Please always include full 'make model (what it is)'. It appears to be made by Nova Kool, made in Canada and is a dual voltage RV Fridge. Those are all important details. Here is the wiring diagram.
Nova Koolhttps://www.novakool.com > wiring-support
Q: Can I see a wiring diagram? A: Please see the wiring diagram in our online manual or click the below links. ; Q: What Wire fuse and breaker size do I need?
Missing: gr272- ‎sv
https://www.novakool.com > full-faq
Below are the Most Frequently Asked Product Support Questions. Please See Our Online Manual for Detailed Information:
So far, I cannot locate a wiring diagram for an installation. However, this is a single phase "shaded pole" motor.
For a single speed, shaded pole motor, there are only two power wires. For a dual speed motor, a third wire provides a second speed. One wire will be one side of the motor coil(s)...connected to the white power wire. The other wires are the opposite side of one or two motor coils, connected to the black power wire or through a thermostat. A thermostat is simply a temperature operated switch. An additional wire may (should) be a green "grounding" wire.
your best bet is to go onto www.the12volt.com and find the tab at the top that says subwoofer wiring diagrams. Next go to google and search for audiovox subwoofers and search through. You will definately have no issue if you find the model it will tell you the impedence of the subwoofer. 2 ohm dual voice coil, 4 ohm dual voice coil, 8 ohm dual voice coil. anyway it is a dual voice coil
This model of cook top needs the 4 wire install because it has both 220v and 110v circuits. The forth wire is a neutral that operates the 110v circuit. You can move the ground of the 3 wire outlet to neutral, but ONLY! if the ground wire is insulated. What this will do is give you both your 220v and 110v circuits. The problem with that is your cook top will not be grounded. The best solution is to locate a neutral wire and tap into it, this will give you your 4 wire circuit. Your missing a neutral in a 3 wire outlet.
