Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
I have a 20 hp craftsman lawn( hydro gear transaxle ) tractor in terrific shape that losses drive on a grade. I replaced the worn drive belt and it was good for the first few mows, Now Im right back to where it will not pull up a grade.
  • jlcarty5 May 11, 2010
    Is the transaxle the one with a spin on oil filter on it?Also a model number for tractor would be helpful.There is a possibility that the oil is degraded and a flush may help,but i need to know which transaxle it has.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
It sounds like the oil in transaxle is degraded.The transaxle is supposed to be a sealed unit requiring no service but over time the oil will get dirty enough to cause problems like you are describing.Remove the back hitch plate and look at the transaxle it will have a rubber vent hose or a 1/4 alllen wrench fitting on top. You will need to purchase a battery suction bulb from sears automotive and use it to remove as much oil from transaxle as possible. Warm the transaxle up first by running it around,then suction the oil out.Refill with a good synthetic motor oil 15w-50 or 20w-50 like Amsoil or Mobil 1.Do not use transmission fluid or hydraulic fluid. When adding the new oil back fill it to within 1.5 in from the top,be sure to allow this amount of air space in top of transaxle for expansion.
Posted on Jul 31, 2009
Ariens 19.5 hp drive belt slip
Question how old is the mower? Drive belt may need to be replaced due to being streched . Also is the clutch fully engaging , are there any worn pulleys?
Nov 10, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Brand new riding lawnmower, stop on hill, set park break, ready to go foward and when I push foward pedal and release break mower free whells backward. has 1 hr. on it. purged the trans. per instructions...
Sorry to hear about your problem...you aren't the only one having it. Sounds like a hydrostatic problem or a pulley freewheeling on a shaft somewhere. If you bought your tractor at Sears they might could help you---the husky and are the craftsman are the same. Husky uses a little better engine is all. Hope this helps.
Jul 11, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
I'm having trouble replaceing the motion drive belt on my LT1000 lawn tractor. The mowing deck is off, the old drive belt is off. I can't get the belt around the transaxle pully. Any suggestions?
Often there is a keeper on the back of the pulley, and the belt must go inside the keeper. Get an inspection mirror up in there to look if necessary. Start by putting the belt on the transaxle pulley, then on the PTO pulley, then on the idler, last have someone sit on the mower and depress the clutch pedal while you put the belt over that pulley.
Sep 26, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a Craftsman lawn tractor 21.5hp (hydro stat. trans.) I've noticied a small loss of power over a few yrs. Now I have no forward gear at all, I still have reverse, fluid level is up no sign of loose...
If you had included model no. I could have been more help but you probably will have to replace drive plate and or more in transmission. If you go to searspartsdirect.com and in model number type in, hopefully you will get parts breakdown of the transmission showing parts.
Oct 22, 2017 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have the same ,Sears Kohler tractor won't pull uphill
Have you checked the fluid level in the hydro trans, there is a drive belt from the engine to the hydro trans check and make sure that this is not worn or loose. Make sure that when you check the tension of this belt that you do not have the engine running or the parking brake set, since tension will be released from the belt when parking brake is applied. good Luck
Oct 07, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Sep 30, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Cratsman lt2000 lawn tractor will start but will not move forward or backward. I tried changing the drive belt, but that didn't work.
Is the transaxle pulley turning? If so have you removed the rear wheel recently and possibly lost the square key that fits on the axle?check those two items first.If ok it probably has a broken gear or shift key in transaxle.
Jul 14, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 20.5 hp. auto trans.lawn tractor loss of drive power
Hello:
>>You can View a Breakdown/IPL of
this Engine at this Site Addy,
http://www.outdoordistributors.com/
and Select the H. Then Select Hydro-
Gear. Then Select Don't have Part
Numbers. Then Enter the Model
Numbers 319-0650. Then Select your
Model and Download the File for
Online Viewing.
From your Description it Sounds like the Internal Pump is Worn and is Loosing Pressure as the Unit Heats Up and the Components Expand from the Heat.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 10, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman Transmission problem
Some of these tractors have a friction wheel that is driven off of a flat wheel on the bottom of the engine drive shaft. The rubber ring on this friction wheel could be worn out, or it could be out of adjustment.
Apr 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
810 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
