Question about Whirlpool LER4634J Electric Dryer
Dryer works but does not heat - Whirlpool LER4634J Electric Dryer
    Brigadier General:
  • 4,088 Answers
Check and reset the house electrical breakers (Locked pair). One breaker of the pair may be bad--should be checked with a volt meter across the two breaker load side terminals. If checks 230 volts or so, then probably the heating element in the dryer is burned out. You have to remove the drum to get to the heater.
Posted on Jul 15, 2009
    Sergeant:
    Novelist:
  • 197 Answers
On the back, there may be a red push button to reset. where the dryer has overheated. If the heating element is only heating on a soft dry, wollens, etc, the element needs replacing. Keep checking your lint filter after every dr, to prevent a reset situation. Hope it helps, Regards Dave.
  • dave mccullough Jul 15, 2009
  • 5,911 Answers
The following link explains how to troubleshoot a dryer not heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
There is no reset button on the back of any Whirlpool dryer I have ever worked on. Most dryer heat related problems are attributed to poorly installed, kinked or clogged exhaust vent ducting. Pay particular attention to the section that discusses ventilation and make sure your dryer interior and ducting are clean. Leaving a dryer in a clogged condition will not only decrease the drying efficiency of the appliance, it will also cause repeated failures of any components you may replace and is a fire hazard.
The first thing you need to check is the wall receptacle for the proper input voltage. A reading across the two hot leads (left and right slots) should read 220-240 VAC. If this reading is incorrect, check your breaker panel. Some homes have the dryer circuit on two breakers, vice one single 220 breaker. If the voltage at the receptacle is good, unplug the dryer and remove the cover on the terminal block in the back of the dryer. Plug the dryer back in and take the same voltage check at terminal block across the RED and BLACK wires. You should see 220-240 VAC if good. If the voltage is bad at the terminal block, but good at the wall receptacle, you have a bad power cord. If the voltage is good at the terminal block, then the problem is internal to the dryer.
NOTE: The reason a dryer will still run if the input voltage is incorrect is because the dryer drive motor only uses 110-120 VAC, while the heating circuits require the full 220 service. So, if you are missing a portion of your input voltage, the dryer may exhibit the symptoms you have.
If you have nay questions about this repair, or require additional assistance please let me know.
Posted on Jul 17, 2009
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
My ge gas dryer works but no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 24, 2010 | GE Dryers
Dryer will not heat. It would initially heat but then the heat would stop.
heatman101
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Model #w8w2780wcwww over and under. dryer works but does not heat. ge model
heatman101
Aug 23, 2010 | GE Dryers
Heats up shuts off wont heat back up
heatman101
Aug 23, 2010 | Whirlpool LGR3624JQ Gas Dryer
Heat comes and goes, most of the time no heat but sometimes heat comes on
heatman101
Aug 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My dryer wont heat up. The ignitor coil glows but it only heats up on occasion.
heatman101
Aug 19, 2010 | Whirlpool Dryers
Our dryer works but does not heat up. this is onl...
if you dryer is gas check out this gas no heat tip....
check out this electric no heat tip...
heatman101
May 20, 2010 | Maytag Neptune MDG5500AW Gas Dryer
KGYS850LT / KGYS850LE / KGYS850LQ Gas Dryer: The drier is working fine just no heat?...
heatman101
May 18, 2010 | KitchenAid KGYS850LT Gas Dryer
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
390 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
