Question about Garden
Chainsaw will run but will not shut off with the run/stop switch
My Chain Saw will run with no problems, but when I try to shut it off, it won't shut down with the Run/Stop switch.
I have tried another switch, not the exact same switch, but I was told it would work, but it doesn't.
Saw continues to run with no problem besides shutting it off.
  • sukecchi Jul 15, 2009
    I had to make a new wire for the switch so that I have eliminated the old wire already.
  • 721 Answers
The cut off wire is probably broken before the switch. Depending on the make,you'll need to remove the pull start housing to fix it.
Posted on Jul 15, 2009
Cant get enought gas
repair - What should I check if my chainsaw fails to start ...
diy.stackexchange.com/.../what-should-i-check-if-my-chainsaw-fails-to-s...
Feb 26, 2013 - Does anybody have any idea what I can do to get my chainsaw started?... Clean carburetor and fuel lines, especially if it may contain old fuel. ... that prevents it from generating enough current to sustain repeated firing of the spark plug as the engine turns. ... Your muffler is pluged up your saw can't exhaust.
Stihl Chainsaw - starts but won't run - GardenWeb
forums2.gardenweb.com > Garden Forums > Tool Shed
Aug 9, 2006 - Re-chocking (once until it kicks) gets it running again for another 20-30 seconds ... carb body was not letting enough gas through to contunue running the saw at full speed ..... MY STIHL 029 CHAIN SAW BLOWS GAS BACK OUT OF THE .....Can't imagine why shaking the saw around would keep it running. Chain saw won't start
Feb 8, 2012
homelite xl chainsaw
Sep 4, 2009
Husqvarna chainsaw wont start?? HELP
Oct 15, 2006
chainsaw starts then after few cuts shuts down
Mar 30, 2006
More results from forums2.gardenweb.com
chainsaw won't start - any ideas? [Archive] - Straight Dxxe ...
boards.straightdope.com > ... > Main > General Questions
21 posts - ‎11 authors
Jan 31, 2016 | Garden
My chain saw starts but won't keep running what is wrong with it
Sparkplug ,If not. Try saw on half Choke, if works check filter in tank.
Jan 22, 2015 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
My saw runs great for about 5 minutes then it seems to over heat and it quits running.
There are several things that can cause this problem First if you run it until it quits will it start working again after it cools down. If this is the case the it is shutting off thermal switch on motor. This could be from saw needing cleaned or lubed, make sure chain is not to tight, don't force saw to hard,let it cut at its own pace. Make sure chain is sharp. Anything that causes excessive friction will increase motor temperature. It is possible that thermal switch is about worn out. Hope this helps. Thanks
Nov 12, 2010 | McCulloch 14" Electric Chain Saw Mcc1514
The carriage comes off and makes a grinding noise when using the extension plates.it does'nt move smoothly over the bed or needles
My Chainsaw's Engine Does Not Start: If the engine will start at all, you might have a bad starter switch. Check to see that all connections to the starter switch are secure. Is the power cord cut or broken? Check to make sure that you have a proper power line connection. If all checks out except for the switch, go ahead and replace it. You may want to consider whether you are using the appropriate fuel mixture.
My Chainsaw Smokes: If there is smoke coming from the chain, it could be an indication that there is not enough lubrication. Without the proper lubrication, the chain and chain bar can become seriously damaged. Make sure there is oil in the reservoir. When you start the saw, the automatic oil pump should lubricate the chain and bar. To see if this is a problem, hold the saw tip over a light-colored surface, hit the throttle and look for oil spatters on the chain bar. If you see no oil splatters, turn the saw off. Remove the chain guide bar and see if the oil discharge slots are clogged with sawdust. Clean out the sawdust and restart the saw to check lubrication again.
The Chain Skips or Jumps: If the chain skips or jumps during operation, check the engine drive sprocket to make sure it is not worn. If you have a worn sprocket it will not allow the chain to sit properly. Also, check to make sure the chain tension is set correctly. Setting the chain tension is a part of continuous operation. However, a dull or damaged chain may also cause the skipping and jumping.
My Chainsaw Isn't Cutting Properly: If the saw cuts at the wrong angle or shoots out a lot of sawdust, you probably need to sharpen the chain. A dull chain can be very dangerous. It can cause a kickback or chain jump that might break the chain and release pieces that could harm to the operator. If your chain is very shiny, you need to examine each cutter for damage. Use a file to sharpen the cutters.
The Chain Continues to Move or Stops: If the chain continues to move while the engine idles then you should check to make sure the idle is not set too high. If it stops while cutting, see if the brake is engaged.
My Chainsaw Loses Power: If the saw loses power while operating, check to make sure all electrical connections are secure. Any break in current may cause the saw to decrease in power, stall or shut down altogether.
How to Sharpen Your Chainsaw: Once you feel the chainsaw start to "grab" or stop with more frequency, shut the machine down and begin sharpening procedures:
1. Find a good, flat surface to place the chainsaw on (clamping the saw in a vice for stability would be optimal). 2. Make sure that you have a sharpening file that matches the size of the teeth on your chain. 3. Next, you'll want to make sure the chain is clean and clear of any debris so that nothing interferes with the file or sharpening device. You should have some kind of degreasing detergent at the ready so that you can wipe the chain down and during the cleaning and debris-removal process, make sure there are no damaged or broken teeth on the chain. 4. Before sharpening, take a piece of chalk, a pencil, a crayon, etc., and mark the tooth on the chain where you begin...so you know where to end. 5. At this point, you're ready to start sharpening. Find the groove between the teeth (the little notch in front of the tooth...your file should fit right into it) and give about 3-5 good swipes of your file (if you have a good, sharp file, this should be sufficient). Make sure you use the same amount of swipes for every notch/groove so that you keep everything even. Also, try to use the same angle with each swipe; this will contribute to a smoother performance by your chainsaw. 6. Repeat this process one at a time until you have come back around to the tooth where you began. 7. Then, after one side is done, turn the saw around and repeat the process. Again, remember to use the same amount of swipes with the file every time, and try to keep the same angle; uniformity/consistency within the teeth of the chain is very important for evenness and smoothness. As a general rule, after about 12-or-so times sharpening, you will want to bring the chain into a power tool repair shop or a place that does chainsaw repair, for some professional sharpening. The pros will be able to grind the chain back into shape and get the angles perfect.
Oct 05, 2010 | Garden
How do you remove the sprocket and clutch assembly
Article: Fixing a Broken Chainsaw
Having a broken chainsaw is an inconvenience. Having one that works when you need it is important! Chainsaws are useful tools for tree pruning, cutting firewood, and carpentry projects, but are not so useful if not properly maintained. It can also cost a great deal of money to get a broken chainsaw repaired. You can save a lot of time and money by repairing it yourself. For chainsaw repair you will need a blanket or large cloth, a chainsaw tightening tool, files to sharpen the blades, and any necessary replacement parts.
My Chainsaw Smokes
When maintained, chainsaws are a great asset to any tool collection. Consult your user's manual for questions specific to certain manufacturer types.
About the Author:
Oct 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Reference the Husqvarna 350 chainsaw. Why does the chain continue to turn at idle? I just installed a new clutch. Adjusting the idle down causes the saw to shut off upon trying to accelerate.
Sounds like the clutch is still grabing. Easy solution is to apply the chain brake at idle to stop the chain turning. Try adjusting the L screw for a smoother idle.
Aug 05, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Chain saw runs fine but won't stop running
a single wire from the coils connects to the on-off switch and when you switch it of just earths that wire trace the wire and check the connection
Apr 04, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My chainsaw quite suddenly. i restarted it but
1. The kickback brake, if equipped, was triggered to stop the chain.
2. The chain is jammed with saw dust/debris (it doesn't take much)
3. the bar sprocket is damaged.
4. The chain guide teeth are damaged and not sliding through the bar guide groove smoothly
5. The chain is adjusted too tightly.
6. You are out of bar oil and friction has stopped it/damaged the bar and/or chain
7. The motor sprocket clutch is damaged.
That should cover all of the basics to look over.
Nov 04, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Chainsaw shuts down when chain engaged
hi gregory
I think it has a carburation problem.Check the fuel line and the fuel filter:
cheers savumihai71
Nov 12, 2008 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
126 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
