Question about Canon IMAGERUNNER 3530 Copier
Where is the serial number on a canon 3530? - Canon IMAGERUNNER 3530 Copier
  • 11 Answers
On the rear cover of the machine near the bottom. Or you can press the counter check button and it is also displayed at the bottom of the screen.
Posted on Oct 20, 2009
  • 130 Answers
BEHIND BATTERY
Posted on Jul 15, 2009
E000732 0001 error in ir 3530 how can i solve
Official instructions from Canon are these, try if it works for you:
Solution 1:
  • Check all the cables outside of the printer: they must be plugged, especially between the differents elements of the copier:
  • Solution 2:
  • Check all the connectors on the main board.
  • Solution 3:
  • Unplugg and replugg all the leads between the boards and modules
Dec 26, 2016 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
JAM ERROR 0207 ON CANON IR 3530
Open the printer and remove the paper jam.
Dec 04, 2014 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
Paper jam at the fixing unit for IR 3530
Check the exit sensor actuatir and the the fusing unit upper and lower roller strippels.
Apr 18, 2013 | Canon IMAGERUNNER 3530 Copier
Display touch is very hard
my printercanon ir 3530 insaid disply was rain water in said but how to open and cleen the disply bord tuch screen
Dec 15, 2012 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
Nov 10, 2012 | Canon gpr-16 ir 3530 blk...
How do I make an 11x17 newsletter on my canon 3530
If you are trying to print this from your computer to the IMAGERUNNER 3530 Copier, you need to access the "page setup" portion of the program you are using to produce the original artwork. If you are using "Publisher" or "Photoshop", for example, go to "File", Page Setup and change the paper size to 11" X 17". You will also need to tell it which tray in the IMAGERUNNER 3530 Copier you have put paper into.
If you are up-sizing the page from a previous size (ie: 8.5" X 11 or 8.5" X 14") you need to use the enlarge feature to scan into the IMAGERUNNER 3530 Copier and output to 11" X 17".
Let me know if I can be of any additional assistance.
May 27, 2011 | Canon IMAGERUNNER 3530 Copier
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Need authorisaton code for adobe photoshop cs activation number: 0065 7989 0006 0764 9725 4258 3044
Serial: 1045-1087-0042-9969-4346-1209
Activation: 0065 7989 0006 0764 9725 4258 3044
Auth: 7208 1393 6952 0802 8253
This is for the old CS2, but it may work for this too. Good luck.
Dec 07, 2009 | Adobe Photoshop CS for PC
E000002-0102
this is a fixing unit malfunction code you need a new fixing unit
Aug 03, 2009 | Canon IMAGERUNNER 3530 Copier
179 people viewed this question
old marine
old marine
