Question about Roland Music
I am looking for a manuel for the td10 percussion sound module i just got the roland v drums with this brain and no manuel and need to know how to set the levels on toms and cymbals basically all the kit
Http://www.ipass.net/davesisk/music/gear/RolandDrumBrain_TD-10_OM.pdf
This is a link to the full TD10 manual, Regards Amos
Posted on Jul 21, 2009
No pad sound
Not sure what module you're using this with, but I'm familiar with Roland electronic drum pads and modules, and guess the following would stand true for any pad / module combo....
I would check the following:
  1. Is the cable correctly connected at the pad?
  2. Is the cable correctly connected at the module?
  3. Is the module sound turned up?
  4. Are your headphones / speakers turned on & up
    (do other pads sound)?
  5. Is the fader for the specific pad (or pad group) turned up?
    (On a Roland module, where the pad is AUX1 to 4 - the 'fader' button needs to be pressed in order to operate the AUX slider).
    The next couple of things are less likely, but possible.
  6. Does the pad have a polarity switch on? - try switching it.
  7. Has he correct pad type been assigned in the module?
  8. Has an instrument been assigned to the pad
    (Roland: Press INSTRUMENT, hit the Pad, select a sound)
If you get no joy with this - please drop me a message.
Dec 30, 2012 | Alesis e Practice Pad Electronic Drum...
When I switch on the power in the roland HPD 15 handsonic, the number screen in the centre has the light but is blank, and the semicircle which has the numbers for different percussions has two lights on...
I had this problem and was about to send it back to Roland but tried a Factory Reset . It managed to fix it self but it has happened again so I woul dbe interested in finding a more perminnat solution .
Did you fix the probolem?
robin
Jan 23, 2012 | Roland Elektronische Musikinstrumente...
My KD-8 bass drum pad will now only trigger if it is hit really hard- I've tried altering the sensitivity at the brain to no avail any ideas please ? Thanks
SOME of these have a small potentiometer inside the pad part... The pot is VERY fragile and one needs a small jewler's screwdriver to adjust. You have to be careful as excess pressure on the screwdriver breaks the part off the circuit board inside. The access hole is only about 1/8 inch diameter.
Apr 12, 2011 | Roland Elektronische Musikinstrumente...
My roland td3 drums are playing the crash noise on every drum i am hitting even when crash is disconnected, why is this please?
Your Xtalk filter is set too low. Refer to the owners manual for how to adjust individual triggers' sensitivity to "cross-talk" (vibrations carried from other pads)
My bet is you unplugged the crash trigger, but not the cable from the actual module (the brain). If you have a cable connected to the brain but not to a trigger, than any little bump to the end of the cable that isn't connected can be picked up as though you hit the pad normally. (play with the end of the cable a little, you'll see what I mean. It's kind of neat.)
Jan 14, 2011 | Roland A: TD-4 Electronic Drum Set Pads,...
Hello sir i need a spare rubber for my HAND SONIC PAD HPD 15 can u please guide me for the same i shall be thank Full to u.
Try going to this link, chose your country and look under support or local dealers; http://www.roland.com/index.html You can also try this link; http://www.sweetwater.com/store/detail/HPD15/ Call their toll free number or email them to talk to a tech for advice.
Jun 22, 2010 | Roland HandSonic 10 Percussion Controller
Hooking up two roland brain modules.
No need to connect via MIDI. Just connect the pads to whichever and run audio out of each into seperate mixer input.
Unless you were going to use built in rhythms there is no real need to synchronize the units.
Apr 25, 2010 | Music
Does it have the option to load other sounds in it?
Here is the manual if you don't have it:http://www2.yamaha.co.jp/manual/pdf/emi/english/ssdrums/dtxp4_en_om_d0.pdf The set comes with 427 drum/percussion voices and 22 keyboard voices. If you use a midi cable plugged into the midi out on the sound module you can control other midi sound modules and midi devices by plugging into the midi in on them. Page 30 of the manual describes some of the parameters. If this helps please let me know.
Nov 19, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Music Logo
110 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Roland Music Expert? Answer questions, earn points and help others
