Question about Refrigerators
Top freezer fine, frig not cold. fan,condensor cleaned.
MTB1954DR top freezer fine, frig is not. vacuumed out rear compartment around blower and condenser. no change.
  • 52 Answers
Set both cold controls on the number 4. See if this helps
Posted on Jul 15, 2009
Whirlpool Frig/Freezer - Frig side too warm at 60 degrees
Check for another fan to cool the fridge side. It could be bad.
murf427
Aug 01, 2012 | Whirlpool Refrigerators
The blower in frig is not working, frig is warm freezer is working fine, we have vacuumed all area & unplugged for serveral hours. please tell us what else we can try.
all it does is blow cold air from the freezer into the fridge section,open the freezer door,you should hear the fan blowing,no fan fridge will be warm bad evap fan motor,also send the brand name and model number,some machines have dampers in them if the damper is bad it blocks the cold air from entering the fridge section,send model number and brand name,
Sep 25, 2011 | Refrigerators
Frig on top freezer below.....freezer working.... frig not...condensor seems fine and fan is on?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 20, 2011 | Amana ABB2227DE Bottom Freezer...
My Kenmore refrigerator model # 253.7419240p the freezer works perfect but the fridge part is very warm i had milk in it over night and it spoiled... what can i do to fix this i can not go without a fridge...
the fact that the freezer is still cold is a good thing as that means the compressor is still running, and probably at least the condensor fan also that is beneath the frig/freezer near the compressor.
check that the fan in the rear of the freezer is running when the compressor is on, if so then your issue may be a pluged or blocked air passageway that interconnects the freezer compartment with the frig to cool it. this will need to be chased down and located to remedy
if the fan is not running you will need to find out if there is power to the fan, if so the fan is shot and can be replaced, if not then we need to find out why. broken wire between the defrost timer is a possibility, even a bad connection through a moly plug could cause it.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 61042 Top Freezer Refrigerator
Hi my refrigerator and freezer is not getting cold what could be the problem?
A variety of things could be wrong. First ,check your condensor for proper airflow.Is it dirty? Do you have a fan that moves the air over the condensor? The fan may not be turning and would cause the frig to not cool. Good airflow over coil removes heat from the coil = better cooling inside frig compartment.hope this helps
Sep 26, 2009 | GE Refrigerators
Ge tpx21pr side by side refig/freezer Freezer is not cold enough
If your unit is NOT a static condensor, (the type with cooling fins and tubes on the outside of the back of the unit) If the door seals are okay and sealing properly, you might need to service the forced air condensor components located at the rear lower area, usually behind a fiber board cover. Remove the cover and look for dust on the condensor fins and fan blades. If clogged, carefully brush, vacuum, or blow the dust out, opposite the direction of the fans natural air flow direction. (You don't want to lodge the debris further into the condensor fins.)..Be sure to unplug the unit first.
Jul 31, 2009 | Refrigerators
Maytag freezer don't freeze food or make ice
There could be several things causing the frig to be cold but not cold enough. First check thermostat control and air control. Both should be set in the middle setting for normal operation.Next check to see if evaporater fan is running in freezer. It should be running whenever compressor runs and circulates cold air inside frig as well as freezer. Next check if condensor fan motor is running. It blows air over condensor coils to remove heat. Last ,check condensor itself for dirty coils. If they are matted up with hair dust,etc. it will cause poor cooling. you can give thorough cleaning with vacuum cleaner. Hope this helps
Jul 28, 2009 | Maytag MSD2756G Side by Side Refrigerator
My Jenn-Air frig, model JCD2389G,isn't cooling. It's less than 7 years old. Freezer seems fine. Frig is set at coolest and still is only 55 degrees. Cleaned back of frig, what else do I check? thank you,...
Check the fan located in the freezer compartment.
This fan blows the cold air from the freezer into the fridge and is about 40 dollars for the part. Simple to fix too.
Gary
Jun 05, 2009 | Jenn-Air JCD2389G Side by Side...
GE TFX 22CR Freezer works but not Refrigerator.
If the evaporator fan isn`t working, the frig will not circulate the cold air needed from the freezer to the fresh food compartment. You will need to remove the panel and check for ice around the fan. Make sure it can turn free. If it isn`t blocked and you can turn it freely and there is voltage going to it, the fan motor has gone bad and needs to be replaced if there.
Nov 11, 2008 | Refrigerators
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
