Question about Optoma HD65 DLP Projector
Our projector started making a sound - Optoma HD65 DLP Projector
  • 130 Answers
MOST LIKELY THERE IS BUG IN FAN MOTOR
Posted on Jul 15, 2009
Optoma movie time projector has a vibrating sound
Normally this sound noise is the small FAN inside. Dirty or faulty. You must open the proyector, or go to some shop repair.
God bless you
Jan 25, 2013 | Optoma EP706 Projector Remote Control
Dear Sir, I have a NEC LT 260 K Lcd projector. The lamp of the lcd was busted.I replaced it with a new lamp. After replacing the lamp the lamp is not lighting when projector is put ON, I think the...
the clicking sound hopefully is the high voltage trying to start the lamp, but for some reason there may be a connection problem between the lamp and the projector power supply.
take the lamp out.
look at the lamp and check that the 2 connecting plugs are ok.
then look inside the projector at the power sockets that connect to the lamp (when it's installed).
check that the pins are not damaged or pushed down too far to prevent the lamp plugs making a proper connection with the power sockets in the unit.
Jul 01, 2011 | NEC LT 260K Multimedia Projector
When I turn on the power light comes on , then the warning light comes on and the projector fails to start
I would start off by making sure that the fans and filters are cleaned. The easiest way to do this is with a can of compressed air that you can buy at any office supply store. If that does not solve your issue, than it would sound as if your bulb is burnt out.
Feb 28, 2011 | Sanyo PLC-SW30 Multimedia Projector
My projector wont turn on anymore, what do you think the problem is ? power supply or the lamp?
Some projectors will not start if you have seriously exceeded the normal life hours of the lamp. If you do not replace your lamp when notified by your projector, the lamp will continue to get so weak that the starting amperage of the ballast will eventually make the lamp explode in the projector. manufacturers don't want you to have to vacuum out bits of glass and mercury from the projector, so they just stop the projector from working until a new lamp is installed.Do you hear a ticking sound of the ballast trying to start the lamp?
Aug 16, 2010 | Sharp Office Equipment & Supplies
SHARP NOTEVISION XG-C50X LCD PROJECTOR: Does this work for laptop presentations as well as DVD projections
Hi there, Sharp makes light and compact projectors with low fan noise. Set the projector up in areas subject to minimal humidity and dust to avoid having to clean the lens too often. Remember that colors will get washed out if the screen is in direct sunlight. Learn a few troubleshooting techniques to get the most out of this work horse projector.
No Pictures, Sound or the Projector Fails to Start
  • If you have no pictures, sound or the projector fails to start, check that the power cord is plugged into the wall and that all the cables are connected to the rear panel. Make sure the remote control batteries are fresh. If you are using a notebook computer, make sure the screen output is correct. Check the Input Mode on the projector. Check the projector physically--is the lamp and cover in place? Check the key lock.
  • Jul 31, 2010 | Sharp Notevision XG-C50X Multimedia...
    No sound on my infocus lp530 - laptop thinks its connected, audio cable is good, sound is up on the projector. suggestions?
    make sure the settings on the projector are set to internal speakers and (obvoiusly) the sound is on and up on the laptop.
    Oct 16, 2009 | InFocus LP 530 Multimedia Projector
    Viewsonic Projector PJ506D not working
    proable solution the cooling fan is giving problems. the whistling sound most likely is fan rubbing on a wire??? The unit gets over heated and turns off for protection. Good luck
    Aug 19, 2009 | ViewSonic PJ506D DLP Projector
    Optoma DV10 projetor suddenly started made popping sound
    hi,
    Please Check and service the fans and the Air filters. then check again. In case the noise still comes then service the fans or replace accordingly. By complete service of projector, this will work.
    Rave services
    Jan 12, 2009 | Optoma MovieTime DV10 Multimedia Projector
    Vibration noise on optima Projectro/DVD unit
    Hi mstadisasta
    This is a faulty colourwheel that will have to be replaced as a colourwheel cannot be repaired.
    It is quite easy to replace and I would suggest you to do it yourself if this unit is no longer under warranty.
    All you'll have to do is get your hands on the new colourwheel from your local or nearest retailer.
    Thanks for using Fixya !
    May 25, 2008 | Optoma H30 Multimedia Projector
    Optoma HD65 DLP Projector Logo
    93 people viewed this question
    Top Optoma Office Equipment & Supplies Experts
    jasbo
    jasbo
    color wheel light...
    Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
