Question about Husqvarna Garden
New blades,correct air pressure still cuts uneven
  • 21 Answers
Try pulling the mower on a level surface and checking the deck for level if that checks out see if there is any play in the blade spindles ( with the mower off of course) hope this helps
Posted on Jul 27, 2009
Uneven Cutting with my Zero Turn 50"...Possible Causes?
First is being sure all your tires have proper air pressure and you don't have a bent blade. Then while parked on flat concrete and both outside blades at 3 and 9 o'clock measure blade height far left side of deck and far right side and compare. I there is a difference the entire deck is out of level and should be adjusted. Then remove the blade drive belt from one of the pulleys so everything is slacked. Grab each blade and see if it wobbles or has excessive play and check the spindle housings for cracks or breaks. If you find a housing with wobble or play the bearings in that spindle are shot ( this is a lot harder to detect with the belt tension on the pulleys) and should be replaced. If you find a broke or cracked housing the housing will need to be replaced. Either one of these situations may not be obvious with the mower at rest but the blade will wobble at speed causing uneven cuts.
Aug 25, 2014 | Garden
UNEVEN GRASS CUTTING
The most common cause of uneven grass is tire pressure of the machine. Even though they may look like they have air, when you go around a corner it may droop down on that side. If the mechanism is intact, there is no reason for it to change while riding. Or possibly you have a bent hanger.
Dec 15, 2011 | Garden
I have a Craftsman Lawn Tractor model 917.28712. 20 HP and 42 inch cut. The mower cuts uneven, lower on left side. My Op manual says that I have adjustments on both side. I only have an adjustment on the...
If tires are the correct inflation, check the angle of the deck. The blades may need to be sharpened. There is a blade balancer you can purchase. If one blade is not as sharp as the other, it will have a little more weight on one side than the other.
Aug 16, 2010 | Garden
Cuts uneven, lawn looks terrible. Missing half
Are your blades upside down? Mower deck level?Proper air pressure all 4 tires?Correct blades for the diameter of cut? Deck bent? Deck hangers bent?
May 28, 2010 | Garden
I have a Craftsman 42" rider cuts uneven
Check your tire pressure first, uneven tore pressure will cause this problem.On the rear of cutting deck on both sides there are height adjustments, if your deck has a rear roller this also can be adjusted to compensate,If your a stout person sitting on tractor can cause unevenes.
Jun 25, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
2003 DLT3000 Craftsman riding mower. Air in tires correct, deck level front/back & side/side, new blades.. Still cuts uneven. Does this deck flex when cutting tall grass & how do I fix this...
when you put the new blades on did you notice if they were even with each other? the 42" decks have a tendency to "warp" inward on the left side. this causes the left blade to ride at an angle to the right blade - there is a tool to correct this, but not all shops have it - sometimes you can remove the deck, flip it over and wallop the inside edge of the left mandrel until the blades are even - a 2 lb. sledge works well for this
Aug 26, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Uneven cutting
put your mower on level ground. Concrete or pavement. Check to make sure deck is setting level. If not, adjust deck. NEXT. Make sure mandrel or shaft isn't bent or broken. (this is what you bolt your blades onto and top side is where the belt runs.) If you have hit a root or rock. These will bend and break. If so, Remove and replace with good used or new one. You can purchase the housing for somewhere around 25 to 35 dollars
Jul 26, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Duel blades on craftsman riding mower cut unevenly
check the front tire air pressures then for a bent blade
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Cuts lawn uneven, one side shorter than other
Was it cutting uneven before you changed blades? If so, you may not have gotten the blade on the shaft correctly. There is an adjustment in the center of the deck hanger on each side. You can turn the 9/16 nut up or down on each side to level it out.
May 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
143 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
