can happen
May 09, 2009 | Garden
Homelite Consumer Products 4.0 Amp, 13 In. Trimmer Logo
190 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
