Question about Beverage-Air Kegerator - Beer Keg Cooler Refrigerators DD48 2 Keg Space Saver by Beverage Air
I have a beverage air dd78 that the compresser is bad. what is the best thing to do ? iI am debating weather it is worth fixing or getting rid of. any repair place in or around Loveland, Colorado that knows this unit? Thanks Terry
    Top Expert:
  • Beverage-Air Master
  • 76,070 Answers
We can't provide local info as we are all over the world, i am in calif, look in the phone book, but chances are the repair cost will be more than or about the same as a new unit with labor rates that are near $100 per hour these days.
Posted on Jul 15, 2009
I have a Beverage Air cooler (Model UR30G) where the fans seem to be running, but only warm air comes out...it's about 10 yrs old and is in great looking shape and would love to find a way to fix....any...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 26, 2010 | Carrier Beverage-Air UR30GEFD Beverage...
Model nodd78e iceing coils or not cooling when at lower t stat setting was r12 changed to hot shot
icing coil could be improper freon level, poor air flow. If it was changed to hot shot due to a low freon level, was the leak in the system located and repair? If so, then check out the above mentioned items. If not, freon level is low due to an unresolved leak.
May 17, 2010 | Beverage-Air Beverage Air 2- Tap Unit...
Clogged drain in a beverage aire mod# dw49
I like to use compressed air, sometimes a wire may work to clear the drain line. It will require some dissassembly of the unit to gain good access to the drain. Clean everything once dissassembled, it will save you trouble later. Hope this helps.
Dec 24, 2008 | Beverage-Air Beverage Air DW49-S...
Beverage air cycling off/on
These units are not designed to run in temps much lower than 50 degrees. They have no winter controls and the freon pressures will take a nose dive when running in a cold ambient condition. The unit will not run well in a cold environment, compressor damage may result. :(
Dec 16, 2008 | Beverage-Air Beverage Air 2- Tap Unit...
Beverage air dd78e not cooling
change setting on thermostat and see if anything changes. If yes, that's the prob if no, freon level. start there.
Dec 14, 2008 | Beverage-Air Beverage Air 2- Tap Unit...
Restriction
The cap tube is clogged and the unit is overcharged. Get used to this on beverage air units.
Nov 18, 2008 | Beverage-Air Beverage Air 2- Tap Unit...
Ge wall unit cools and then stops
Weather below 50 deg F can harm airconditioners if you run them. If the unit is turned off, then the weather can get as cold as it wants to and not damage the unit. Also 99.999% of the time repair costs on wall units surpass the cost of replacing the unit. This is even accounting for the fact that you will have to pay $25 to $50 to get rid of the old a/c. 5 yrs isn't that bad for a wall shaker anymore. Suggest looking for a new unit.
Jun 27, 2008 | GE AJCQ08ACB Air Conditioner
Beverage air dd78 comp.wont start..tripping GFI
Refrigerators often will trip the gfi via the compressor. If you have checked all the wiring. The problem is likely in the compressor windings. I have had this occur in brand new units. Another thing to check the gfi, less expensive gfi outlets do not handle refrigeration equipment well. You should consider getting an industrial rated outlet. Hope this helps.
Oct 22, 2007 | Beverage-Air Beverage Air 2- Tap Unit...
Refrigerators Logo
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
