Question about Ryobi Backpack Blower 25.4cc
I pull the cord but it will not start, i have a Ryobi Backpack Bl
I pull the cord but it will not start, i have tried to clean the exhaust and a new spark plug but it will not even try to start,my arm is broken from trying to pull so many times i just want my blower to run!! please help me
  • 148 Answers
Ok that's half the battle. Probably the easiest thing to do is to clean the carb. So I would get some carb cleaner and using the little tube that comes with it spray into the high and low ports on the carb. Then spray in the outlet side of the carb.
Ps. Remove the little black and white caps and turn the screws on each while counting the number of turns to close (this way when you put the screws back in then all you have to do is count the turns to put them back at the factory settings). Now remove the screws and gently put the tube in each port and spray.
Also you may as well clean the filter with soap and water and let it dry. Once the filter dries take some fresh oil and drop a couple of drops on the filter and make sure it's has a small amount of oil in it.
Let me know how things go! Good luck!
Posted on Jul 16, 2009
Blower bogs down and kills at full throttle
Check the following, then clean or replace:
  • Fuel Filter - Located IN the fuel tank
  • Spark Plug
  • Spark Arrestor - at muffler port, creates resistance of exhaust flow, engine then bogs
  • Carburetor - may need a rebuild kit
Then watch this...
and...
Mar 31, 2013 | Echo Pb265l 25.4cc Gas Powered 158 Mph Low...
Ran last year, won't start this year. Changed fuel and replaced spark plug. Checked spark and attempted to start with battery and tried with pull cord but no start. pulled plug and it had fuel on it so...
It might have tipped over on its side. Look at the air filter, if you see oil or gas on the filter then you might have to remove and clean the carburetor. I would start by cleaning/replacing the air filter and trying it again. If its getting fuel and the spark plug works then the only other side of the fire triangle is air.
Jun 05, 2011 | Ryobi Backpack Blower 25.4cc
Blower will only run on full choke ryobi ry08578
They aren't designed to run with full choke on, the choke is for starting cold engines only, many times you can choke them pull the cord a few times and then turn the choke off or turn it down to start it. Then slowly reduce the choke until it runs fine on its own.
May 06, 2010 | Ryobi Backpack Blower 25.4cc
Ryobi Backpack Blower Elbow
the home depot stores sell ryobi so i think they might have it if not they sure can get it for you, or you can always go to the ryobi website and try purchasing it that way.
Jan 23, 2010 | Ryobi Backpack Blower 25.4cc
Ryobi backpack leaf blower about three years hard to start
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 24, 2009 | Ryobi Garden
MODEL RYO9600 LEAF PULLSTART BLOWER MISSING FLEX HOSE TO WAND
Go to this link for the Ryobi parts. You can get one for less than $5.
http://www.ereplacementparts.com/ryobihm-ry09600-backpack-blower-parts-c-7931_15636_130605.html
Oct 17, 2009 | Ryobi Garden
Low RPM's Ryobi 25.4 cc backpack blower
Remove the muffler and you should find that it will run at full speed. The muffler is clogged with carbon. You will have to replace the muffler since it is sealed. If you want the muffler cleaned you can contact southern supply company at 205-833-2525 or email them at
southern.supply@mindspring.com and I feel sure Jason or
someone there can help you.
Sep 03, 2009 | Ryobi Backpack Blower 25.4cc
Ryobi RY08576 25.4cc was started without mixed fuel
If the engine is sticky ie harder to pull it might have to be pulled apart new piston and honing of cylinder. not difficult just a pain. If it doesn't seem any harder to pull, Drain all of the unmixed fuel. Put a few drops of 2cylinder oil in the spark plug hole and pull the starter a few times with the plug out of it. Put a few more drops in repeat. Replace the plug (new plug) Put in mixed fuel prime the system cross your fingers and it should start up for you.
May 12, 2009 | Ryobi Backpack Blower 25.4cc
Ryobi RLT30CES
I also tried this.
  1. Clean the carb wire gauze air filter behind the roto-choke knob. (undo the nut/washers & long bolt)
  2. Deteremine if fuel is being fed to cylinder - Fully depress & prime the bulb about 7 times, turn to full choke. Pull start cord about 7 times. Remove spark plug see/smell fuel fumes/vapour present in cylinder
  3. Determine if compression is weak - remove plug, put finger over plug port, pull start cord. Should be evident of resistance/pressure build up when cord is pulled.
  4. Of course brand new plug!!! as above (I would try this first)
Hope this helps
please rate my comments - Thanks
Aky1967
Jun 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi Backpack Blower 25.4cc Logo
380 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
