Question about GE (PSS26MSRSS) Side by Side Refrigerator
Schematic for TBX19THB
Schematic for TBX19TH. 74 VAC across defrost heater though it does not glow when in the defrost cycle. Any help is appreciated.
  • 5 more comments
  • joseph_guari Jul 15, 2009
    Hi Chuck:
    Thanks for the quick reply. I see the bi-metal switch, how do I check for continuity....there is no easy way to check for continuity with the leads being insulated. Is one end tied to the defrost heater? When you say the unit must be cold...is that frost over the entire coil? The heater resistance measure 31.1 ohms. I assume that it is good since it shows continuity. Also, i removed the heater though I cannot get it back in place. It seems that you insert the heater then rotate, though it seems to bind on the sheet metal hole just before it will orientate the contact in a vertical position. Does it just take some force to get it into a vertical position? Should there be 120V across the heater when it is in operation? There must be a voltage drop across some other component, if it is to operate at 74V. Since I do not have a schematic, I am not sure where it is. Thank you in advance for your help.
    Joe
    Vic:
    I am sorry for addressing you as Chuck. It has been a long day. Thanks again.
    Joe
    Hi Vic:
    The heater is a glass tube radiant type. I believe that I can remove the sheet metal to reinsert the phenolic support into the hole. It came out....not sure why it won't go back in...I don't want to break the heater. When the defrost timer turns on the heater, is it also controlled by the bi-metal switch or would it always be on since it is in defrost mode? I put the timer into the defrost mode....that is when I measured 74V.
    Thank you, Joe
  • joseph_guari Jul 16, 2009
    Hi Vic:
    I purchased the thermostat but have not replaced it as of yet. I started the machine 30 minutes ago. How long before the entire evaporator coil gets cold? It is not even 25% cold so far. I assume that the entire coil must be cold before I can put it into defrost cycle to see if the defrost heater turns on. If it doesn't turn on, I should check to see if the thermostat is open.....correct.
    Thank you,
    Joe
    Hi Vic:
    Thank you,
    Joe
  • joseph_guari Jul 18, 2009
    Hi Vic:
    The defrost thermostat was good. The defrost heater turned on as it should. The machine has been running at no load for the past day, with temperature control knob set to 5 (Fresh Food) and C (Freezer). The machine never turns off following defrost. The freezer reaches -13 F and the fresh food goes to 33 F just before the defrost cycle starts. According to mfrs specs, when operating at no load at 70 F ambient, the freezer should get down to -3 and the fresh food to 34-40 F. The percent running time should be 34-44%. I am not sure why the temperature control is not turning off the compressor. Any thoughts would be appreciated. I have a couple of old controls that I am going to try to see if I get better results for cycling the machine on and off.
    Thanks again for your help.
    Joe
  • joseph_guari Sep 19, 2009
    Hi Vic:
    Still fooling around with the fridge. I detected oil on the line that goes up the back of the box. I can send a picture if you would like to see it. Back in 1991 the compressor was replaced after the first one failed, just after 1 year in service. Work was done under warranty so no cost to me. What is funny is the compressor never shuts off. In the morning, the freezer is -10F and the fridge is 27F. I have two thermocouples taped to spoons, one in each box, and connected to a Fluke multimeter with temperature adapter. In the morning when you start to use the machine (open and close the doors) temperatures seem to start to running away. Also, at the same time if it goes into defrost and it seems that it will never get cold again. It went into defrost 5 hrs ago and the freezer is now 40F and freezer is 11F. When I removed the back panel in the freezer 4 hrs ago (removed it quickly-it is loose) and found that 1/4 of the coil (lower left-hand corner of coil) had ice on it (not as bad as I have seen it in the past) rest of coil had no frost on it. Shouldn't the entire coil be cold - the remainder of the coil is probably above 32F. My thinking is the machine runs and runs and runs, coil freeze up and then you get no cooling.....correct? I think that it is low on charge (evident by the coil leak, though I recall this situation years ago and now it seems that it is really getting bad, as far as cooling goes). There are service ports off the compressor, though they are different than those that you would find on a auto. I have access to R12 gauges and refrigerant. Can I add refrigerant to this machine to keep it going for another year? What kind of adapter do I need to allow connection to the service port and use the R12 gauge set that I have access to? Am I correct in my diagnosis? The compressor is a GE RS8B1G2. Thank you for your help in advance and sorry for the long post. Joe
    President:
  • 1,136 Answers
Hi, Check the bi-metal switch located at the top of the evaporator coil. It need to be teated while it is cold. If the coninuity test shows an open circuit, replace it.
Please let me know if this helps you or if I can assist you further.
Vic
Posted on Jul 15, 2009
  • 5 more comments
  • Victor
    Victor Jul 15, 2009
    Joe, It must have 120V for the heater to operate. ne end os the bi-metal does hook up to the heater. The other end should be the power side. You should be able to insert the lead end of you meter into the connections of the wires.
    It need to be cold but not totaly frosted up.
    Is the defrost heater a glass tube radient heater?it should line up with the groves in the bracket on each end under the evaporator coil. Does this help?
    Vic
  • Victor
    Victor Jul 15, 2009
    No Problem. I have been called worse.....hehe.
  • Victor
    Victor Jul 15, 2009
    The bi-metal is a thermostat to shut the heater off when it reaches the right temp. It is in series with the timer and heater. The picture doesn't show a good pic off the heater mount. If you need to wire it up and let it hang.
    Vic
  • Victor
    Victor Jul 15, 2009
    Joe, The plastic ends on the element, are they in the metal bracket at all? It looks like the bracket should slide into a sot on the plastic ends.
    Vic
  • Victor
    Victor Jul 15, 2009
    Joe, Please let me know how things come out and feel free to rate my resopnses to you so that other as well as myself will know how I am doing.
    Thanks
    Vic
  • Victor
    Victor Jul 16, 2009
    Joe, It should be totaly covered within 2 hours. It won't get to the coldest temperature by then but the thermostat should be cold enough to test. You are gonna be a repairman yet!!
  • Victor
    Victor Jul 18, 2009
    Joe, Thsnk you for getting back with me. It sounds like the cold sontrol needs replaced. Try setting the control to 1 and see if it turns off. If it still runs, change the control.
    Please let me know.
    Vic
Frying sound in the side by side freezer. What is the cause?
you can hear the water dripping on the defrost heater during the defrost cycle . this only can happen every 8 hrs or run time .. this is not a problem . .. you may eb able to see the glow from the heater if you look low in the back of freezer .. ... mm hope this helped ..
Jul 10, 2011 | Kenmore Refrigerators
I bought a maytag side by side in 2002; model # MSD2454GRQ, SN 18157432AL, REV # 18. Ice is forming at the bottom of the maytag freezer department. Overnight ice will form at about 1/8 inch and left has...
Defrost problem: 3 components. Defrost Heater. Timer (circuit board or motorized) & Thermostat.
Remove cover on the inside back wall (usually 6 screws). Note frost pattern. (bottom of evaporator coil)
Put refrigerator into defrost cycle and note the defrost heater come on, or not. (careful heater can glow red hot)... Unplug Frige and test defrost components. Replace bad component... Refrigerator should defrost every 8 hours. when the cycle slows or quits the freezer will freeze over the evaporator coil and no air flow = no cold air...
Nov 15, 2010 | Maytag MSD2756G Side by Side Refrigerator
Heater
Good day,
Remove the rear panel in the freezer compartment. You will see the evaporator coil (cooling coil). The heater runs along the bottom of this coil. It is made of the same material a bake element in an electric range has.
While it glow? Not much if any on this model, but it gets quite hot during the defrost cycle.
May 13, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice forming on back of freezer , refrigerator side not cooling GE modelgss22wgpe bb
You frig is not going through the defrost cycle. Locate the defrost timer and advance it to the defrost cycle.(one click). Empty the freezer and remove the rear panel. See if the defrost heater is starting to get hot. Located at the bottom of the evaporator. If getting hot, replace the timer. If not getting hot, unplug the frig and check the resistance across the defrost timer(should be a closed curcit when cold) and across the heater. If "0" resistance, replace heater.
When replacing the heater alwarys replace the defrost thermostat at the same time. Will save you work in the near future.
Dec 28, 2009 | GE Refrigerators
I have a side by side that frosts up in the middle back ofthe freezer and the frig part gets warm. I have $200 in it and still no resolution. Bought new in June '04. I defrost for 24 hours, turn it on and...
If you can locate the defrost timer and advance it to the defrost cycle you should be able to see the defrost elements glow behind the rear panel in the freezer. Do this before the freezer gets too frosted up. If you can't see the glow then there is a problem with the defrost heaters or the defrost thermostat. Unplug the frig and remove all the racks in the freezer. Remove the screws holding the rear panel on. Locate the two heaters and check the resistance. IF open, replace heaters. IF ok check resistance of the defrost thermostat. IF open when cold, replace defrost thermostat.
If replacing heaters always replace defrost thermostat at the same time. It will save you doing so at a later date
Dec 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer is working refrigerator is not.
The freezer is not defrosting. Look at the back wall of the freezer section and see if it is frosted. Locate the defrost timer and advance it till it clicks once. This should advance the freezer to the defrost cycle. Check to see if the defrost heater is on. If the defrost heater is glowing behind the freezer rear panel the you know you have to replace the defrost timer. If the heater is not glowing then you have to check if the defrost heater or defrost timer is in default.
Dec 27, 2009 | Amana ABB1927DE Bottom Freezer...
Defrost heater voltage
Hi, Yes there should be 120V when the defrost cycle is on. If not, chack the bi-metal switch and see if it has continuity on it. It must be tested while it is cold. If there is an open circuit, change the by-metal switch. You can try and bypass the bi-metal switch and put the cycle in defrost to se if the heaters come on.
Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Jul 18, 2009 | Maytag MFD2561HE Bottom Freezer French...
It seems that our kenmore freezer is defrosting for no reason at all. I dont even hear the refrigerator kick on, the light is on.
Is it actually in the defrost cycle. Can you see the red glow from the heater behind the back cover in the freezer. Could be stuck in defrost because of defrost timer(adaptive defrost control).
Of it could be iced up on the evaporator coils behind the same cover, blocking the circulation of air. This would be a defrost failure. check defrost timer, defrost heater, defrost thermostat
Jun 30, 2009 | Refrigerators
Red glow in freezer
Hi, What you was seeing was the defrost heaters. You just happen to open the door in the defrost cycle. Everything is OK and you need not worry.
Hope this helps. Please rate my answer so that I know how I am doing.
Vic
May 10, 2009 | Hotpoint HSS25GFP Side by Side...
Refrigerator
My Haier wasn't defrosting right, ice would build up & the freezer would be fine but the fridge temp not right. After reading lots of posts, defrosting a few times,etc., I took advice & ordered a new defrost timer. (Repair Clinic) They had diagrams that showed where things are. This is everything I did. Unplugged it, cleaned off everything in back, double checked fans were all working, drain pan draining, in freezer took off panels to make sure ALL ice buildup was melted including drain hole. Made sure everything was connected (there is sensor w/clip that could be near or on the condensor coils & it wasn't on - so I made sure it was on) - dried things, put back together. Changed the defrost timer. Plugged back in. Two weeks have gone by and things are just fine! You definitely need to completely defrost the fridge because even if the defrost timer is the problem all the ice built up won't allow the fridge to defrost in the defrost cycle. You'll want a fresh start & it's worth it! I thought we were going to have to buy a new fridge! And my husband is proud that I did the trouble-shooting & repair all by myself! Thanks to all the help I found online!
Sep 05, 2007 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
431 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
