Question about Frigidaire FRS6R5EMB Side by Side Refrigerator
MY indoor water is no longer cold - Frigidaire FRS6R5EMB Side by Side Refrigerator
  • 153 Answers
Check the temprature and read the menual again and check if is there any problem with the door.
Posted on Jul 25, 2009
Our AC keeps cutting out. It runs for a few minutes then stops. have to switch off and restart. Any idea why? Have emptied water and cleaned filter recently
Look for:
  1. the ac needs air flow thru the indoor and outdoor radiators
  2. the outdoor radiator coil should get warm/hot and produce warm air.
  3. indoor radiator coil needs should get cold and produce cold air.
The ac needs the fan motor(s) working and compressor running and pumping. Compressor skinny copper line hot and thick line cold.
Jul 21, 2015 | DeLonghi Heating & Cooling
My plants leaves are curling up
Need a lot more information. What plants? Indoor or outdoor? What soil are they in? Are you watering enough or too much and do you give it fertilizer as directed?
Nov 19, 2013 | Zilla Guzmania Bromeliad Plant
There seems to be humidity in the watch
If the humidity has been condensing or happening for a period of tmie longer than 3-4 hours, this watch should be taken to a Certified Master Horologist in your local area as soon as possible. The timepiece should be opened, dried out, resealed, and water tested.
If humidity comes and goes away within 3-4 hours it is a normal occurrence from extreme temperature change (A/C to outdoor heat, vice versa) (Outdoor cold to indoor heat, vice versa).
Jan 16, 2011 | Giorgio Armani Emporio Armani AR0584 AA...
Water heats, then turns cold
These units need lots of flow to start and run. Set the temp on the unit lower and the people in the shower will have to use more hot and less cold which will make the unit more stable.
Jun 29, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Rheem tankless water heater error code C4 13??
check diaphrapm valve or micro/switch best of luck
Sep 13, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
Cold water doesn't get cold
Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
May 18, 2009 | Avanti Hot and Cold Water Cooler
Intermatic electric water heater timer only gives enough hot water for a 7 minute shower. How do I increase this time?
Try turning your thermostat up 20 degrees. That will make hotter water, requiring more cold to mix so you'll use less hot water for the shower. If that helps but you'd like it longer, increase the temperature in 10 degree increments until you reach a temperature that works.
May 14, 2009 | Intermatic T103 Indoor 120-Volt 40-amp...
Cold air coming from jets in a large garden tub indoors
jets pull outside air in thru the water jet in a natural Venturi action. If you are referring to the air bubbles in a bathtub then, yes there are air blowers that have heaters inside them to warm the air before if goes into the tub.
Feb 20, 2009 | Home
Frigidaire FRS6R5EMB Side by Side Refrigerator Logo
35 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
