Electronics - Others Logo
Posted on Jul 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to find out what gauge of wire i need for a 1500 watt roadpro inverter to wire to batteries of a semi
Craig Butler
Level 3:
President:
  • Master 1,730 Answers
  • Posted on Jul 15, 2009
Craig Butler
Master
Level 3:
President:
Answers
1730
Questions
0
Helped
697170
Points
4778
At 12 volts DC it will pull 125 amps at full load of 1500 Watts.This requires at least #2 copper AWG
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Wiring diagram for power cord on a roadpro 100 watt
my roadpro snack master stop working after a month
What is the brown wire and blue wire for the power cord on roadpro100w
I would guess the blue is POSITIVE, and goes to the tip of the lighter plug. However, get a voltmeter and check...
Cheers.
THE RED FAULT LIGT IS ON AND IS ONLY WORKING AT PART POWER.
it has grounded out on you inside of your converter,Replace it.
My inverter is Roadpro 1500 but cannot power 700W microwave
How good is the connection to the battery? there are a lot of amps that have to flow fast and clamps just don't do it, lugged cables do!
Getting fault light, what can I do? road pro 1500 watt inverter
Check the Following:
  1. Ground from inverter to frame is intact
  2. Positive leads are intact and clean
  3. Negative leads are intact and clean.
I hope this of help to you please rate if the answer is of any help. If I can help any further will be glad to. Good Luck and have a great weekend.
Have several non working inverters
I have had this happen a few times.
Sadly replacement is the Best option.
Repairs can be %75 the cost of a new one.
The best invert we have been using is a Pure Sine 1500 watt inverter.
Sad news but hope this tip helps.
R/
David
I have a roadpro 1500 what size wattage of
depends on the type of oven but usually a comfortable load is 3/4 the size of inverter out put
3helpful
I just bought a RoadPro 2500 and i want to buy like a dorm fridge how many watts or volts size would work??
If you are referring to the RoadPro RPPI-250
  • 2000 Watts Continuous Power
  • 2500 Watts Power Output @ 10 Minutes
  • 5000 Watts Peak Power Output.
  • A small fridge will use about 500 -700 watts, with startup wattage at around 2000watts.
  • So, a dorm fridge will work fine.
  • the RoadPro converts DC to AC voltage, so a regular 120 volt dorm fridge will work.
  • 1helpful
    Can't get power to my RoadPro 1500 DC to AC Power Inverter
    I have had this same problem with several power inverters over time. The problem is usually one of three things.
    Those starting with the simplest.
    1. Too much current being drawn on the inverter.
    Solution (Check appliances that are plugged in and make sure they are not drawing more than 1200 watts. If they are unplug the appliance that is using the most current and get an inverter that is more suited to your power needs.)
    2. Some power inverters have fuses built on to them. Sometimes multiple fuses. Sometimes, one fuse may burn out leaving one intact. When this happens even small items draw too much current and over load the inverter.
    Solution (Replace the fuses)
    3. Improper installation. Inverters draw a lot of current. You must use the propper wire size for the inverter. I would recomend at least an eight guage wire directly fused and hooked directly to the battery. Of course like with all things the bigger the wire the better the flow of electricity.
    If it is not one of those things stop into a truck stop electronics shop and have the person diagnose it.
    Hope that helps.
    Top RoadPro Electronics - Others Experts
    ADMIN Andrew
    ADMIN Andrew
    deton8 von Splosion
    Are you a RoadPro Electronics - Other Expert? Answer questions, earn points and help others
