Computers & Internet Logo
Hung Nguyen Posted on Dec 31, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 4 Ethernet ports output in the back quit working. Tell me how to reset or troubleshoot.
Brett Duxbury
Level 3:
  • Computers & ... Master 4,352 Answers
  • Posted on Jan 01, 2016
Brett Duxbury
Level 3:
Answers
4352
Questions
0
Helped
1118626
Points
13423
Try pulling out power cord for 30 seconds.
put back in
has anything changed in your network have you added any other network devices ?
can you ping between each devices ip address ?
how are ip addresses assigned and is there a conflict between same ip address on two devices.
what model number and make is the device with the ethernet ports. ?
Been having troubles with the earthnet port in back of pc how do i go about changing it
Assuming you are talking about the Ethernet port on the mainboard...
Please define 'trouble'...
1. Is the network port not working and is the driver correctly installed?
2. Switch the Ethernet port OFF in the Device Manager and
install a (quite cheap) PCI network card on the mainboard.
Can you remind me how you connect a router to the modem to the computer?
Output from the modem .. CAT5 from WAN port into
WAN port on back of Router
CAT5 from ethernet port ( netport card) on back of PC into any open port on back of router. Power up router and allow to finish booting
Power up PC
I cant install my router. The internet, power, WLAN, and DMZ lights are all on, but none of the Ethernet port lights are on, but when I try to complete the install I get the following error message: Unable...
If the ethernet light is not coming that means your router is not detecting your computer. Try to plug the computer on any other port.
To check if your ethernet ports are fine you can perform a loop back test. You can take a cable which is not connected to anything. Than put one end of the cable to one ethernet port and put other end of that same cable to any other ethernet port. If the light on the ethernet ports led up means your ports are fine and u need to reinsatll the drivers of the ethernet card on your computer. Else your routers ethernet port are not functioning. If that is the case you can try to reset the router.
Let me know your finding.
**If this works please rate else let me know in case of further help.**
I forget my ip of TEG-S2600i 24-Port Ethernet
At the back on your switch there is a reset button. Press and hold it down for 10 seconds to reset it.
Default ip address of this switch is 192.168.0.1
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
1helpful
Router quite working. Wireless does not work nor
Follow this procedure :
  1. Turn off all components on your network - computer, router, modem, printers and any wifi laptops
  2. With the ethernet cable connected only between the modem and the router TURN THE POWER TO THE ROUTER ON and let it boot up.
  3. Turn on the modem and let it boot up to all lights on.
  4. Connect / boot up any and all other components on your network.
Keep this order handy in case of a power outage. Best of successes!
2answers
Network card
Yuo need to install a driver for your network card. Go to the IBM WEB site to download a network driver for your particular model ThinkPad.
Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
To make a router connection to Xbox Live:
  7. Turn on your Xbox 360 console with no disc in the disc tray.
  8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
2helpful
5answers
Ethernet vs. usb
FYI for those people trying to use a ethernet and usb cable from a cable modem - it may work for a while but it won't work forever - your ISP will only allow one IP address out of the modem unless you pay for additional addresses (then you need a switch). Each device you have on the modem is fighting for that IP and eventually it will just quit working (if it works at all).
If you want more than one computer on your network (on the Internet or sharing printers/files, etc) then you need a router or a gateway (cable modem/router combo which I DON'T recommend).
Grand Canyon Tech
Grand Canyon Tech
