Question about Nintendo DS Lite Console
My top screen keeps changing colors
Every time i turn it on the screen turns everything a different color
  • 80 Answers
Something is wrong with connection with the bottom and the top screen. If you have ever dropped it that could happen. If all is bad try a new battery.
Posted on Jul 15, 2009
Top and bottom menu bars are different colors, I made bottm pink but top won't change color?
make sure that the "Let windows choose... " is turned off otherwise windows takes over.
Tony
Apr 27, 2014 | Gateway Computers & Internet
My hannspree monitor recently started flashing colors
i have 3 hannspree monitors 2 were sent back for repair i replacement was faulty when i got it back the other one changes flashing colours never again i tried turning the brightness to full which helped for a time
Mar 29, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
Tv went grayscreen, flickering. turned off, then
When you had gray screen and flickering you had only one problem - color wheel. After "putting everything together" you have totally different problem, caused by multiple possibilities like: forgotten connectors, cut/jammed cables/wires, lamp not being inserted properly, lamp door not being set properly, disconnected color wheel, etc. Try to open rear cover and redo what you have done. Remove optical block, check everything visually and slowly put everything back. If still no luck - then only skilled TV repairman may (or may not) help.
Mar 10, 2010 | Samsung Televison & Video
Screen changes colors only
Hold the Vol+ Vol- buttons down and turn on the power switch in the back of the unit.
The screen should turn blue and some square in the middle of it.
The noisy square is actually the bios being reset.
Once the unit turns itself off, you can turn it back as usual.
Note: Some of these units require a 3 button reset.
In that case hold Vol+ Vol- and Menu at the same time while you turn the power switch on in the back of the set.
I hope it was helpful.
Jul 07, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Laptop screen goes white
hi..right click on desktop,choose properties,select
settings tab and then choose highest bit in color quality.
see if it does make any difference,sometimes having low
or medium bit color quality can do such thing.
check it out..
thank u..
rate me..
May 04, 2009 | Fujitsu Siemens Computers & Internet
Laptop screen freezes in different color
This is definately an over heat issue. since laptops use on onboard graphics card, chances are you might need to replace the mother board, or may it may just need a fan replacement. also purchase a laptop cooling pad
Jan 27, 2009 | Compaq Presario 700 470024-192 Notebook
Home screen color
Yes, the home (XMB) does turn color depending on the time of day. This is a default feature. I haven't seen it yellow that I can remember. But check it at different times and make sure it is changing to other colors as well.
Sep 24, 2008 | Sony Playstation 3 (PS3) Console
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Nintendo DS Lite Console Logo
297 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
