Question about Nor-Lake Norlake Refrigeration 4' x 6' Kold Locker Walk-In Cooler - 6' 7'' High w/Floor
Kenmore Refrigerator model 253.64814400 Our refrigerator seems to be running fine, however today a puddle appeared on floor from underneath it. Assume it is problem with the drainpan or line, but service guide says it is not removable. We do not have the automatic ice maker hooked up. Thanks in advance for any suggestions. vcb
5 Suggested Answers
  • 1073 Answers
SOURCE: sears refrigerator
stopped up drain in the freezer remove back freezer panel and
unthaw the drain pan and the tube, the tube connects to the bottom of the metal pan, you will see a hole about the size of a dime direct the heat from the hair dryer at this hole it may take 20 min, to thaw
pour some water down the hole if it is clear of the ice the water will run to the drain pan at the bottom of the ref
if it does not keep thawing until it does
Posted on Apr 17, 2008
mikedurland
  • 481 Answers
SOURCE: Ice Maker has some black stuff in water
check the ice-maker itself, it has a teflon coating (like a frying pan) that sometimes flakes off leaving little black flakes in the ice. if this is the case you have to change the ice-maker.
Posted on Jun 28, 2008
rpbuice
  • 161 Answers
SOURCE: Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Posted on Jan 12, 2009
  • 3600 Answers
SOURCE: water hook up
give me the model number and I will tell you where it is and give you a web page for where it is located and when you do get this info pleas rate for the help for free question. I will be waiting for the model number. the ice maker is fed threw the same line as the water. and is connected at the back.
Posted on Sep 13, 2009
About once a week I find a small puddle of water on my floor in front of my Kenmore Elite refrigerator (bottom freezer, no ice maker) What should I do?
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Oct 02, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice collecting in bottom of Kenmore Coldspot freezer side and then melting and ending up on the floor. It was first discovered by a puddle on the floor. This model--"59282990"--has...
Leo Ponder
imufo2
Aug 09, 2011 | Refrigerators
Freezer is cold, fridge side is not. Fan runs, compressor seems to run. water puddle on the floor on fridge side. anything available for DIY?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 01, 2011 | Amana ASD2620HRZ Side by Side Refrigerator
Refrigerator not keeping food cold enough.
I didn't solve this problem. Can't afford to pay to have this question answered as I am employed at this time. Will look for an answer that I don't have to pay for.
Aug 01, 2009 | Kenmore 60721 Refrigerator
Puddles of water appear on the floor from the refrigerator every now and then why
if the water is coming from underneath unit then check to see if your drip pan is full. if so check your fan by your compressor. if not running there is not heat transfer to evap water out of pan.
Jun 21, 2009 | Refrigerators
No cooling no freezing puddle on floor
Your defrost drain line is frozen over. Turn off the fridge and defrost the drain in the lower rear portion of the freezer.
Apr 23, 2009 | Kenmore 53642 / 53644 Side by Side...
Water accumulating in bottom of freezer and leaking onto floor
Yes the drain is clogged and the water that supouse to go through became ice so it make it worse.Put hot water in the drain hole until it runs through,it'll go to an evaporative pan on top of the compresor to keep it warm and vaporize the water.
Apr 04, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Puddle
no mater what the issue is the machine is under manufacture warranty for 1 year, call for factory service
Apr 12, 2008 | KitchenAid KSRP25FN Side by Side...
Refrigerators Logo
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
billconfused
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
